Question about Karcher 2500 PSI Pressure Washer
Karcher pressure washer 2500 psi
I bought at garage sale guy said it wasn't running because of bad fuel. but my problem seem to be just getting it to is imposible with starting rope i used a breaker bar a got it turning but nut enough so that i could start it with the rope is a honda moter
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
  • 92 Answers
SOURCE: Electric Karcher pressure washer surging when turned on
Dear firenutt681,
One simple thing you can do, is to check for leaks. Check if hose at machine is leaking. Check gun if it is leaking. You can also check if water still comes out of lance nozzel. These leaks however so small, will cause the machine to surge.
Another reason is due to a faulty SPILL VALVE. This spill valve( often called CONTROL VALVE) will contract when the gun is closed. When it contracts under the enclosed pressure it will switch off the machine by means of a Micro Switch. Now if this Spill valve is faulty it will loose its compression under pressure and puts on the micro switch again. This can be seen once in a while or more frequent, as in your case. I sometimes do service Spill Valves, but mostly I replace them with a new one. I do not know the model number of your machine, but normally you have to open the cover and you should spot the spill valve on the head. Most probably you see a thick wire or a cap containing the micro swith. If you find the micro switch, you have found the spill valve. Sometimes it is a bit hard to pull out the spill valve. Myself, in various Karcher models I remove the spill valve by trying to feed water and put on a bit the machine. In this way the spill valve will be spitted out.
Another reason which makes your machine surge, is leakage from from the detergent inlet.
If you do not see no leakages at all....then for sure it is the SPILL VALVE.
If you cannot do this job yourself or you do not find spare can continue using the machine as it is...but before closing the gun...switch off the electricity. I only recommend this in an emergency. You do this so that you do not leave the machine surging. This surge will for sure damage the electric motor and the capacitor (assuming it is single phase).
Posted on May 30, 2009
  • 40 Answers
SOURCE: Pressure Washer trouble The Engine Won't Turn Over. What's Wrong?
well for starters if you let it sit all winter you the pump probably froz up and you might be able to get it un jamed by pouring in oil (any kind) in the hose inlet and let sit one night the try starting
Posted on Jun 03, 2009
  • 2002 Answers
SOURCE: new Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Posted on Aug 31, 2009
  • 228 Answers
SOURCE: I don't get a constant
Make sure that while you are running your pressure washer, other machines that pull
large volumes of water like a dishwasher or washing machine are not running. check and make sure
the hose you have tied to the pressure washer is not collapsing or has any kinks in it.
check the filter where your water hose ties in to your pressure washer, make sure it
is clean and does not have any debris or hardwater buildup, clean the tip at the tip of
the wand. if it is reduced in size by hardwater buildup, will not work properly, good luck!
Posted on Jul 12, 2011
Backfire when turning off
let it idle down after using it then shut it off the carb could be leaking a little with the bad fuel we get only lasting 30days i always turn off the gas and run the gas out of the carb
Aug 15, 2012 | Karcher 2500 PSI Pressure Washer
When I squeez the handle the pressure surges.
The first thing i would do is be sure there is not a partial blockage in the nozzle.
Sep 24, 2009 | Karcher 2500 PSI Pressure Washer
New Karcher pressure washer won't start
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Honda 5hp engine wont run
check oil level. it has a low level shut off switch ?? May be it
May 04, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 2600 psi pressure washer wont stay running
Apr 22, 2009 | Karcher 2500 PSI Pressure Washer
No water coming through pump at all.
Is the tip/nozzle clean? try a different one. But you're probably right about the pump (I think they are all junk) unless you spend over a grand and get a "real" one
Apr 05, 2009 | Karcher 2500 PSI Pressure Washer
Karcher pressure washer k2.89
pressure relief valve is stuck. can't have an air lock.
May 31, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 601c
i don't know what a car boot sale is but sounds as if relief valve is stuck open.if this car boot thing is a car lot they use all kinds of stuff to clean cars in the water they use to wash a car. this washer has probably been let set up without being flushed after use. the problem isn't in the pump most likely but a corroded relief vale. remove and clean.
May 15, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
82 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
