Question about RCA HD52W59 HDTV Projection Television
Color not correct picture fuzzy
The tv hesitates when you turn it on and the color seems to be greenish and the sides of the picture are fuzzy.Any help on this would be great.
I have spoken with support they told me a problem like this is usually a "color wheel". You are looking at $500 plus for repairs. Good Luck!
Posted on Jan 21, 2008
Green Color Tint
I had a similar problem with my tv. Sometimes it depends where the tv is located, have you moved it? Magnesium in the earth caused my tv to have greanish tints in all four corners of my tv. Try moving your tv forward, backwards, or side to side. Let me know if this works.
Cynthia
Feb 01, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture is greenish hue and cannot be changed from menu bar
The greenish hue cannot be adjusted from the menu. One has to do it from inside.First confirm by turning the color settings to zero using the remote. You should get a clean black and white image with no traces of any color ( inc: green ). If your TV is greenish , the green drive on the base of the picture tube has to be trimmed.
All you need is a screwdriver. There are dangerous voltages inside a TV, some as high as 27,000 volts !!!. Where the color adjustment has to be done there are voltages as high as 110 volts and 8000 volts.If you still want to make the adjustments yourself revert back for instructions
Apr 11, 2011 | Sony KV-36FS12 36" TV
Picture is starting to get greenish, yellowish colored
hitachi model 51f510 projection tv has horizontal lines & has greenish tint,do i need to chang the bulbs??i alredy tryd the magic focus button & manual focus,but unsuccesfl,any ideas????
Nov 27, 2009 | Hitachi 51F510 51" Rear Projection...
TV Picture is tinted pink
depending on how much you paid for the tv , the cost of the repair may be more than the tv is worth. but if this is a large tv , then the repair would be most likely worth it
Dec 29, 2008 | Televison & Video
Fuzzy picture on my 42" akai lcd tv
Check the menu ,,it should have a option ,,called convergenge ,,that realigns the colors,, and some tvs have geomagnetic correction,, good luck
Oct 05, 2008 | Akai LCT3201AD 32 in. LCD Television
Zenith TV- greenish color
If you take off the back of the TV there are additional tuning buttons. One is for the focus. I have a model SY2551S and have the green tint problem. Have you resolved that?
Aug 28, 2008 | Zenith C27A24T 27" TV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Sony Rear Projection TV Model # KP 53N74
I have had a similar issue with a Sony 52" circa 2001 tv. It was bad and then got better. The only problem now is that when I plug anything into the component 1-5 (but not 4) the screen is fuzzy. The DVD is plugged into 4 and it works fine. I tried plugging something else into that and it showed up in black and white. Very frustrating. Fancy TV if you only watch cable or a DVD. All other modes show up fuzzy. Sony recommended a tv repair place in St. Paul but they want around $400 just to look at it.
Sep 26, 2007 | Televison & Video
Picture is going fuzzy and blinking red light...
This is the classic symptom of a CRT (picture tube)that is starting do get weak. The picture takes longer and longer to come on, it appears greenish and blurry, and it blinks on and off in different scenes, and when it is off the timer LED blinks 5 times. Sony has a circuit called "IK Blanking" which monitors and adjusts the colors in the picture tube, and shuts the picture off when the tube is getting too weak. The good news is that the Sony tubes always respond beautifully to a CRT rejuvination (recharge), and the picture returns to perfect. Since the set is 36 inches and VERY heavy, it should be serviced in-house and an appropriate charge for a service call for your set should be around $150.
Jun 22, 2007 | Sony KV-36XBR400 36" TV
RCA HD52W59 HDTV Projection Television Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
