Question about LG WM2688H Front Load Washer
New LG WM2688H*M Steam Washer
We just hooked up our new washer and leveled it on the pedestals and when it goes into spin cycle it starts vibrating and taking off like a jet plane really loud. We made sure it was still level and it keeps doing it! Any ideas?
  • Anonymous Mar 31, 2008
    LG front load washer:
    We have had a tech out, over severe vibration problems. There is no reason any manufacturer should make a washer that should only be installed on main floor. We were told by the LG tech that this washer is mainly made for that. The reason it does vibrate so much is that the motor is 1200rpm. Regular top load washers are abou half that. He informed us that because of the 1200 rpm, it should not be used on second floor applications. It vibrates my pics off the wall in the laundry room. We bought the laundry soap that sits on the top of the washer and pours right into the cup. That bounced around so bad that it scratched the whole top of my brand new washer and it looks like ****.
    This whole thing is ridiculous, especially after i paid 2000.00 for the set. I am trying to reach the manufacturer to see if they will return the money and take thier equipment or give me a credit so I can buy a regular top load and have peace back again. We will see how honorable they are. I will keep you posted. Anyone needing to chat about this can email me at [email protected]
    Problem Solver:
  • 14 Answers
Your load is unbalanced, at least that is what is sounds like. Have you taken out all the shipping bolts?
These washers and dryers hold very little clothing, 3-4 pair of jeans or less if the person is really large and maybe three regular sized thick bath towels since they weight so much when wet. You must make sure you are not overloading your machines when in use.
Good luck and if you keep having problems I would take a look at the manual and call customer service to report this issue to them. Make sure you get a repair number for your records.
Posted on Jan 14, 2008
6ya staff
SOURCE:
Makes noise in spin cycle and now it started smoking. Tub seems to spin more easy but i don't hear anything like a bearing.
LG WM2688H Front Load Washer Smoking power ... - Fixya
www.fixya.com > ... > LG > WM > LG WM2688H Front Load Washer
LG WM2688H Front Load Washer, smoking power related issues. ... is it worth trying to fix drum loud and rattles when on spin cycle, then smoke started pouring out of ...hi working till smoke came out the back and now no power - Unplug it. ... washer makenoise doing spin cycle smell smoke make the power cord warm to ...
LG 4280FR4048L Bearing - AppliancePartsPros.com
www.appliancepartspros.com > ... > Washer > Kenmore Washer Parts
Rating: 5 - ‎189 reviews - ‎$32.19
Burnt rubber smell at end of cycle from 11 yr old lg wm2277hw front load washer i hand spun inner drum it was ... Appliance: LG Washer WM2277HW ... Our LG "Tromm"washer (a.k.a. "Trommy Baby") started making a horrible ... The bearings were worn and made very loud noise in the spin cycle John A. • Punta Gorda, FL.
LG WM2455HW washing machine problem - YouTube
? 10:29
https://www.youtube.com/watch?v=__abhTwmi1I
Sep 15, 2010 - Uploaded by djmcarter
I also have an LG refrigerator, which makes a loud sound (it's the.... I am watching your video while mopping up water underneath the exact same machine right now. ... How to Fix an LG Front load washer machine that wont spin - Duration: 5:32. ...
Jan 19, 2016 | LG WM2277H Front Load Washer
LG washing machine WM2277H tub off center does not spin electronically, manually its spins but rubs sides
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Sep 02, 2010 | LG WM2277H Front Load Washer
My LG WM2233HW vibrates and crawls forward during the spin cycle, it is not on a pedestal, does anyone nkow if the pedestal will stop this?
Not sure what pedestal you refer to ,but vibration and movement is often caused by machine not being level / not stable initially . With machine off ,hold the top firmly and see if you can rock it in any direction , if you can , put some packing under the base to stop this , then operate machine , it should be better.
Nov 03, 2009 | LG WM-2277HW Front Load Washer
Wm 2487H. My machine is off balance and shake the house terribly bad. It also has a metalic scraping sound sometimes when the drum spins. I just purchased my LG washer and dryer a couple of months ago. I...
Starting in November 2008--LG introduced "square door" model washers.
These washers will (unlike round door models) perform very well on wood floors.
If the WM2487 washer is on a wood floor--even a tiled wood floor--it will be near impossible to get smooth spin performance.
Some homeowners have had success by adding two layers of 3/4 inch wood under the washer AND dryer.
The following steps were taken:
1) Remove washer & dryer
2) Cut & remove any floor covering (bare wood)
3) Locate floor joists with a stud-finder & mark locations at the edge of the flooring--allows finding the joist locations after 3/4 sheet is laid to floor.
4) Add wood glue to floor
5) Place 3/4 inch wood sheet to floor & drive screws thru wood into joists (as many scews as deemed necessary to fully & completely compress wood sheet to existing floor
6) Add wood glue to 1st wood sheet
7) Place 2nd 3/4 inch wood sheet on top of 1st wood layer and drive screws into floor joists.
8) Add molding if desired
9) Re-install washer & dryer and level.
10) Add one heavy towel into washer tub & close door ( this will mimick an off-center load)
11) Press power "on" button
12) Press "Spin Speed" button & select high speed spin option
13) Press "Start" button
14) When * 9 minutes remaining * is displayed--use the flat wrenchette that comes with every LG washer to "tweak" the adjustment of the front leveling legs. This will allow for "fine tuning" adjustment of the front leveling leg(s) to eliminate vibration / noise during the spin cycle. The rear leveling legs DO NOT need further adjustment.
NOTE: Those with pedestals--check the front leveling legs on the washer and on the pedestals (front only) during spin.
Jul 16, 2009 | LG WM2487H Front Load Washer
LG washer vibration
My wife and I originally had the same problem, and it didn't help that the washroom was a slick tile floor. First add as much weight as possible to your pedestal. We have ours full of detergents, bleach, fabric softener, etc., and have several of each so that the pedestal is completely full. When mounted on the pedestal, the washer is quite top-heavy, and the added weight in the bottom helped immensely. Second, make sure your washer is level, both the feet resting on the pedestal and the feet of the pedestal itself, and tighten the secondary rings so the feet don't vibrate out of place. Last, I purchased some thin rubber padding (approximately the thickness of leather) from Home Depot in the carpet aisle. Cut some small squares and place one under each foot of the pedestal. This gives the feet some additional "grabbing power" on slick floors.
Feb 16, 2009 | LG WM-2277HW Front Load Washer
Steam cycle runs on every setting
The steam will only run on certain cycles. If you look at your dial you will see a pink line which indicates which one. Your unit does have a recirculatting pump, maybe you are confusing the two. One way to check is to run a delicate cycle. During the operation press the wash/rinse and soil level buttons together. Hold them, a display will pop up with readings in the second coloumn, and second row it will display the tempurature of the steam generator in ceilsus. This will confirm whether or not it is on.
Sgt. 48
May 29, 2008 | LG WM2688H Front Load Washer
L g steam washer front load
The model you have this listed under WM2688H (LG Steam Washer) a E1 Code Correct water level (246) is not reached within 8 minutes
after water is supplied or it does not reach the preset water
level within 25 minutes.
I suggest you
Check the screens in the water inlet valve for blockage
Feb 18, 2008 | LG WM2688H Front Load Washer
Walking during the spin cycle
Is your floor level, first thing. Okay, the rear 2 legs are not adjustable so leave it. The front 2 legs should be screwed up (ie the machine should be at the lowest level in front) and there are check nuts to tighten inside the body of the machine. Check the machine it it rocks by using your hand against it. Adjust accordingly, this is if your floor is not too good. You shd not hv any problem. If the rocking persists check inside machine, behind after getting he plug off wall, maybe shockabsorbers hv come off, springs?.....
and rate me please if helped.............
Jan 12, 2008 | LG WM2277H Front Load Washer
Lg washing machine pedistals
You will have to have the washer lifted to screw the leg back into the bottom. As far as the shaking...try some vibration isolation pads. www.keshakeaway.com the best $30 i have ever spent.I have a front loader on a pedestal also..it vibrated the pictures of the wall in the next room. with the pads I hardly know its running.( and the drawer stays shut)
Nov 10, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Vibration
just because the level shows it is doesn't mean it really is. check the pedestal first. make sure it is level and all legs are tight and there is no wiggle. next do the same for the machine once it is put back on the base.
Sep 18, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM2688H Front Load Washer Logo
599 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
