Question about Frigidaire ATF6000ES Front Load Washer
How to remove Affinity front bottom panel? Catriver help?
I have the dreaed E21 error... I have the Affinity 7000 I think. At any rate it looks similar to 6000... the problem is that the front panel which included the door is large... how do you remove it? (there are 4 screws on the bottom) Now, I imagine it comes off with the door, but there is a rubber gasket that connects the door to the drum to prevent leaks of course... does that come off? It was already replaced once and I remember the repairman had a hell of a time placing the new gasket one so I am a bit hesitant to take the panel off... anyone has any pcitures? CATRIVER?  ( Isaw your earlier post with picture of the pump)
  • 1 more comment
  • robinzon Jan 14, 2008
    I don't wante to replace the front, I would like to clean out the pump... I have an Affinity ATF7000 washer... ie there is no bottom panel, the front panel is one piece with the door (the control panel on top is separate). I would like to clean the pump and in order to do that, from what I have read here, you need to access the front of the washer. I have no way of tilting or moving the washer as there is a dryer on top of it. So please let me know how to get to the pump from the front...
    Well for me its even more complicated as I would have to first remove the closet doors then somehow getthe machines out... someone recommended teflon skids, but perhaps the tech can tilt the machine back and only partially move the machines out since there is room up top for the tilt. I decided I don't want to experiemnt with this myself since Iremember how hard of a time the tech had when he was replacing the rubber gasket (after 1 month the thing sucked it in). I regret 100% on buying anythign from frigidaire (I would much rather get GE/Kenmore or LG) but I was forced into this becuse of the size of the closet (though that is even no longer the problem since the door was changed). Its a poor unit that washes very badly and is impossible to service.
  • dhrodefe Oct 27, 2008
    how to repair error 21
I have an affinity 600es.. and the same problem.. I went through it yesterday.. There is no bottom panel to remove.. the only way in from the front is to remove the entire front panel, which first involves removing the top, then the control panel section and the liquids dispenser.. I got part way through it that way, and decided I didn't want to cut all the tie wraps and what not to fully remove the fro panel/door section.. so I put all that together and titled the unit on it's side (pump side down).. there is a large removable access panel on the back, and an always open smaller access port on the bottom next to the pump... I had to work at it with one arm in through the back, and one arm in through the hole in the bottom.. because of those stupid hose clamps they use...
No matter what, you're gonna have to remove the dryer from on top of your washer.. I'm really pissed off at frigidaire for this design.. I think it's on purpose to force paying service costs.. if not, then the engineers are just plain stupid.. this is obviously a periodic maintenance thing for these washers.. why couldn't they make some sort of easily removable filter for the thing.. maybe where all you do is remove the large back access panel and then there is a filter unit that has a threaded cap.. so that you're not fighting to remove a bunch of impossible to get to hose clamps and cursing the whole time..
if designed with the consumer in mind, this procedure could have taken less time that it takes to disconnect the hoses and power to move the unit.. but instead, I missed the entire cowpokes/gnats game yesterday fighting this thing.. way to ruin my sunday!
I'm not an engineer, but if they're too inept to figure it out, I can show them what they need to do, to make this a simple procedure that any housewife can do! If they care a smidgin about their customers, that is!
Posted on Jan 14, 2008
  • Anonymous Jan 15, 2008
    Like I said, if they simply installed some sort of removable filter that with a twist could be pulled out of the boot that goes from the drum to the pump, it would make life a lot easier... then the customer could just remove the large oval cover on the back of the unit.. reach in, give a twist on the cover and pull out the filter, remove the debris, put the filter back in, replace the cover, and go on with life.. it would take all of five minutes instead of three hours, turning the machine on it's side and whatever else gymnastics a person has to go through to do this...
    at the very least, use automotive style hose clamps, so that they can be removed without all the bad language.. I'm sure even the paid repairmen would appreciate this small gesture..... because this can't be any easier or more fun for them either...
    Lint, coins, pet hair, pillow stuffing, etc. are all part of life.. so these thing are eventually gonna get into the pump strainer and clog it up.. make the thing easier to clean out...
There is NO WAY to remove front panel on the 7000 washer... the pump can only by accessed in the back... its a POS machine to begin with, forget about the service..
Posted on Jun 02, 2008
  • 14 Answers
What I want to know is where is the filter???
Posted on Jun 01, 2008
    President:
  • 1,314 Answers
Dude why do you feel the need to replace the whole front of the washer for a slow drain im a 15 year frigidare tech lets talk
  • 1 more comment
  • robert samples Jan 14, 2008
    ok guys just chill a few minutes error code 21 is a slow drain code let me look at the blue prints and see how we can deal with this i own a Frigidaire front loader my self because its one of the finest on the market they had it out for 30 years in europe before bringing to the us so lets work together and i can be of great help ok
  • robert samples Jan 15, 2008
    listen guys if you e mail me at [email protected],com i will give you the golden cow but listen to me your dead wrong about the appliances companies ive been tight with them for 26 years and frigidaire done a two million dollar study that said one dissatisfied customer on average will tell twenty other people and that's not good for business they want you happy now slow drain problems number 1 cause is foreign objects left in peoples pockets during wash like change,tooth picks ,drill bits , nails getting stuck in the holes in the tub and jamming the tub ,etc.They are world wide companies and repair is a small part of their business. but e mail me as i cant post what im going to do for y'all on the web .frigidare would want me to to make you happy ok and if you need further assistance ill be here and fix-ya is a great site we are here doing this for you
    ps after the email yall got any comments for frigidare ill be happy to relay them for you but check your pumps first and see whats in them
6ya staff
SOURCE:
Error code e21 on frigidaire affinity washer cleaned pumped and ran a rinse cycle it did fine put clothes in to wash it ran for 10 min. then stopped.
Hello Deena,
Error Code e21
means the water is not pumping out fast enough.The most likely reason is because the washer drain filter is clogged.
Here is a solution:
  1. Pull the machine out from the wall.
  2. Then take the panel out in the rear. Once the panel is off you will see the drain pump.
  3. Disconnect the drain Tube between the Tub and the Pump.
  4. Look inside the pipe you will find the Drain Filter.
  5. Clean the filter out ( you will be surprised of "things" found in the filter) then put the machine back together
  6. Try a full cycle.
That should end your problem.
Best of Luck!
JP
Jun 19, 2015 | Frigidaire Washing Machines
E21 frigidaire affinity won't drain
Good Morning Friend,
I understand you are receiving an E21 code on your Frigidaire Affinity washer, model# ATF7000E, and it is not draining. The E21 code can possibly mean that the water is not draining out fast enough. Please check the drain hose for any kinks or clogs. Also, make sure that your home's drain pipes are not clogged as well. This could also be a false code. Try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
What is error code e21
Good Morning Friend, this is Z. That's a great question!
If you are getting an error code E21, it usually means that your washer is not pumping out water fast enough. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Best regards!
Jun 06, 2014 | Frigidaire Affinity ATF7000E Front Load...
E21 error affinity
Hello markramos66 - An error code E21 commonly refers to the water in your washer is not pumping out fast enough. First, check the drain hose for any restrictions or kinks. If you have check the hose and it appears to be clear and free, then potentially the underlying issue may be the main control board or pump. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
Apr 14, 2013 | Frigidaire ATF6000ES Front Load Washer
My frigidaire washer has e21 error code and wont start
Hello - The error code "E21" typically means the water is not draining properly or not pumping out fast enough. Does the washer making a humming noise? If so, either the drain hose may be kinked or the drain in the house is clogged. Once you have confirmed and cleaned the hose and if issue continues contact a professional to move forward accurately. The unit may possibly have a faulty pump or control board.
Nov 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
What is code E21
You have a pump error - 1. Check the drain hose for restrictions. Restriction, correct problem. No restriction, go to step (2). 2. Start the washer and check for 120VAC at the drain pump. Zero, replace the Main Control Board. 120VAC, remove the pump and check it for blockage. If blocked, remove the restriction, if not, replace the pump.
Aug 07, 2012 | Frigidaire Affinity ATF7000E Front Load...
I have a frigidaire affinity washer and e21 appears on display. what does it mean
E21 is slow drain. this means there is something clogging the filter in the hose from the tub to the pump. 1. unplug unit. 2. remove bottom access panel on the front. 3 be ready for water to spill lots of towels you can throw them back in washer when this procedure is done, so don't worry, pack the towels around the hose that comes from the bottom of the tub to the the pump 4 remove the clamp holding the tub to the pump 5 gentle remove the hose this is where you may get wet 6 reach into the hose you will feel a filter (cup like with holes in it) work is out of the hose it will be tuff but it will come out 8 now you have it in your hand clean it out all good 9 put it back it must be there so don't think of leaving it out , you must push it all the way back down until it is set in the grove for the lip of the basket. 10 reassemble the unit
Jun 18, 2012 | Frigidaire Washing Machines
Frigidaire Affinity ATF7000ES Front Load Washer Error Message
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the mains. You have to look for screws below the front kick-panel, you can raise the machine a bit to gain access to the screws, the panel comes down & out. You may find a drain hose here, on left, drain off the excess water. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. You can pass it into a large plastic bag. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Pl rate me nice for the free help!
Apr 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error code E21
you need a phillps screwdriver remove the top . control panel then the front... hope it helps
Aug 23, 2008 | Frigidaire ATF6000ES Front Load Washer
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
May 04, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
887 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
