Question about Toshiba Satellite A105-S2717 (PSAA0U01Q003) PC Notebook
Laptop would power off after 10 minutes....
My laptop would power off after about 10 minutes, so I read that I should try to blow out any dust from heat sink area. Took laptop apart, and blew air inside, put back together and now screen is blank. It powers on, and seems to be booting up, but totally black screen. Hooked up to external monitor, which works. Any suggestions?
  • 83 Answers
Open it bk up u may have knock any wires or links to the screen ps dont open laptops unless u no what u are doing
Posted on Jan 14, 2008
My laptop freezes completely and then shows multi colored screen and does not swict off thereafter
To shut it off press and hold the power button for ~10 seconds. It sounds like your computer is overheating. if you have compressed air, blow out the fan vent, if you do not you can carefully try to blow out any caught dust.
Nov 22, 2012 | Computers & Internet
Tip
Basic Laptop and Desktop PC preventive mainance tip.
I strongly believe the #1 issue 'other than physical damage' that causes issues with laptops and desktop PC's is not keeping them cleaned and blown out of dust/debris. Just like changing the oil on a vehicle regularly greatly increases the life of an engine. Many issues with PC's can be so avoidable by a less than $5.00 'non flammable' can of air. Desktops are worse than laptops of course since they reside of desk cabinets or on the floor. It takes less than 10 minutes and even less time for a laptop to 'power the PC down, remove the power cord' and then blow out the power supply and its fan or on a laptop 'usually the back or side of the unit' where it's pulling in the cool air. If you have the courage to pull the cover off the desktop, 'again remove power' you will see the build up of dust inside the cabinet. Blow all this dust out if you can and this will help increase the longevity of your laptop or PC. Think of it as an oil change for your PC.
Blessings always,
A/V Media Tech Guy
on Dec 03, 2009 | Computers & Internet
Acer guet hot end shut down en 10 minuts
Three reasons laptops get hot:
1) Dust - Dust inside the laptop, dust clogging the vents and fans, dust around the cpu and heatsink. Remedy - take laptop apart and use a can of compressed air to blow out the dust.
2) A Fan not working - Listen and see if your fan is working, Air should be pulled in through the vents. Remedy - take laptop apart and replace the fan.
3) The Thermal Paste around the CPU and Heatsink has either dried up or is too thin to keep the unit cool. Remedy - Take the laptop apart and put a fresh coat of Thermal Paste around the CPU and HeatSink.
You could purchase a Laptop Cooling Pad that the laptop sits on and it plugs into the usb ports to keep the laptop cool. Try Tiger Direct at:
http://www.tigerdirect.com
When the site comes up just type: Laptop Cooling Pad in the white search box at the top and click GO. Sort the returned results by Price Low to High.
Below is a link to one that I use when someone can't afford the expense or have the time to take the laptop apart. It costs $12.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1879782&CatId=3486
Jun 02, 2012 | Computers & Internet
Laptop shuts off afer 5 minutes
Sounds like your laptop might be overheating. Does it reboot successfully immediately after is shuts down after 5 minutes or does it have to sit awhile before it reboots successfully?
If you can't boot it right back up after it shuts down, then it is definitely running hot and will only boot back up successfully after it sits awhile to cool off.
Things that cause it to run hot:
1) Dust... Dust clogged in the vents, fans and around the cpu and heat sink.
2) A Fan is not working
3) The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool.
For the best results you'll have to take the laptop apart to remedy the situation especially if you need to get to the Fan, CPU or Heat Sink.
You can try a can of compressed air and blow out the vents and fan area, that might work for a while but you'll be blowing the dust in. It's best to take it apart and blow the dust out.
Apr 02, 2012 | Toshiba Computers & Internet
The laptop has been in use for the past 10
It sounds like you have an overheating problem on the machine. You can try to blow the system clean but in many cases laptops need to be physically taken apart for a thorough cleaning.
Robert from Blitware
Jun 22, 2010 | Compaq Presario CQ60-220US PC Laptop
Hi, I have an Advent laptop that shutsdown after 10 minutes. Appears to over heat and I can't hear any fans running? Any advise? Regards Steve
Take a can of air and where the air vents are, blow alot of air into them to make sure the vents are free of dust and dirt, that can cause laptops to overheat.
If that doesn't work, you'll need to take apart the laptop and clean out the CPU fan so its clear of dust and dirt.
Apr 22, 2010 | Advent 4211c Notebook
Why is my laptop get's better warm and when i go into my facebook, couple of minutes later it shut off.
Your computer is overheating.
Turn it off.
Remove the battery.
Disconnect the AC adapter.
Buy a can of compressed-air.
Give your computer a "blow-job", to blow-out all the dust from inside the computer.
The dust is "insulating" your laptop, preventing it from cooling itself down.
Apr 18, 2010 | CMB T43 750 Notebook
It has problems getting it to turn on.. and when it does turn on, it suddenly turns off by itself after 10 to 15 minutes
It could be overheating (due to the failure of a fan inside the laptop) causing the computer to "self-protect" by shutting itself down.
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Purchase a can of compressed air.
Use the air to give a "blow-job" into every air-port in the laptop -- a layer of dust will act as a layer of insulation, preventing the computer from radiating the build-up of heat.
When you turn the computer on, listen for the fan(s) to start running -- put the hairs on your arm near an "exhaust-port" on the PC, to feel if the fans are blowing air out of the laptop.
Apr 08, 2010 | Toshiba Satellite M45-S265 Notebook
I have a dell Inspiron 1705, it runs fine, boots fast, runs normally however after about 10 to 15 minutes of use the laptop freezes. The only way to reboot it is to hold down the power button to shut it...
Looks like an overheating problem.
First, make sure that you put your laptop on some hard surface. If you put in on your bed for example, the soft surface will block the air vent on the bottom of the laptop, resulting in poor cooling of the inner components.
Do you hear the fan working, and air blown out of the exit vent on the side (or rear) of the laptop?
If not, then perhaps the fan is broken and needs replacement.
If the fan can be easily heard, working at full speed all the time, there is a problem with blocking the air inlet, or the internal radiator/heatsink got covered with dust and lint, and needs cleaning - try compressed air blown from the opposite direction (from the air outlet) to blow away the dust - of course with the computer switched off, otherwise you'll be "fighting" the fan trying to blow in opposite direction. If this doesn't help, the laptop needs servicing, as it probably lost the heat-conductive layer between the processor and heatsink.
Jan 23, 2010 | Dell Inspiron E1705 Notebook
Same problem.....
U need to get ur laptop for a diagnosis to locate the problem. i suggest a website where u can get a free diagnosis. click on below mentioned link
http://tinyurl.com/m7ghqz
Jun 19, 2009 | CMB T43 750 Notebook
Toshiba Satellite A105-S2717 (PSAA0U01Q003) PC Notebook Logo
88 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
