Question about Pioneer VSX-D811S Receiver
Pioneer VSX-D811S receiver
The sound will go out after a short time sometimes it will work all day but when the sound goes out the bass still plays and I lose all the highs, (lots of rumble no talking during movies)
  • mbhouse Jan 13, 2009
    Turn on receiver (vsx-810s) come on then goes off after 5-7 sec.
Make sure the positive and negative match up between the receiver and all speakers. I had the same problem and 1 out of 5 speakers had the wires backwards.
Posted on Nov 03, 2008
I need diagram for vsx-d811s
if you wish to get it, place your email address here.
Sep 30, 2016 | Pioneer Vsx-d811s Audio Video Multi-...
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
My receiver turns of when i raise the volume and when i press the super bass button.
Check your wiring and connections, make sure positive (red) goes to positive on both ends and negative (black) goes to both ends. A lot of times these Receivers will have a "saftey" auto shut off if the wiring is old, incorrect or exposed. This is to ensure your amplifier doesn't short out if turned up to higher db's.
Mar 07, 2011 | Pioneer VSX-405 Receiver
Will not tune any radio station, fm or am. everything else works fine. May be damage resulting from lightning, through the antena input.
It is very possible the fm tuner pack is damaged from lighting,if you have voltage going to the fm tuner pack im sure your tuner is bad pioneer part number for your tuner is AXQ7231
Sep 26, 2009 | Pioneer VSX-D811S Receiver
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
I have a Pioneer VSX-4900S that when first turned on (cold) the right channel doesn't work unless I turn the volume up loud or let it warm up and roll the volume knob up and down. From then on it works...
Hmmm, that almost sounds like a bad solder. As things heat up, they expand. When there is a bad solder (even if you can't see it) as the unit heats up and the pieces expand, the contacts at the solder point will meet and allow the circuit to complete, thus producing sound through the right channel.
Take a large magnifying glass, and with it, examine the bottom side of each of the circuit boards, looking for a solder point that is not well formed.
Mar 04, 2009 | Pioneer VSX-D811S Receiver
The right Channel is not working
hello if you are sure that you check everything, speaker,cables input signal.
if this pionner suddenly stops playing in one channel the most probable is in protection not burned so it needs service at repair shop.saludos
Jan 17, 2009 | Pioneer VSX-D811S Receiver
Overload problem on Pioneer VSX-D811S 7.1 Channels Receiver
IF YOU HAVE AN OHM METER.UNPLUG UNIT.REMOVE TOP COVER AND CHECK IC604,605,606 AND IC607 PART NUMBER ON THESE ARE AEK7022. I THINK YOU WILL FIND ONE OF THOSE OPEN .IF ONE OF THESE ARE OPEN YOU WILL ALSO HAVE A DEFECTIVE OUTPUT AMP IC.IT WILL BE THE ONE THAT IS CLOSEST TO THE OPEN IC. PART NUMBER ON THE MAIN OUTPUT ICS ARE PAC011A
Dec 27, 2008 | Pioneer VSX-D811S Receiver
Pioneer VSX-D811S Receiver Logo
199 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
