Question about Bionaire BSF1731RC Stand (Pedestal) Fan
Oscillation works but motor doesn't
When putting it together, the fan cover was not put on correctly and was preventing the fan blades from spinning. The oscillation works correctly, but the fan motor that spins the blades does not work at all. Did the motor burn out? Or is their some sort of other part that can be replaced? The in-board fuse seems okay, and if were burned out would prevent the oscillation function from working, right? There is very little support here on the web. Thank you in advance.
  • 1 more comment
  • PeteRepeat3 Jan 15, 2008
    What is there to fix with glue? Is this a joke response? There is no movement of the fan motor or axle. It seems that no power at all is getting to the motor which spins the blades. Is there a part that was burned out which prevents power to run the motor. It's a brand new fan.
    I have a good joke fix reply for next time: Just put some duct tape on it.
  • donsbun May 30, 2008
    oscillation works but blades don't - just bought it haven't tried any thing at this point. Person I bought it from said it worked before.
  • Dani Love
    Dani Love Oct 04, 2014
    I found out that mine has a tiny fuse in the electric plug that needed to be replaced.
I have the very same model and it worked for 6 years OK. Two days ago the fan stopped turning even tho it still oscillated.  I often repair my own equipment and so I opened it to check what was wrong.  I found out that it has two motors., one for oscillating and one to turn the blades.  In short I discovered that the fan motor is bad, even though there was no odor.  Using duct tape or glue is not a solution unless you hear noise from the motor when your fan is on and the oscillating off. I suggest that you return your unit if it is new..   Personally I am going to try to purchase a new one if I can find the model.  I hope this helps.
Posted on Aug 16, 2008
    Problem Solver:
  • 14 Answers
Try tofix the axle with some glue or so
Posted on Jan 15, 2008
SOURCE:
I have a Ellington AW52ABZ5 the fan motor hums but will not turn blades
seized bushes or failed start / run capacitor or burnt motor
check that the oscillation action is not jammed , preventing the motor from spinning
Aug 08, 2016 | Ellington Dryers
My electric fan WILL oscillate, but the blades do not spin. I've opened it up, cleaned and oiled it and can't see any loose wiring. If the Oscillator works, why won't it spin?
fans that oscillate but don'e spin suggest a separate small motor for that action
the fan not spinning suggest a failed motor
mostly it is not worth repairing fans as the parts are not readily available and the labour and parts will out weigh the cost of a new one
take it to an appliance centre for a correct diagnosis then make a decision.
Jun 21, 2015 | Dryers
The plastic cover over the fan seems to be touching the fan blades. When I remove it its very quiet but when I put it on it seems to be slightly touching the blades and makes a noise. Can this be fixed....
There are two causes
1. The blades are out of alignment Check to see if blade nut is loose and look behind the blades at the shaft to make sure the notches ate in the shaft pins, off is clockwise.
2. The cover is not mounted correctly to the fan housing. Make sure its not upside down and the two halves are together properly and rightside up
Hope this helps Mike.
Mar 15, 2015 | Dryers
Fan motor will not spin blades
Is blade stuck? Remove grill cover and spin the blade to see if there is a mechanical problem. If OK then check the cord for a bad connection at the plug.
Oct 22, 2013 | Comfort Zone 18 In Oscillating Pedestal...
I took the blades off my table fan to clean them and once i put the fan back together and turned the fan back own the blade spins and everything but no air is blowing out
I think that you may have put the blade on backwards. try taking the fan apart and reversing the blade around and reassembling the fan.
Dec 10, 2012 | Hampton Bay 24002 Ceiling Fan
Aloha Breeze pedestal fan blades won't turn, but motor is humming
remove protected cover and with wd-40 or oil spray lightly behind the blade at the base oil up the bearing turn blade by hand till free put back and test the bearings get sticky from the dust
Sep 12, 2009 | Windchaser 3-way Oscillating Fan
Humming noise from motor of oscillating fan.
Wd-40 is not a very good lubricant. It only lasts fror a few days and then dries up again. In order to get your fan working again, take some 3-in one oil and put a drop at the bearing side of each bearing top and bottom with the shaft upright. Spuin and tap the motor briskly with a small tack hammer or screw driver handle. This will impact and allow the oil to get into the bearings Keep tapping and turning until you feel it lighten up a spin freely. Turn it over and do the same thing again. I garuntee that all will be fine after this.
Sep 07, 2009 | Windchaser 3-way Oscillating Fan
I own two Marvin Floor / Box Electric Fans. It's
its extremely simple... when it does that put your hand on the oscollator cover and hold it with light pressure for a couple seconds then let go. it should work
Jul 10, 2009 | Marvin Dryers
Accutek stand fan just hums, won't turn
That means the bearings are dry and have locked. Simply open the motor cover by removing the screw and pull the oscillation knob by rocking it side by side gently to have free access to the motor.
MAKE SURE THE FAN IS UNPLUG FIRST. Use cream type grease on both ends of the shaft. After applying the grease rotate the blades until they're freely and you feel the blades have released.
Place the motor cover back and the oscillation knob and plug-in the fan. Leave it on HIGH for 10-minutes or more to make the rotor loose with the grease.
Jun 15, 2008 | Accutek AOJ-1601 Stand (Pedestal) Fan
Bionaire BSF1731RC Stand (Pedestal) Fan Logo
1,387 people viewed this question
Top Bionaire Dryers Experts
Jerry Greenberg
Jerry Greenberg
Kardoc
Are you a Bionaire Dryer Expert? Answer questions, earn points and help others
