Question about Frigidaire GLGF386DC Stainless Steel Gas Kitchen Range
Oven doesn't light right away
When the oven tries to light the element stays lite a long time. when it finally lites, there is a flsh fire in the oven, and the house fills with gas odor. i took the panels off to get to the burner, and tried turning on the oven, and it lit fine, put the panels back on and same problem. help
    Top Expert:
  • Frigidaire Master
  • 25,263 Answers
The air/gas mixture is wrong. Call a qualified gas engineer.
Posted on Jan 30, 2018
SOURCE: element light is on but no heat from the burners
You only have voltage coming in on one leg of the 240 line. Either the terminal block connectors are loose or burned or you need to check the circuit breaker in the house and reset it. It is also possible that one of the wires burned off in the back of the unit between the terminal block and the clock.
Posted on Jul 21, 2007
  • 7 Answers
SOURCE: How to lite a pilot lite on a frigidaire "Gallery" gas stove?
wet sparkers, let them dry out good
Posted on Jan 30, 2009
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Posted on Feb 26, 2009
  • 145 Answers
SOURCE: frigidaire Model fgfl79gsa EOC won't lite up
If it has 120 volts to the EOC, with a good line and nuetral, and it won't show the clock or turn the oven on it has to be replaced. Frigidaire doesn't offer repair parts for the EOC.
jim
Posted on Jul 28, 2009
heatman101
  • 43501 Answers
SOURCE: I have a frigidaire GAS stove. Oven doesn't work.
Even though the ignitor glows it does not mean that it is working...sounds crazy but it is true... the ignitor needs to pull a certain amperage to let the gas valve open and as they get older they stop pulling enough current...
Check out this tip I wrote about this problem...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Posted on Mar 05, 2010
My pilot light won't stay lite,replace thermopile and still doesn't stay lite.
Hi there.
Check for wiring errors, fix and tighten all wiring connections. Make sure that the gas pressure is correct.
Check the hi limit and gas valve, one of those component may be bad.
Regards.
Apr 18, 2013 | Cecilware FMP40 Deep Fryer
My oven pilot light will not stay on
you may need to replace thermocouple and re-try it....good luck.
Nov 06, 2012 | Southbend S560DD (Gas) Oven
Reliance 606 Hot water Heating element (Pilot light) won't stay lit
Gas water heaters don't have elements, so I am confused about what type water heater you have..
Look on the side of tank for the label.
Find the brand, and type. Does it show BTUs? Or does it show wattage?
Then re-post question with this information, for best possible answer.
Also post question on Tank forum.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Aug 12, 2012 | Water Heaters
I light the piuolot button and when i let go of the pilot button the pilot goes out does not light burner wont stay lit
When you light the pilot lite you have to hold the button down until it gets the element hot enough to stay lit. If you hold down the button and lite the pilot and let it go right away it will go out. What to do is hold down the button and lite the pilot and continue to hold the buttn down for about 45 seconds to a minute then let it up very slowly and you will see if it is going to go out by the flame getting smaller as you let up on the button. If it does start to get smaller conitnue to hold it again for a few seconds and repeat the process of letting it up slowly. when the control element gets to the right temperature it will stay lit then turn your valve to "ON" and the fire will start up and continue to heat the water.
Mar 15, 2011 | RELIANCE ELECTRIC WATER HEATER
Can't get pilot light to stay lite in oven
make sure the thermocouple is positioned above pilot light this part needs to be heated up by the pilot light to keep gas going to the pilot light. if the thermocouple is positioned above pilot light and it doesn't stay light, replace thermocouple.
Apr 04, 2010 | Stoves Premier 600GRa Gas Single Oven
Thermador Oven SMW272 will not self clean
You need a new control board on this unit. Once the self clean goes out, your oven will soon go out and you will not be able to cook. We have parts for Thermador ovens so please give us a call at 972-859-0929 and we will ship the part out to you right away. It's so much less expensive if you repair it yourself rather than calling a service company out. AND you will be ready for all your winter meals to be hot and delicious! We look forward to working with you and hope to hear from you soon.
Oct 04, 2009 | Thermador C302U Electric Double Oven
OVEN WON'T STAY LITE MOST OF TIME & DOESN'T HEAT WELL:
Most problems with gas ranges have to do with the flame—either it isn't quite right or it's nonexistent. Many new gas ranges have "electronic ignition," a spark igniter that starts the flame as gas flows through the burners f, when you turn on a burner, it fails to spark but you hear sparking at other burners, the igniter or the burner switch probably needs replacement by an appliance repairperson. If your range has a pilot light, be sure the pilot light is lit.
have nice time..!! arte the solution!!
Apr 17, 2009 | DCS 24-24G-1 Gas Kitchen Range
Oven will not light - get F1 code
Your touch pad or control board is bad.
To determine what is bad, disconnect the ribbon strip to the board.
If you receive a code replace the board.
If no code appears, replace the touch pad.
Jan 23, 2008 | Magic Chef CGR3742 Gas Kitchen Range
Frigidaire GLGF386DC Stainless Steel Gas Kitchen Range Logo
44 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
