Question about Canon ZR200 Mini DV Digital Camcorder
Problem tape in the receptacle
Every time I put the casette tape in and shut the receptacle, it immediately beeps and reopens the slot. It will however close and retract if there is no tape in the receptacle
  • Hiroito camachu Jan 24, 2008
    Every time I put the casette tape in and shut the receptacle, it immediately beeps and reopens the slot. It will however close and retract if there is no tape in the receptacle.
I found other entry in this forum about the same problem. Could not believe the solution, but worked for me and other 30+ folks...
A couple of gentle slaps on the side (not the one of the screen), made it work again...
I had nothing to loose since it was out of warranty, so I tried and worked on mine as well...
Good luck
Posted on Jan 27, 2008
6ya staff
SOURCE:
Car casette player won't accept cassettes. I put a cassette in and it spits it right back out.
Your casette player must have something lodged in it that's why it spits the casette tape back out. If you are able to, try dislodging the player from your dashboard. Shake it and if there's something noisy inside, chances are that's your culprit. Try to get it out by shaking the player while keeping the casette tape door open - like getting coins from a piggy bank. :)
Hope this helps!
Fix14
Jun 16, 2010 | Car Audio & Video
How do I dub casette to casette? I lost the manual.
There should be a DUB button. After you push the DUB button, you will have another button that will allow you to select Dub form 1-2 or 2-1. If not there will only be one deck that will play while the other records and plays. Put the tape to be coppied in the play deck and the blank tape in the record deck push record and it should work.
Dec 11, 2009 | Denon DRW-585 Single Cassette Deck
Remove tape error message
I used my hairdryer to blow dust out of the cassette compartment. It worked for me.
May 05, 2009 | Canon Optura 20 Mini DV Digital Camcorder
Casette problems
To blank the whole tape, put the lens cap on the camera, then run the whole tape through on "record." Presto, blank tape.
I load my whole tape into a video editing program on my computer and delete the parts I don't want from the program.
Jan 06, 2009 | Sony Handycam DCR-DVD105 DVD Camcorder
Reinsert casette tape
I suggest to clean tape head directly w/ QTIPS and the solution to clean video heads , clean and try again , thanks AJ
May 03, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Will Not Load Tape
thanks! I tried everything and nothing worked. I smacked it a few times and it worked like a charm! Thanks!
Oct 30, 2007 | Canon ZR200 Mini DV Digital Camcorder
Will Not Load Cassette
I have the zr850 which I have used less than a dozen times, and it does the same thing as you describe. Was told by canon tech people to try a maxell brand tape and a head cleaner tape. Have not tried their sugestion yet. camera is 3 months old.
Aug 07, 2006 | Canon ZR70MC Mini DV Digital Camcorder
Put tape in new video cassette
TAKING A GOOD QUALITY TAPE FROM ONE CASETTE AND MOVE TO ANOTHER WITHOUT HARMING THE TAPE QUALITY: TAKE A NEW, GOOD CASETTE AND UNSCREW THE 5 SCREWS HOLDING THE TWO PARTS OF THE CASETTE TOGETHER. AT THIS POINT DO NOT OPEN THE CASETTE. TURN THE CASETTE UPSIDE DOWN (SO THAT THE SIDE WHERE THE SCREWS CAME OUT IS NOW SITTING DOWNWARDS ON A FLAT SURFACE) IF YOU OPEN THE CASETTE BEFORE TURNING IT UPSIDE DOWN, ALL KINDS OF SMALL PIECES WILL FALL OUT AND YOU WILL NOT KNOW WHERE THEY CAME FROM. NOW GENTLY SEPARATE THE TWO PARTS OF THE CASETTE AND PAY ATTENTION TO EXACTLY WHERE THE TAPE RUNS THROUGH VARIOUS SPINDLES, ETC. MAKE A SKETCH IF THIS WILL HELP YOU. GENTLY LIFT OUT THE TAPE AND REPLACE IT WITH THE TAPE THAT WAS IN THE BROKEN CASETTE. THIS IS ASSUMING THAT THE ONLY DAMAGE WAS TO THE CASETTE ITSELF AND NOT THE TAPE. REPLACE THE TOP PART OF THE CASETTE (WITH THE SCREW HOLDS STILL FACING DOWNWARDS). HOLDING THE TWO PIECES OF THE CASETTE TIGHTLY TOGETHER, TURN IT OVER AND REPLACE THE SCREWS. TRY NOT TO HANDLE THE TAPE ITSELF. I HAVE USED RIGHT FITTING SURGEON'S GLOVES WHILE DOING THIS, BUT REALLY DON'T KNOW IF THEY HELP, BUT THEY DO KEEP THE NATURAL OILS OF THE FINGERS OFF THE TAPE.
Feb 26, 2006 | JVC HR-J461MS VHS VCR
Canon ZR200 Mini DV Digital Camcorder Logo
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
