Question about Olevia LT37HV 37 in. HD-Ready LCD Television
Factory Reset wont work...Manual reset?
I can go into menu and navigate to factory reset, but nothing works.
Is there a way to fix this, or a manual reset.
Other problems:
1. the tv has shifted lines of viewing (not sure how to describe)
2. glitches, it some times will freeze for a fraction of a second, you can still watch but its not perfect
3. My parent code is locked, and I never set a code. Is there a administrator pass code so I can change the level.
Thanks to anyone who can help.
This tv has been nothing but trouble since I got it.
Your tv might be in showroom mode. Use the remote to open the main menu, go to picture, go to mode, go to power up and make sure that home is selected and not showroom. Many of the controls are disabled in showroom mode.
Posted on Jan 17, 2008
  • Price Funderburk
    Price Funderburk Sep 12, 2012
    Im completely frozen on that screen....:/
The above solution totally works. THANKS- this solved a TON of my problems with this TV. You rock nikitastorm.
Posted on Jan 25, 2008
I have a Panasonic DMR-EH 50 DVD Recorder, I changed the code on the Remote from code 1 to code 3, now the Remote will not work. How do I reset the Remote so it works again.
here you go. Page 62 for Full Reset, and also Page 57 of the instructions. Copy and Paste from the PDF doesn't work, so you will have to visit yourself :>)
To return the channel settings
and clock to the factory preset
(No setting)
Press and hold on the
Manual
ftp://ftp.panasonic.com/dvdrecorder/om/dmr-eh50_en_om.pdf
Apr 24, 2017 | Panasonic Televison & Video
How to reset my Motorola blur
Factory Data Reset is a tool used to remove everything that was imported, added or installed on the device. Keep in mind, when using this feature; everything is deleted. Nothing stored on the MicroSD will be affected. Your information is automatically backed up to the MOTOBLUR server. Your information will be restored when you login with your user name and a password.
Factory Data Reset
  1. From the screen of your phone, open the Applications Tray. (circle located in the middle at the right of the display screen) Or press the Menu button on the left from your screen.
  2. Tap Settings
  3. Scroll down and tap Privacy
  4. Tap Factory Data Reset
  5. Tap Reset Phone
If you are unable to navigate through the menu to perform a factory data reset, you can follow the steps outlined below:
  1. Power off the phone, press and hold volume down button, press power button.
  2. Wait for the "triangle ! / Android" screen then release the volume down button
  3. Tap lower right-hand corner of Touch Screen
  4. Navigate on-screen menu to select "Wipe" (data/factory reset) and Press OK
  5. Navigate on-screen menu to select "Reboot System Now" and Press OK
  6. Wait for device to reboot
Apr 22, 2016 | Motorola Cell Phones
How to hard reset andriod phone when changing password
not sure what p/w you want to chg but a hard reset isn't necessary to do that. If you do it will bring your phone back to factory defaults and you will need to renter/reload everything.
The factory default reset is on the device menu.
This is for my Droid Pro - look for it in ur manual.
Reset
To reset your phone to factory settings and erase all
the data on your phone, touch Menu > Settings
> Privacy > Factory data reset > Reset phone.
Warning: All data on your phone will be deleted.
(Nothing on your memory card is deleted.)
Jul 07, 2014 | Google Android
Why wont my i rulu tablet wont unlock or power off ?
This might fix your problem
Every Android handheld has the same pattern on how to restore or reset the phone back to factory settings. Factory settings means you are wiping the data in the internal storage but not whats on the SD card. See steps below: 1. Turn off the tablet by pressing and holding the power for 30 seconds and tap shut down. 2. Press and hold power plus volume up until an android menu appear 3. Use the volume keys to navigate and option key or power to select. 4. look for factory reset and wipe data 5. restart the device and it should be back to factory settings.
Jun 19, 2014 | Computers & Internet
CM 1015mfp Colors are not aligned. when printing the characters looks like 3D.
If nothing else works, you may have to manually calibrate the dials inside the mirror box. This video link will show you how. http://youtu.be/R1DIko0a1MA
This may be necessary if the printer got bumped really hard.
Aug 17, 2011 | HP Color LaserJet CM1015 Printer
My Panasonic DMC-LS2, work with "Motion picture mode", but not work with "Normal picture mode" ; not memorize. Work with .mov files and not work from .jpg files. My SD card is 2Gb. Is...
You have to reset your camera thru its factory setting. To do this, navigate the menu and look for factory reset. Different brands and different models of camera use different style if menu control structure. If you are not familiar, read the operating manual of you digital camera. I hope this advice will help you in your problem.
Mar 17, 2011 | Panasonic Lumix DMC-LS2 Digital Camera
Factory reset Menu
IF A SAMSUNG TV Put tv into STANDBY
WARNING DO NOT CHANGE ANY OTHER SETTINGS TV WILL NOT WORK
Press INFO / MENU / MUTE / STANDBY on remote tv will come on with service menu displayed and FACTORY RESET (12) is on it
ONLY USE DOWN NAVAGATION KEY until you highlight factory reset
NOW PRESS RIGHT NAVIGATION this will reset all settings
PRESS POWER ON THE TV TO EXIT then turn on tv and retune
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Nokia 500 GPS won't navigate
suckthedick, lick the tip, grab my balls, swallow my gravy
Mar 15, 2009 | Nokia N500 Auto Navigation
How do i turn off my lock on my tv
Hello there. This is taken rigth from the manual...
To reset to the default factory settings, follow these steps.
1. Press the MENU button on the remote control to
open the OSD.
2. Press the Navigation (UP/DOWN) buttons to
select the Options menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to
select Factory Preset.
5. Press OK.
6. Press EXIT to close the OSD.
You can find the rest of the manual here.
Dec 03, 2008 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
How to reset (manually) factory defaults?
Press Setup,Right Arrow,Press Down 3 Times,Then Enter 2 times this should reset factory settings, I Hope This Is Correct As I Realize You Cant See The Menu But I Studied The Manual And Wrote Out The Exact Key Movements To Navigate The Restore Factory Settings menu. Hope This Helps
Sincerely,
Michael Scott
Nov 16, 2008 | Protron PD-DVR100 DVD Recorder
Olevia LT37HV 37 in. HD-Ready LCD Television Logo
2,409 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
