Question about GoVideo VR3845 DVD Recorder/VCR
Error message:- "Unknown Disc, please check again."
I always encounter this error message: "Unknown Disc, please check again." after I finish recording on some DVD-R disc. This does not happen on all discs but on selected ones only. What shld I do???
  • 4102 Answers
SOURCE: dvd player will not read disk
have you tried getting a lense cleaner as they sometimes get alot of dust and will stop signal from disk to the laser if this dont solve the prolbem then you are looking at replacing the laser unit itself if the cleaning dont work and you think you are capable of taking the casing off make sure you switch it off first this should send the laser to the center of the laser tray if you take the case off and it is not in the center it might just be that it has got jammed now sometimes gently pushing it back to the middle will get it working again if it is already in the middle then it could be that the laser needs replacing but if not in middle push gently dont gerk it it should be quite stiff to push any way when you push back to middle try a disk with the casing off but please make sure you dont touch anything whislt it is plugged in if nothing works then it probably is the laser but before you do anything as soon as you get the case off switch it on and put a dvd in and make sure the disk is spinning if not laser unit is nakered and need replacing let me know how you get on hope this is some help to you
Posted on Nov 26, 2007
  • 1003 Answers
SOURCE: DVD Recorder/Player won't accept DVDs
I think your Laser Lens or drive needs to be cleaned
Posted on Jan 14, 2008
  • 1003 Answers
SOURCE: dvd movie or recordable dvd won't work
YOUR LASER LENS MAY need cleaning
  • 4 Answers
SOURCE: go video dvd recorder vhs combo vr3845 - won't read discs - says unknown disc
FIRST UNPLUG THE UNIT FROM POWER !!!!! The problem is dirt/dust/****/crud/stuff on the tiny, little ***** laser lens. Remove the case screws ( 2 on each side, some in the back) with a correct size driver. The cover must be pulled open at the bottom, side to side a tiny bit ( use a hand on each side) to allow the cover to lift up at the rear, it must come up quite a bit as if it is hinged at the front and THEN pulled back out of the front panel. Set the cover to the side. The DVD reader/Burner is covered with a small black cover, it is held on with two TINY screws, STOP!!!! Get yourself the CORRECT size driver at Fry's or Radio Shack, DO NOT get cheap here!!! Remove the two screws and find the two plastic grip tabs, push them to release and lift the cover. There is the laser! It is a tiny blue lens about the same diameter as the tiny screws. find a very, very well washed CLEAN 100% cotton T-shirt. The softer the better, get 70% or higher rubbing alcohol, pull the fabric over the tip of the finger and wet with the alcohol. VERY GENTLY wipe the lens 4 to 5 wipes and the 3 wipes with a dry spot. That should clean the lens. USE NOTHING ELSE!!!!!! The lens tracks back and forth on two tiny bars. The stuff I use is WD-40 wet on a Q-tip swab. Go to a safe place to spray the WD-40 on the Q-tip. The lube should drip. With the Q-tip apply the lube to the tiny bars at the ponts of rider contacts and wipe the bars too. Put the top of the burner back> BE CAREFUL!! Use a magnet driver and then repower and try to read a known good dvd. You will have to do this more in the future, you understand, dist dirt etc in the air. Put the top back on. Enjoy.
Posted on Sep 26, 2008
  • 19396 Answers
SOURCE: My daughters GoVideo DVD player always says CHECK DISC!
If no disk is detected it means that the lens are dirty or defective.
If the lens cleaner disk, or using Qtips and alcohol did not work, then the lens pickup or the disk drive must be replaced. this involves precision soldering and must be done by a technician. Regards.
Posted on Jul 04, 2009
  • 3 Answers
SOURCE: New R6530 put DVD+R disc in shows no disc
you can only use imation or verbatim DVD+R. No other DVD's will work. I use exclusively the IMATION DVD's. Easily recognized by the logo on the disc package, it looks like the old movie reels.
Posted on Feb 17, 2011
0 characters
1 Points
Returns error message :Unknown Disc. Please Check Disc Again" The DVD disc plays on other DVD players with no problem.
Problem may be reset needed, or lens need cleaning, or dvd recoreder worn out. Reset is pull the plug from the wall for 5 minutes. Turn it back on after reset to load firmware again, may work after that.. TDK makes lens cleaner. LG uses fan so, dirt can get into dvd recorder lens. If the tray moves out wiggly, laser assembly may move wiggly too. Replace dvd recorder which is a dvd+-rw regular ide unit from computers.
Aug 20, 2010 | LG RC-197 DVD Recorder/VCR
LG DR389 "Unknown Disc. Please check disc again"
my lg dvd model dr389 displays PRO1 please solve my problem
Dec 18, 2009 | LG DR275 Recorder
"no disc" error message
Try unplugging the unit, then remove the cover. Take a cotton swab, wet one end with glass cleaner, and clean the lens on the laser assembly. Use the other end to dry it off and finish cleaning. Wipe very gently, do not press down hard on the lens.
This problem is usually (not always) caused by dust and smog accumulating on the lens, preventing the laser from reading the disc. Symptoms are skipping, spinning and not reading, or "no disc" errors.
Feb 28, 2009 | Sony DVP-S560D
LG RH289H DVD Recorder Unknown Disc. Please check disc again.
I have had the same problem a few times. All I do is eject and re-insert the disk until it recognises it, this seemed to work for me
Jun 04, 2008 | LG RH177 DVD Recorder/HDD Recorder
I also have this annoying problem - but I bought mine new on ebay and have zero after-sales support. I have tried all the hacks I cna find over the last 12 months and when I am finished, the messages all say 'congratulations, you're now region free'. But even the local DVDs don't work. Disc ejects itself with irritating message 'unknown disc'. Does anyone have this problem who has a SALES RECEIPT from an authorised LG dealer? If so, can you jump up and down with LG until they offer a solution? Thanks!
Mar 17, 2008 | LG DVD & Blu-Ray Players
Disc Error message
Mar 17, 2008 | Sony RDR-GX300 DVD Recorder
Dvd won't play
sounds like microprcessor board failure the best thing to do is get a new unit
Nov 27, 2007 | Insignia IS-DVD1001 DVD Recorder/VCR
Unknown disc error
In my dvdr630vr plays only audio cd`s. Same problem?
Oct 28, 2007 | Philips DVDR630VR DVD Recorder/VCR
Unknown disc error message
Aug 27, 2007 | DVD & Blu-Ray Players
GoVideo VR3845 DVD Recorder/VCR Logo
27 people viewed this question
Top GoVideo DVD & Blu-Ray Players Experts
Jaime Hernandez
Are you a GoVideo DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
