Question about Maytag Neptune FAV6800AW Top Load Washer
Fav5150aw1w maytag washing machine moving all over the floor
The machine moves all over the place even when the clothes are well spread out in the tub. It did not do this until recently.
  • 1 more comment
  • edwart Jan 14, 2008
    I don't know exactly, perhaps 4 years old. It performs like new otherwise. The model number is fav5150awiw.
    Thank you very much. I will try and let you know.
  • robert samples May 11, 2010
    how old is the unit
    President:
  • 1,314 Answers
First check the leveling legs and the feet make sure the rubber on the bottom of the leaveling legs are not worn through and there are locknuts on the legs make sure they are tight
Posted on Jan 14, 2008
Iv'e got a LG Top loader.WF-T755A. When it spins the drum shakes violently and move the washing machine around . It also makes a loud noise while doing it. What is wrong please?
The load is off balance. Instead of being evenly spread out along the drum, your laundry is bunched up on one side. Try smaller loads to allow the clothes to move more freely in the water.
Feb 11, 2017 | LG Washing Machines
I leveled my machine but t jumps badly
my answer it maybe not the answer you want !
watch if the clothes have made a bundle on one side ?
a washing-machine Too full stop the spreading the clothes evenly ,,
but if a front loading ,
the four rubber feet must touch the floor evenly ,
look for the two front rubber feet are level and push hard on the top to level the back legs automatically or adjust them manually !!
Oct 04, 2015 | Bosch Washing Machines
My maytag washer shake a end of rinse cycle.
After the rinse cycle, the washer rapidly spins the tub to get as much water out of the clothes as it can. It works basically the same way as a salad spinner. If the weight of the clothes in the washer is not balanced, the washer will shake and maybe even jump around during the spin cycle. This is pretty normal. If all of your jeans end up on one side, and your t-shirts on the other, the jeans will hold more water, their side of the tub will be heavier, and the washer will shake a lot during the spin cycle.
If the washer is shaking too much, open it after the rinse cycle (wait for the tub to stop before reaching in) and spread the clothes out evenly in the tub. Try to balance the weight. Then close the lid/door and let it continue spinning.
Mar 05, 2011 | Maytag Washing Machines
Roper model #RTW4440VQ2 drum off balance. Don't think that the washer itself is not level, when we try to wiggle the whole machine it doesn't move. So it's not the floor. The drum is "loose". ...
Try tipping it up and look underneath there should be some springs that hook to the base plate and to the tub to help keep it in position . 3 shorter ones and 1 longer on the back. If they are unhooked or broken it could cause this problem. Hope this helps.
Dec 05, 2010 | Whirlpool Washing Machines
Maytag walking
Hello. I have a few ideas for you.
1. Tilt the machine forward so the back feet are 3 to 4 inches (7.5 to 10 cm) off the ground, then set it back down. The back feet usually are self-leveling--just raising and lowering the machine like this will cause the feet to re-level themselves.
2. Place your level perpendicular to the front of the machine and check to see if the washer is level in this direction. If it is off, readjust each front foot by the same number of turns until you reach level.
3. Go to the carpet store and buy a remnamt which is the size of the washing machine lengthxwidth. Place this under the machine with the four legs all resting on the carpet.
Regards, Joe
PS please rate my answer. thank you.
Dec 20, 2009 | Maytag MAT13MN Top Load Washer
Washer shaking very bad
It's very likely your washer is out of balance. The load has shifted and is not evenly spread throughout the tub.
Stop the cycle, open the lid, move the items around so they are more evenly distributed and that should solve the problem.
Oct 27, 2009 | Maytag LSE7806A Top Load Stacked...
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
Leaking water
If it was moved with a dolley the dolley may have broken the water pump under the washer.
Mar 14, 2009 | Maytag Atlantis MAV8000
Admiral clothes washing machine AAV7000AW
Hello calmtouch,
You said,
When in spinning cycle, the barrel begins to move all over banging the washer across the floor. I don't even know what to look for.
Help.
sounds like the coupling connecting the tub to the transmission may be loose and throwing the wash tub out of rotation causing the banging and walking washer.
Bless You
Huuum
Sep 19, 2008 | Admiral AAV7000A
Maytag Neptune FAV6800AW Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
