Question about Samsung HL-R4266W 42" HDTV-Ready Projection Television
Samsung hlr4266wx dlp tv shuts off
While i am watching tv it randomly shuts off sometimes within 30 mins and then i'll turn it back on and it will continue to do this while i'm watching tv
    Scholar:
  • 67 Answers
This tv usually if detects a fault will display via leds a error flash code. Refer to Owners manual for What the codes are for. If you go to Samsung Website Copy and paste link for manual.
http://www.samsung.com/us/support/search/supportSearchResultView.do?group=televisions&group_cd=&type=televisions&type_cd=02010000&subtype=dlptv&subtype_cd=02010300&model_nm=HLR4266W&dType=D&vType=R&mType=&model_cd=&menu=download&prd_ia_cd=02010300&acc_ia_fl=N&disp_nm=HL-R4266W
Problem may be lamp is failing or ballast which operates lamp may be Bad. Could also be Temperature fault from Inoperable fan or Color wheel. Bulb of course is first choice of possible problem followed by color wheel then ballast. Color wheels usually will start making bearing noise when they start to fail. Hope this helps.
Posted on Jan 14, 2008
Our RCA high-def 52 inch TV is shutting off on
It has you Posted as a projection TV and Not DLP, if Fan to Lamp stops running set will shut off to protect Lamp,I had a DLP that would play sometimes 30 mins then shut off drove me crazy trying to firgure it out and it turn out to be Fan would stop running I replaced Fan TV working fine . When you remove back engage toggler switch to up position put a piece of tape on it to hold it is a safty switch ,then turn tv on watch to see if all fans are running also if when tv trys to come on is there a spark coming from Ballast Board if so your new Lamp is defective it does happen if not your ballast board maybe Bad it is what turns on Lamp.If all fans are running Ballast Board.
Sep 22, 2009 | RCA HD52W56 52" Rear Projection HDTV
Samsung TV made a big ''POP''
replace the color wheel
Sep 13, 2009 | Televison & Video
My remote only works within 2 feet of the sensor on the tv. This is true for 2 universal remotes and the original remote that came with the tv. I have a Samsung 42" DLP HLR4266WX
Chances are that the sensor has gone bad. If you know how to get to the circuit board that it is on, then changing the board would be easier than just changing the sensor.
Jul 06, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung ldp 46 " replaced lamp humming sound fans cleaned and working set continues to turn off every 20 min or so
Humming problem with a Samsung DLP HL-P5063W
picture displays good
Humming randomly starts, but once it starts it hums
May 31, 2009 | Samsung DLP HL-P5663W 56" TV
Tv shut off and wont come back on
fuses first, than powersupply, next lamp inverter.
Dec 04, 2008 | Televison & Video
46 sam dlp problem
It sounds like an overheating problem.
Jun 09, 2008 | Televison & Video
TV TURNS OFF AFTER 20-30 MIN
Ensure that the TV is off. It may be advisable to unplug the TV as well.
2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
Make sure your TV is off and cool when performing this procedure.
May 28, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Shutting off
i have the same problem...laptop randomly shuts down, but its even done it within a minute of turning it on so i don't think its a heat issue. Sometimes it'll run for over an hour with no problem and never shut down, but other times it randomly shuts down sometimes within a minute, sometimes maybe 10 mins, sometimes 30 mins or more ...its maddening! i'd love to find a solution if anyone's found one. Thanks.
Apr 22, 2008 | HP Pavilion dv1000 Notebook
PROBLEM WITH SAMSUNG DLP TV
disconnect the power and hold in the power button for 30 seconds to reset it.
Feb 20, 2008 | Samsung DLP HL-P5663W 56" TV
Open Questions:
Samsung HL-R4266W 42" HDTV-Ready Projection Television Logo
1,310 people viewed this question
Jerry Greenberg
Jerry Greenberg
