Question about Hotpoint RGB745 Gas Kitchen Range
OVen doesn't Heat
The oven light comes on, but doesn't heat. The broiler works fine, however.
Tried to find a pilot, but nil. If there is a bulb needing replacing, where is it and how to access it? Please help
  • 1 more comment
  • BakeACake Jan 14, 2008
    Thank you! that was fast!
    The model no. is RBG745wea3ww.
    If it is a fairly simple repair, I would like to try to make the repair myself. Thanks!
  • chelino Mar 13, 2008
    I have the same problem, oven doesn't work, but the broiler and stove tops do. My model # RGB745BEA6WH and I want to make sure that I have the right part number.
  • Anonymous Mar 13, 2014
    Light Lonnie consul comes on it click likely going to heat up a broiler does not work either
  • 5,911 Answers
More than likely, you have a bad igniter for the bake manifold. Since the gas range has a separate ignitor for the broiler, this explains why the broiler works and the bake function does not. Since most consumers tend to bake more often than broil, the bake ignitors go bad more frequently. There are a couple of different ignitor types listed for your range. I will need an EXACT model number (located somewhere around the oven door opening) before I would be able to give you a correct part number. The ignitor price varies between $52 - $64. If you wish to make the repairs yourself, I can give step by step instructions. Please post back with your information and I will be able to assist you further.
Posted on Jan 14, 2008
  • Jeff Rockwell
    Jeff Rockwell Jan 15, 2008
    The part number is 1990 and runs $64.55 at repairclinic.com. If you order on line they will ship the part directly to you. There will also be a shipping fee to add. I am not trying to promote the website, but I have personally used their service over the years and have never been disappointed. They use the identical same parts as your major appliance repair companies, but charge a lot less.
    Your stove uses a glow bar type igniter. When you turn the stove on the preheat, the igniter begins to glow. When the igniter reaches a certain current potential, the gas valve opens, gas begins to flow and voila!, you have ignition. Now...your old igniter may still glow, but the gas valve won't open. This is a typical symptom of an igniter that has become weak. If the current potential is not reached the gas valve remains closed. This is a safety feature that prevents gas from free flowing into your home with no ignition.
    Now to get to the igniter perform the following steps:
    1. Unplug the stove from the main power.
    2. Open oven door and remove oven racks.
    3. Remove the lower drip pan. There should be a couple of screws holding it in place.
    4. Once the screws are removed the drip pan should slide back a bit then lift out.
    5. The igniter is mounted directly on the gas manifold. There are a couple of 1/4" (I think that's the size) screws holding it in place with two white heat resistant leads connected to it.
    6. You may have to remove the drawer under the oven door to access the connector plug where the igniter plugs in. If there are no plugs, or if the plug is the wrong type, there are a couple of ceramic heat resistance wire lugs included with the install kit to connect the leads. You will have to cut the wires and use the wire lugs.
    7. Now, sometimes removing the gas manifold makes it easier to install the new igniter, so you aren't leaning inside the oven door for a long period of time. The manifold comes out by removing (usually) one screw located near the front of the manifold and lifting the entire assembly up through the bottom of the oven. The manifold simply plugs into the gas line below the oven just after the regulator in most models.
    If you feel this is something you would like to tackle on your own it is very simple if you follow the instructions given. If you have any problems or have any more questions just let me know.
    PS Use care not to put your weight on the oven door while it is open. You may damage the hinges. Just a reminder, make sure the range is UNPLUGGED.
This solution was very helpful to me! I would only add that if you search ebay for "Hotpoint Gas Range Oven Igniter", you will find a seller called Midwest Appliance Parts that sells them for $30 plus shipping. Their part number for these things is WB2X9154 instead of 1990, but it's the same item. I just installed it and it works great.
Posted on Feb 24, 2008
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
My oven doesn't heat up
It could be the switch or heating element
Mar 17, 2013 | Thermador SM272 Electric Double Oven
I have a Hardwick propane stove, 4 burners and oven. The stovetop burners work fine (need a match), but now the oven does not ignite despite the pilot light working fine. I have brushed the pilot light...
Hello Patrick,
WHen you turn on the oven/broiler does the size of the polot ligh increase in size??
the way it is suppose to work is...thier a small free standing polot light and when ya turn on the oven the size of the pilot is suppose to increase and heat a little bulb that is connected to a wire that is mounted to the pilot burner and when that bulb heats up it will allow the main gas to flow into the oven(not pilot burner).
If the size of the pilot does not increase it could be caused by a clogged pilot burner. the way to determine that is TURN OFF GAS SUPPLY...disconnect gas line from pilot burner and turn on gas to unit, light that tube with it disconnected from pilot burner and turn oven on and see if size of flame drastically increases...if it does turn gas off and remove and replace pilot burner
if flame sizedoes not increase the problem is going to be the thermostat
If the pilot does increase and heats the bulb on the pilot burner the problem will be with the gas valve that,that bulb in the pilot burner accathes to is bad .
now chances of the thersostat still being available is very slim if the pilot burner is clogged and needs replaced they are still available their is 2 of them one has the mounting plate on the left and one is on the right.
here is what they look like
oldtech2332_148.jpgPart number for this one is 1898-021 notice how the mounting tab is on the right
oldtech2332_149.jpgthis one is pt# 1898-022 the tab is on the left
That when performing a quick search on google is pretty much all that still available teh thermostat (would need model number) is doubtful to find also a good chance the gas valve is also no longer available
Good luck,
GENE
Oct 27, 2011 | Kitchen Ranges
The pilot light on the oven is on how ever the burner will not come on when the oven is turned up.
Their is 2 possible things that are causing the oven to not heat.
1) the pilot burner is clogged with build up and not burning corretly...the standing pitol light is small and when the oven is turned on the pilot enlarges and heats a small bulb connected to a tube on a gas valve,if the pilot burner is clogged it will burn the small pilot but will not enlarge to heat that bulb so the gas will flow to the main burner.If that is whats happening the pilot burner needs to be replaced.
2) the pilot burner is properly heating the bulb connected to the above mentioned gas valve but that gas valve is bad and not opening once the pilot has heated the bulb..so in that case that gas valve would need to be replaced
GENE
Sep 17, 2011 | Premiere Ranges GCK100 Gas Kitchen Range
Our 17year old GE gas oven/broiler stopped lighting today. What might be the problem? Stove burners work.
Most likely culprit is the igniter.
When you turn the oven on it opens a gas valve allowing a small amount of gas to flow thru the pilot light. The igniter then lights the pilot and when the sensor determines the pilot is lit it opens th emain gas valve and the oven lights. If the igniter fails and doesn't light the pilot the sensor doesn't heat up and it shuts down the pilot and nothing works.
The igniter is usually accessable under the oven by removing the drawer. It has a single wire attached and looks like a short cigarette made of ceramic witha metal tip.
You didn't provide model number so I can't give you part number but if you look it up here you may be able to get one from Sears
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
May 18, 2011 | Ovens
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
Was preheating oven, while cooking on stove stop. heard a puff sound open up oven thought it was on but it never heated up. the electric light comes on but does not ignite. the broiler does the same. ...
Gas ovens are fitted with at least one safety device and it could be it has failed.
The safety device is bypassed while the pilot light is lit. The pilot light heats a thermocouple bulb which switches the gas on to the burner. As long as the pilot light continues to heat the bulb gas will continue to flow - until the thermocouple fails, they aren't long-lasting...
Feb 03, 2018 | Hotpoint 30" Self-Cleaning Freestanding...
My GE JGBP32GEL Gas oven will not light. Electric pilot does not glow. Broiler work fine.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 07, 2010 | GE Ovens
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Hotpoint RGB745 Gas Kitchen Range Logo
    603 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Sal De
    Justin Duby
    Justin Duby
    Ismael Rodriguez...
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
