Faulty thermostat, failed water pump, inoperable radiator fan, low coolant due to leak, faulty radiator cap, leaking head gasket, low oil, major exhaust leak near front, exhaust blockage, or incorrect ignition timing. If there is crust around radiator cap, cap is leaking. How long does it take to overheat? If it runs smoothly when cool, and all fluids are at correct levels, you can rule our head gasket, radiator cap, and ignition timing. If it overheats very quickly and fluids are correct, it is probably thermostat or water pump. If it seems to do better at higher speeds, it is probably radiator fan. You can check this by allowing vehicle to run in Park with hood open. Monitor engine temp on dash. When it is at or slightly above normal running temp, radiator fan should come on. Also note exhaust sound. If it seems loud and overheats gradually, you may have a leak before the converter. If the exhaust sounds quiet, but exhaust manifold is getting extremely hot (may glow red), there is probably a blockage. There will also be OK starting and idle but poor acceleration if exhaust is partly blocked.
SOURCE: my 2002 zx2 overheats and the coolant flows into
You may need a thermostat replacement,which i would try first,or your head gasket is blown.[Any luck it's the thermostat].
it overheats only at slow speeds,all fluids are topped off and when it overheats the coolant flows into the overflow tank and its very hot.
when i drive slow the temp gage goes up
it depends on when it overheats.
