Question about Konica Minolta DiMAGE Z6 Digital Camera
LCD not working
I can take pictures using the view finder,but I cannot see them on the main lcd.I do not know how to turn the screen on or off,I cannot find that on the menu options
  • michev Feb 07, 2008
    The lcd screen is not working,moving the switch next to the on/off button is not causing the screen not to work.You can hear the beeps when switching,so that is ok.Is there an on/off switch for the lcd that is not in the manual.thanks
  • 4 Answers
There's a good possibilty that your mode switch is broken. Same thing happened to my Z6. I was able to source replacement switches, and can replace them.
Posted on Sep 21, 2008
Next to the on/off switch there is a lever with three colored inidicators just above.
the green is the edit view...you can see the pictures/images from the memory card you have previously taken. the middle red is the lcd viewfinder option. This allows you to point the camera at your desired photo target and view the image in the lcd as you would normally do in the eyepiece view...which happens to be the third colored indicator...when switched to this one you can see the image you wish to take a picture of by looking thru the eyepiece above the lcd screen.
Posted on Feb 05, 2008
Fujifilm FinePix S1600 The monitor display is not working. Can it be replaced and if so how easy is it?
It could be that you have it set for EVF which means that you are using the tiny view finder instead of the LCD screen? It should have a button close to the view finder labeled EVF/LCD, you can alternate between the LCD screen or the tiny viewfinder? This function if mainly to conserve battery power or if you are out in the sun and cannot frame a shot and so you use the view finder like the old cameras, hope this might help you?
Dec 09, 2014 | FUJIFILM Cameras
I don't know how to use the lcd screen when taking pictures
Many cameras that have view finders do not support use of the LCD display to compose or frame a picture. This is generally to conserve battery life of the camera. Most of these cameras limit how long a picture is displayed on the screen to 10 or 15 seconds, immediately after taking for the very same reason.
The exception would be a camera that lacks a view finder - or has a menu item that allows the user to compose the picture on the LCD in addition to the viewfinder. Some manufacturers call this "live view". Check your camera manual to see if it is supported. If so, be sure to buy extra batteries!
I hope this helps & good luck!
Nov 27, 2011 | Canon Cameras
No picture or image from lcd monitor or view finder when opened
the connection between the lcd and the main board is defective, the video connector is broken, try to use tv connection to check if you get a picture displayed on your tv screen so you need to repair your lcd. if you don't see any picture it's main board problem service is required. thanks.
Dec 24, 2010 | JVC GR-D22U Camcorder
No picture on view finder
you need to request to replace your lcd unit to the service center.there's no chance to repair LCD.
Jun 03, 2010 | Olympus FE-280 Digital Camera
My s5000 screen is all white in record mode. It breifly had a picture then when I pushed the shutter it went white again????
Does the EVF work? The small view finder above the LCD screen. You can switch to it using the EVF/LCD button on the right side above the main display. If it is okay then you'll likely need a replacement LCD.
Jan 04, 2010 | Fuji FinePix S5000 Digital Camera
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
No viewing display on LCD screen
Push the evf/lcd button and it should work.
Feb 20, 2009 | Sony Alpha DSLR-A200K Digital Camera
Lcdscreen
if you have tryed switching over between lcd and evf and nothing comes up on the lcd then you might have a flex, lcd or main pcb fault.
May 31, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
SCREEN AND VIEW FINDER BLANK
Is the battery dead? Try taking it out and charging it, then put it back into the camera.
Also, you can try using another battery of the same type.
May 30, 2008 | Panasonic Lumix DMC-FZ50K Digital Camera
LCD Screen does not work properly
Your camera works just like a film camera SLR,. You use the eyepiece to frame and focus your picture. The LCD screen is for reviewing pictures taken or menu operations. You cannot preview a shot on screen before it is taken with the camera.
Jan 07, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
200 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
ktpierce
Level 1 Expert
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
