Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD-62526 I have a Mitsubishi WD-62526 and it has a bluish-greenish tinge at the bottom of the screen. It goes all the way across the bottom in an uneven fashion (not a straight line) about the bottom two inches of the screen. Has anyone else had this problem, is it an adjustment?
  • 2 more comments
  • benjamink Jan 24, 2008
    I feel ya on this, the same thing happened to me.. It gets bigger. You'll think you're on acid or something, and it's not getting bigger, cause it's so gradual. But it does. And then the lamp shits out on ya. I'm lookin for a new lamp right now.
  • lstutz Feb 20, 2008
    I have the same problem, only mine has gotten worse. The spots are 4-6 inches tall from the bottom of the screen and it has also begun to develop greenish spots all over the screen. One tech person I spoke to said that it might be the light engine going bad or that it could be dirty.
  • marino13 Feb 24, 2008
    i bought a tv through Arron's sales and leasebrand new. after 1 year the screen had 3-4 green blotches on it in the middle. i had a service guy come swap it out for another while mine is in service and they gave me a loaner of the same model. it has the worst picture i have ever seen in my life! 6" of green blotch across the bottom. something is up here! has to be a manufacture defect!!!
  • tileking Sep 18, 2008
    My TV too. 2 maybe 3 inches high in some areas. Never noticed it until HD service hooked up. Now thats all i look at is the green on the bottom. Its very distracting.
    I have a repair guy coming and will report back as to the problem. He estimated $300-400 to fix.
    President:
  • 4,402 Answers
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Posted on Feb 11, 2008
Hi i have a mitsubishi tv(wd-62526) and yellow light came on (lamp) that mints that i need to replace the lamp
Posted on May 31, 2010
    President:
  • 1,257 Answers
Follow this article to fix the issue:
http://support.microsoft.com/kb/314060
Posted on Apr 23, 2009
Mitsubishi WD-62526 turns on-n-off
I would bet the illumination lamp has reached the end of it's life (~$40 online). Should be easy to replace. Also possible the ventilation vents need cleaning, which could cause the lamp to overheat and turn off.
Dec 12, 2013 | Mitsubishi WD-62526 Projection TV
WD-62526 shuts off
The power supply is failing. Your TV is able to start but the power supply can't continue operating and shuts down.
Dec 12, 2013 | Mitsubishi Televison & Video
Mitsubishi wd-62526 error code 45
It's a lamp fan failure part no. 299P296010, its available at ebay and tvserviceparts.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
My mitsubishi wd-62526 red light is on for lamp and there is no picture
this indicates a bad lamp. your owners manual has instructions for replacing. there will be a lamp door on the back or behind the speaker grille. if the lamp is shattered or bulged/white it is bad. if the lamp looks good, you may have bad capacitors on your power supply.
May 26, 2010 | Mitsubishi WD-62526 Projection TV
Whats the best replaceable lamp for my wd-62526 tv?
It would be a philips lamp!!! They're the best in the market, discountdashmerchantdotcom :) take a look around and you'll see :P
Jul 03, 2009 | Mitsubishi WD-62526 Projection TV
I need a tv code for a mitsubishi tv model-wd 62526 2006
use your remote and press QV and 9 together. the reset the code
Dec 19, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
1,065 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
