Start the computer, continually press F7 during start up. Click on safemode then it will boot up in windows, click on start, then to control panel, then to add/remove users. Click on add new user, type in a good user name and set as adminisrader. Pick a new password or chose not to have one, then restart your comp. Click on your new user name, type password and hit start, control, add/remove usets and delete old account. Vua La!
In the menu with auto program OR direct enter channels with the remote and in the menu manually add them one at a time(most sets have a add or delete feature in menu for single channels).
Sorry about the problem you are encountering, you will have to uninstall the software from your computer, but before you do that, it will ask you for password during the un installation, so you will need to take the following steps; 1. goto my computer, open the hard disk 2. open the program files on the hard disk 3. Search for the name of the folder lock installation folder and delete it completely, make sure the folder lock application is not running or else you wont be able to delete it permanently. 4. goto the control panel, add and remove program, click on the folder lock icon and remove it completely. 5.click on the folder you secured, and try opening it.
You need to reset the password . Feature 983 enter 1020000 as the password if you have a 3 digit extension number or enter 120000 if you have a 2 digit extension next press the button under the screen with the heading of m box or mail box next your options are add delete or change press change . next enter mail box number the next step will be to press the reset button after re-setting the password press the release button . Now open your mail box and enter the default password 0000
try the Funai codes look on the back of your tv and see if Funai made it if so try ther codes. My Magnavox converter box wont pick up chanel 10 here for some reasion says no signal.works ok on all of the other chanels. Now if you have the orginal remote you should be able to go into the menu and go to add/delet and add that chanel to the scan if it has been deleted for some reasion.
Probably, at first you searched the programs in automatic way. And there were only 20 channels at that time. So, you only have 20 channels. You should try to search channel 21, 22, 23, etc, manually. If you can't set 21 on your program, then your tv set has only 20 programs.
