Question about Canon PIXMA iP1600 Printer
Printer port I'm running Windows 98.  Last May my printer stopped functioning after my system went down. I got my system back up, but failed to get my printer to work again.  I discovered that I need to install the latest driver for my printer, so I downloaded it from Canon.ca.  I followed all the instructions with precision but still fail to get my printer to work. When installing the version 8.61 driver, with the printer on, after the USB cable is connected securely to the computer, then to the printer, the printer cannot be detected.  The driver appears to be successfully installed, but when I try printing a document from Front Page, for example, it indicates that it is printing to LPT1, and I know this is wrong, because I'm using a USB cable and therefore, it should be connected through a USB port of some kind.  What is the name of the port I should be connected to and how do I access it?  I continue to get an error message saying "Error reading to Canon...make sure printer is turned on and on line" I have 3 Canon printers now, and they are all useless, and they are less than a year old.  Are the printers themselves broken, or is it a software issue that you can solve for me?
  • 96 Answers
Try to re-install the printer from scratch...
Delete the existing printers from your system.
I.E. Go to add remove printer and follow the instructions.
Ensure your printer is connected.
Posted on Feb 09, 2008
A printer error has occurred. See your documentation
What are the system requirements for using this printer? A: PC Compatible Requirements
- An IBM (r) compatible PC with at least a 486/66 MHz (for Windows 98) or Pentium (r) 133 MHz (for Windows 2000) processor (Pentium or higher processor recommended)
- Microsoft (r) Windows 98 or Windows 2000
- At least 16MB (for Windows 98) or 32MB (for Windows 2000) of RAM (32MB for Windows 98 or 64MB for Windows 2000 recommended)
- 50MB of free hard disk space (100MB or more recommended)
- VGA or better display adapter and monitor
- CD-ROM or DVD drive for installing the printer software
- USB connection: a computer running Windows 98 or Windows 2000, with a Windows-compliant USB port and a shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction. Apple Macintosh Requirements
- An Apple (r) iMac (tm) series or Power Macintosh (r) G3 or G4 with USB port
- For iMac: Mac (r) OS 8.5 or later (Mac OS 8.5.1 or later recommended)
- For Power Macintosh G3 or later: Mac OS 8.5.1 or later If your iMac is running OS 8.1, you need to upgrade your operating system before installing your printer software. To find out which operating system your iMac is running, select About This Computer from the Apple menu. If you're running OS 8.5 or 8.5.1 on your iMac, Apple recommends that you install iMac Update 1.1. Download the update for your system from Apple at http://asu.info.apple.com. Contact Apple if you have problems installing an update.
- 16MB of available RAM (more recommended)
- 50MB of free hard disk space (100MB recommended)
- VGA display or better
- A shielded USB "AB" cable up to 6.5 feet (2 meters) long. Using an improperly shielded USB cable-especially a cable more than 6.5 feet (2 meters) long-may cause the printer to malfunction.
Oct 27, 2010 | Epson Stylus RX580 InkJet Photo Printer
How do you get an external sata disc mounted in a dock (Thermaltake Black X dock) to communicate with a WIN 98 SE system? The box says the dock supports WIN 98 buit I cannot find drivers that work.
Microsoft stopped supporting Windows 98 over two years ago,
and stopped supporting Windows 2000 on July 16, 2010.
So, any company that manufactures "new" (in the last two years) hardware probably will _NOT_ have written device-drivers for Windows 98/98SE/NT/2000.
Does the external disk work correctly when connected to a computer running Windows XP? Vista? 7 ?
If not, then maybe the external disk itself is the problem.
Sep 08, 2010 | Thermaltake Blacx Se HDD Dock with USB...
Failed Error During Installation. MSI.dot4wrp...Error Code 2753' Message Displays on the Computer in Windows XP and Vista
This is an internal installation error. There can be 2 solutions:---- Solution 1:-- Find all of the hpqwrg files and delete them before installing the software:
  1. Click Start .
  2. Click Search ( Find for Windows 98).
  3. Click Files and Folders .
  4. In the Named entry box, type hpqwrg .
  5. Set the Look In entry box to C: .
  6. Click Search Now ( Find Now for Windows 98).
  7. Click Edit , and scroll to Select All .
  8. Delete all files pertaining to hpqwrg . There will be approximately five to six files.
  9. Be sure to empty the recycle bin of these files also.Solution 2:---- Completely uninstall the higher version of software and reinstall the lower version first, follow the steps below in order:
    1. Uninstall all of the HP Photo and Imaging software (for both of the products). (The uninstall program can be found in theControl Panel in Add/Remove Programs ).
    2. Re-install the lower version of the software.
    3. Re-install the higher version of the software. Thank you Sir.
Sep 27, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
HP 1210 c/ps will not print
you will need the usb port drivers for windows 98 and the usb drivers for the printer as the earlier windows 98 had'nt the usb drivers included with operating system an as the new motherboards came about with usb ports then a new in 98 was needed to catter for this that's why you have win 98 first edition and win 98 se edition please chech that you have the driuvers installed for both parts to work.
good luck
Nov 22, 2008 | Microsoft Windows 98 for PC
Usb 2.0 windows 98
Windows 98 SE supports USB 2.0. The original Windows 98 (gold) or Windows 98 OEM or Windows 98 Upgrade versions which are not SE will not support USB 2.0. Nor is there any way to get USB 2.0 support for these Windows 98 versions unless you upgrade to Windows 98 SE.
Note that the Windows 98 SE upgrade CD will fail upon completion, leaving the SE Upgrade with a corrupt registry, if you try to run the Windows 98 SE Upgrade CD on a Windows 98 system that has a version of IE installed which is higher than IE 4.
Jul 02, 2008 | APC USB Port Version For Windows 98...
940c deskjet with windows xp
well the files for win 98 are not reconized in xp you may have to puchase a new printer for xp for it to reconize it or it might be turned off in the computer management click my compter and then click manahe go to the services and it will show all the things that are running or hace stopped look for you printer and on the left it may say disabled click properties and tun it back on and the see if xp reconizes it
Apr 14, 2008 | HP DeskJet 940c InkJet Printer
Canon Multipass c20 driver for XP
MULTIPASS C20/C50 ON WINDOWS 2000/XP This device is not compatible with Windows 2000 and Windows XP as a multifunctional device. For this product, Canon advertises compatibility with the following operating systems: Windows 95, 98, Millennium Edition (Windows ME).
Printing functionality may be possible by following the steps below.
Step 1 – Install a compatible printer driver.
1. Start the ‘Add Printer Wizard’ from the Printers folder (Windows 2000) or the Printers and Faxes folder (Windows XP).
2. Ensure that the ‘Automatically detect my plug and play printer’ tick-box is not ticked. Press next.
3. When prompted, ensure the printer port is selected on to LPT1. Press Next
4. When the list of manufacturers and models is displayed, click on Canon, and then BJC4200. Press next until the installation is completed.
5. The printer driver should now be installed.
If you are using the BC22e photo cartridge, you will need to download the BJC4200 driver from the www.canon.com.au website.
Step 2 – Setting the Multipass machine to Printer Mode.
1. On the Multipass keypad, press Function, followed by 0.
2. Press the left arrow key until you see Dos Printing.
3. Press Start twice.
If you have successfully completed the above instructions, you may now find that you are able to print to the Multipass machine. To restore the Multipass back to its original mode, press Function, and then Printer Reset.
Feb 06, 2008 | Canon MultiPASS C20 InkJet Printer
Canon PIXMA iP1600 Printer Logo
32 people viewed this question
old marine
old marine
