Question about Pioneer DEH-P6600 CD Player
My pioner stereo is wired up and the only way i can get it to play is to turn my head lights on. is there another way to hook it up.im loosing all of my settings when i turn off the lights. all the wi
Stereo wont play unless i turn on my lights all wires are color coded
  • 2,039 Answers
First take a test light hook it up to ground metal of carfind witch wire got power when you put the light on disconnect the wire and find a wire that gonna work when you put the ignition on maybe in the fuse box be carefull not to hook it up to direct battery it gonna work but if you forget the radio on it gonna drain our battery cheers
Posted on Jan 14, 2008
Landcrusier 79 series 2006 model. keep blowing the tail light fuse after i hooked up a stereo. any ideas?
Locate the LIGHT + lead on your radio.
Do you best on finding the factory LIGHT + lead.
Use this old lead to trigger night lamination on your new radio.
If you can not find this lead then look for closest interior night lamination and tap into that positive lead.
Mar 01, 2013 | Toyota Vehicle Parts & Accessories
Im hooking up a pioneer car stero in a 2001 chevy cavalier. I purchased a chevy plug n play wire harness, and I hooked up all the wires (color coded) and plug it in, but no power, I have A ground and a...
your adapter should be color coded to the pioneer wiring, orange, red and yellow are power feeds for igntion, 12 key and lighting, veryify voltage on the orange and red wiring to the radion with key on, the yellow is for radio lighting with parking or headlight operation, some adapaters may not have all the wiring and you may have to splice around the adapter.
Jan 03, 2018 | Car Audio & Video
I have a 95 nissan maxima i am trying to replace stock radio(bose) w/a new cd player but once its hooked up im not hearing any sound? whats wrong with it?
Most Bose car stereos have an external amplifier. You will need to see if that is the case on your factory setup and remove the amplifier. Then hook the new headunit straight to the speakers.
May 30, 2011 | Car Audio & Video
Stereo wont stay on and only couple speakers work
on the back of the stereo you should have an rca inputs in the back, it should say either rear, subwoofer, or non-fade. all of these are acceptable, run rca's to the amp from the deck.
also on the deck in the wire harness is a blue wire with a white stripe.
hook a wire up to this and run it to the REM. terminal of your amp. this wire tells the amp to turn on when you turn on your key.
these are the only two wires you hook up the back of the stereo.
hope this helps
Jan 07, 2010 | Sony Car Audio & Video
Im trying hook up a subwoofer to my reciever and its getting power to the amp, however the amp is not powering on.. do you have any idea?
did you hook up the power antenna or amp. turn On wire? make sure you should ha a wire that is to power an antenna and this is the wire that has 12 volts as soon you turn On your stereo and send 12 volts to your amp. but if you don't connect this wire, the amp will never turns On
Jan 04, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
Im hooking up a pioner dc deck i have power but cant get any of the speakers working dose it have like a factoy amp or something that need to be hooked up to use the speakers?
the speakers have a neg/positive wire make sure you hooked them up right easiest thing to do is hook up the power and start with two speaker wires once you have sound coming from a speaker label them with masking tape .
Oct 24, 2009 | 1990 Lincoln Town Car
My plug for the factory radio has been cut out of my 1996 cavelier i need the wire codes because i think the plug ran other stuff besides radio and im trying to install pioner cd player but i cant because...
Hook the 12v memory to a constant power, like the cigarette lighter, or parking lights(red I do believe) The yellow one is key powered, so hook that to something that only powers up with the key on. The black one is a ground, that should be obvious. As far as speaker leads, you can take the door panels off and see what wires are connected to the back of the factory speakers. Hope this helps.
Oct 21, 2009 | Car Audio & Video
I have a 1992 eagle talon tsi im trying to hook up stereo
there is a "remote" wire that turns it on-sounds like you hooked it up to your lights. It needs to be hooked-up to the ignition so your radio turns off and on with the engine. Your power wire can go to the battery if you absolutely can't figure out which 1 it is that old radio used, but the remote wire must be hooked up right to turn it off so you don't leave it on and run the battery down.
Aug 31, 2009 | Car Audio & Video
We are trying to install a pionere radio and without the power antena/system control wire hocked up the speakers have no sound when you hook it to 12 volts the tweeters click what should i do
The antenna wire, witch should be yellow. is not supposed to be hooked up to 12 volts. It is only meant to be used as an on censer . If that wire is the reason your speakers are not working then the stereo is defective. That wire should have 12 volts coming out of it when the stereo is on. And hooking it to 12 volts could have damaged your stereo. I would look at the wire diagram again before doing anything else.
So anyway if you are not using the power antenna wire cap it off and leave it alone. you do not need it. Check all of your connections again and follow the wire diagram.
Good luck.
Aug 08, 2009 | 2001 Dodge Dakota
91 oldsmobile cutlass ciera stereo wiring diagrams
Constant 12V+ Orange
Switched 12V+ Yellow
Ground Black
Illumination Gray
Dimmer Brown
Antenna Trigger Pink
Antenna Right Front
Front Speakers 3 1/2" Dash
Left Front (+) Tan
Left Front (-) Gray
Right Front (+) Light Green
Right Front (-) Dark Green
Rear Speakers 6" x 9" Rear Deck
Left Rear (+) Brown
Left Rear (-) Yellow
Right Rear (+) Dark Blue
Right Rear (-) Light Blue
Thanks for using FixYa - A Good Rating is appreciated for answering your FREE question!!
Jul 07, 2009 | Pioneer Car Audio & Video
Pioneer DEH-P6600 CD Player Logo
127 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
