Question about Mitsubishi VS-50703 50" Rear Projection Television
Mitsubishi VS-50703 blurry after move
I have a Mitsubishi VS-50703 50 in projection TV. I recently moved and ever since the move I have had a blurry picture from my TV, it doesn't matter if the signal is from cable or dvd. Even the menu seems blurry its kind of a double picture or halo effect. I don't know if there is a way to focus it through a menu function or if I need to call a tech. please help!!!
PS - I inherited this TV from my parents and I don't have the original remote or owners manual.
  • Mitsubishi Master
  • 8,617 Answers
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Posted on Jan 14, 2008
Blurry Picture on Toshiba 65HX81
yes the tv has convergence problem u will need a tech to reposition it
Jul 11, 2013 | Toshiba 65HX81 65" Rear Projection...
Vs 4571
you must replaces many electricaly capacitors located on video board
good luck!!
Aug 18, 2008 | Mitsubishi WT-42413 42" Rear Projection...
Mitsubishi 50705
Good Day, tree64;
More than likely the convergence problem the TV has wont be resolved by adjustments. In your situation, moving TV, the problem most likely is poor solder connections on the convergence IC's. They are large devices attached to very large heat-sinks, and have numbers on the IC'c like STK 392-560.
If no poor connections....replce.
Good Luck, big IRISH.
Jul 04, 2008 | Mitsubishi VS-50705 50" Rear Projection...
Lost the remote to my mitsubishi big screen tv
Just bought a new remote for my VS60603, then main board goes bad upon moving to new location. Never used it. Interested in purchasing it? Email tomasg01@msn.com.
Apr 21, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi VS-60603 60 inch Projection TV
You would have to completely take the Mirror out or Mylar backing and being careful not to damage anything, trying to move and reassemble when you get at the new location.
Dec 05, 2007 | Mitsubishi VS-60609 60" Rear Projection...
IS THIS TV PLAYING OUT
Color separation is called convergence mis-alignment......that
problem can be repaired...............Blurry,darker when cold may
be a bit of difficulty..............Have a skilled tech give it a look.....T.
Nov 15, 2007 | Mitsubishi VS-50607 50" Rear Projection...
2 new problems with my TV after my move
Well it may just be the signal in your area that isn't quite as good. That's just fact. Also, because the signal may be weaker, it may take longer for the TV to fine tune to get the best picture quality, which would explain the slight blurring after turning your TV on.
Sep 07, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Blurry Image problem with Mitsubishi WS-55805
Hello, if you want I can supply you with the service manual, please leave your email. Best regards, Arpi
Aug 14, 2007 | Mitsubishi WS-55805 55" Rear Projection...
Projection TV with Distorted picture
You have one of two different problem. You have bad solder connections on the convergence amp IC's, or you have bad convergence amp IC's. By the way it is acting, I bet if you or someone else resolders all of the pins on both IC,s your problem will go away. But if you keep letting it do this, it will most likely cost you double to repair in the future. Good Luck
Aug 11, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
219 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
