Question about Mitsubishi VS-50605 50" Rear Projection Television
Virtical sync Picture lose sync intermiittently, but just at top of picture.
  • Mitsubishi Master
  • 8,617 Answers
1. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 . THIS IS A COMMON FAILURE FOR THE VZ-7 CHASSIS
Posted on Jan 26, 2008
Virtical lin
If the problem is with its picture linearity [Vertical], you have to enter its service mode to correct it. It is best to replace all the electrolytic capacitors [5 or 6] of it, at the vertical scan output circuit, before doing any adjustments, because, if there is any of it is damaged, the fault to this kind can occur too. After replacing it, just switch ON the set, and check the picture linearity is correct. If not, enter its service mode, and adjust the vertical picture linearity. If you wish to get some details, check the site linked here.Pull up older posts.
Dec 07, 2013 | JVC AV-27D302 27" TV
Top half of the picture is taken
Your shutter and mirror are out of sync.
Jul 17, 2010 | Canon Rebel XT / EOS 350D Digital Camera
53SDX20B Projector TV - No Picture
It was condesnation from moving the TV from the cold outdoors to the warm indoors. I let it warm up for about 2 hours and then it was fine.
Jan 11, 2010 | Hitachi Televison & Video
Intermittent collapse or rolling of TV picture
Look for dry joints very carefully in the vertical circuitry, IC and the power supply
Apr 07, 2009 | Televison & Video
Picture is squeued vertically from top to bottom.
check for dry joints around the main chassis,esp the supply lines .
Jan 05, 2009 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
Symphonic
if line is across screen thats virtical circuit prob. need tech or up and down horiz circuit. need tech
Nov 27, 2008 | Symphonic ST419E TV
Autiovox lcd Half the screen turns blue the other half has virtical lines in it.
Typical of the glue that holds the circuit to the screen coming loose.
it will take a very good repairman to fix this and he will have to know where to find the glue, its special with microbeads embedded.
Mar 03, 2008 | Televison & Video
Info to fix
Your right! Replace all the caps around/connected to, the vertical output IC. 100uf etc. Vertical IC is mounted on heat sink near yoke connector.
Oct 27, 2007 | Toshiba 19A26 19" TV
PROBLEMS WITH VERTICAL ROLL
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
Jun 28, 2007 | Sony KP-53S65 53" Rear Projection...
Have Virtical and horazonal lines ....Please help
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Mar 14, 2007 | Toshiba 57H81 57" Rear Projection...
Mitsubishi VS-50605 50" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
