Question about Western Digital Caviar (WD307AA) 30.7 GB Hard Drive
Formated Hard drive from Ebay
I won a hard drive on eBay. A Western Digital WD Caviar 307AA
After install and power up. Beep Beep No drive detected. Several jumper settings later. I talked to my friend. Who gave some WD Hard drive software. I can not get the software to pull up on a blank hard drive. So I tried to slave it to another hard drive. Several jumper settings later. I grumbled and contacted you.
Thank you, G.
    Brigadier General:
  • 6,966 Answers
Apparently you have tried most if not all of the basic install procedures.
If and when you connected it as a secondary or slave to a working/booting PC, was it auto detected at the CMOS/BIOS stage? If yes, then perhaps it is a partitioning/formatiing issue, if not then chances are that it is a hardware problem and the drive is dead.
Alternately, you can try using an external SATA/IDE Interface to USB such as a VANTEC CB-ISATAU2 SATA/IDE to USB 2.0 Adapter or any comparable product. This would provide the SATA/IDE connections to your new hard drive as well as a USB cord to your PC's USB port.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Posted on Jan 14, 2008
  • Louie  Role
    Louie Role Jan 14, 2008
    Hi again,
    Of course I am assuming that you have verified that the cable and power cords are OK and connected securely.
    Cheers.
What jumpers are for slave Western Digital WD Caviar Blue WD3200AAJS - hard drive - 320 GB - SATA-300 SATA
SATA drives don't need jumpers. Just install the drive and the computer will assign a drive letter.
Jun 06, 2012 | Western Digital WD Caviar Blue WD3200AAJS...
I looking for a pcb boad for hd western digital wd2500 caviar se
You should be able to find one here http://www.hdd-parts.com/wd-caviar-se.html
Jul 16, 2011 | Western Digital Caviar SE WD2500JB 250 GB...
I bought a Western Digital Caviar 1TB SATAII 64MB Cache 3.5-inch Green Internal Hard Drive OEM and I am trying to get it to work on a SHARKOON QuickPort Combo for SATA HDD - but my vista laptop...
the problem is with compatibility with Quickport combo ,cache of this is upto 8mb while that of WD disk is 64mb power is not sufficient to handle it so try a quickport pro
Jul 02, 2011 | Western Digital WD Caviar Green WD10EARS...
Hi, I want to know how to install the WD10EARS-00Y5B1 drivers? Okay, the problem is, that my computer doesn't recognise my SATA Hard Disk. I have Windows 7 Home Premium, and another SATA Hard Drive. I...
there are no drivers required for a hard drive.
Windows 7 should automatically detect the new hard drive and it should show up in disk management to format or prompt you to format.
Check your cable connections again.
Otherwise your new hard drive may be DOA. Return it to the store that you purchased from.
Mar 26, 2011 | Western Digital WD Caviar Green WD10EARS -...
My western digital wd2500jd does not get detected
try detect it from BIOS
if its not detected mean your western digital wd2500jd controller is need to be replace.
try ebay to buy its replacement.
just seacrh with keyword "western digital wd2500jd mainboard"
Mar 07, 2011 | Western Digital Caviar SE WD2500JD...
My wd hard drive is not detecting. i want to data backup.
Only solution for that is to try to make that WD HD to be ur SLAVE! So that u could get the DATA u wanted!
Nov 29, 2010 | Western Digital Caviar SE WD800JD SATA...
I just bought a hard drive from ebay as a second drive its a western digital 250gb ide drive but my pc will not recognise it as a storage device but it installed the drivers! what am i doing wrong?
Hi:
often when you install a IDE driv ne that is as big as yours, you often need to run the WD installation software first. The easy way is to go to the WD website and download WD Data lifeguard tools program. you can try running it with that drive as a slave, or you can just install your new drive by itself, and go from there
Nov 18, 2009 | Western Digital WD2500SD Caviar RE EIDE...
I want to make an internal western digital 160GB drive from my imac g5 20" into an external drive and need to figure out what enclosure and cables i will need
You need the following
http://cgi.ebay.co.uk/External-USB-2-0-2-5-SATA-HDD-Hard-Disk-Case-Enclosure_W0QQitemZ320419271720QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item4a9a7a1428&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/3-5-IDE-Aluminum-Hard-Drive-HDD-HD-External-Enclosure_W0QQitemZ400070866376QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item5d2614f5c8&_trksid=p3286.c0.m14
http://cgi.ebay.co.uk/New-3-5-USB-2-0-External-Hard-Drive-Case-HDD-Enclosure_W0QQitemZ170377549189QQcmdZViewItemQQptZUK_Collectables_HardDriveEnclosures_RL?hash=item27ab4b1585&_trksid=p3286.c0.m14
Please note the links are an example only.
Sep 02, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
New Hd HELP
I guess there is nothing with BIOS since it identify your Western Digital Caviar Hard Drive. Try changing the jumper setting of this Hard Drive by reading the Instruction that comes along when you purchase. Otherwise you can visit the Western Digital website and click on Support-Knowledge BASE...http://www.wdc.com
Apr 08, 2007 | Western Digital Caviar SE WD2500JS...
Western Digital Caviar (WD307AA) 30.7 GB Hard Drive Logo
215 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
