My computer printer says its going to print and then it starts breifly a bell sound rings and then it stops
  • 51 Answers
You need uninstall the printer software then go on the net to find the latest driver software for it look on the manufacturers website usually this will fix 90% of the printer problems
Posted on Jan 14, 2008
Somehow I have a bell icon on the screen at the bottom left with the words OFF beside it and now the phone does not ring only the ring on the fax/printer. Thanks Margaret
Hi margaret, is there a ringer switch either on the phone handset, or is there an option in the the fax settings to go directly to print. The issue sounds fairly straight forward, somewhere the phone ringer, or the settings for the phone to ring has been inadvetently switched off. Some investigation shoud bear fruit
Jun 08, 2015 | Bell Lands Phones
My bell ring everytime my next door neighbor's bell ring & even the neighbor three doors down. What is up with that?
They're all set to seeing frequency you need to go into your owners manual and check how to change wireless frequency
May 12, 2014 | Heath Zenith SL-6144 Specialty Series,...
I printed all the pages I wanted and stopped the printing. today I want to print something else and it wants to prin about 30 pages I don't want, help
Hi
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Please rate and make a comment if you find this solution very helpful and might help others as well. Post more comments if you need more help.
Apr 14, 2011 | Office Equipment & Supplies
Warning bell won't stop sounding
Sounds like your door sensors are going bad and are not relaying to the computer that the doors are fully closed, with that being said you will need to replace them and also at the same time it will stop the door locks from going crazy
May 16, 2009 | 2000 Ford Windstar
Bell sound will not stop.
Hey Wizz,
Have you checked the "closed door" plungers?
My neighbor had the same problem. I found it to be the drivers side plunger. The plastic retaining ring had broken, leaving the curcuit open. Being two months later, I hope you have found it.
I drove it a half mile...... It was like Chinese water torture. AHHHHHHHHHHH!
Hope this helps.
Matt
Apr 26, 2009 | 1996 Ford Mustang
When I go to turn on the computer/printer the printer sounds like it is stalling while turning on. It does make a loud clunking noise when I turn it on. I am able to print some things but it doesn't always...
your case sounds like the cartridge driving probem
1) check the cartridge driving bell is right on the way, and check the bell no gears damage, need to change if any damage
2) fill oil on the cartridge rail to make it lubricated
3) check the bell sensor open side cover to find out all sensors are in the right position and click normal,
Jan 09, 2009 | Lexmark X75 All-In-One InkJet Printer
My all in one hp psc 1317 has gone off line and nothing i do seems to get it back on
First check the printer icon. ( Make sure the printer is turned on during this process)
Go to Start Control Panel Go to Hardware and sounds Go to printers.
And check that the printer PSC 1317 has a check mark.
If not right click on the same and left click on Set printer as default.
Next make sure the printer icon says 0Ready.
If not right click on top of the PSC 1317 icon and left click on Clear all documents (untill it says 0ready)
If it still does not say 0Ready.
Then Go to Start Then Run(if not where you see start search Type there as Run and hit enter in the run Box type services.msc and click Ok
Now in the services window Scroll down an locate for Print Spooler and double click on the same
Now under Services status If Start is highlighted Cliick on start ( now a small window will poppup and close)
If Stop is highlighted then click on stop ( A small window will popup and close, Now you will see start highlighted Click on start and then either click on apply or ok close all the windows and restart your computer.
Now First
Go to Start Control Panel Go to Hardware and sounds Go to printers.And check that the printer C3180 has a check mark and if it says 0Ready.
If yes Right click on the same icon and left click on Properties.
Now in this window towards the bottom right you will see a tab which says print test pageClick on it to see if it prints a test page.
If yes then Try to print a document.
If non of this works
Go to Start Control Panel (or setup then contro panel) and then go to Printer and faxes (or printers and other hardware)
And deleted any or all the icon which says PSC 1317
If it is not deleting then right click on the same icon and lecft click on cancel all documents Then unplug the USB cable which is connected to the printer end and leave it unplugged for atleast 1Mins before reconnecting (In the meantime reboot your computer)
After rebooting the computer connect the USB cord to the Computer it should install the printer diriver on its own (if it prompts the CD then insert the Cd if you have it handy) it may take some time to install the prnter driver
Then
then PSC 1317 See.if it says 0ReadyRight click on the same icon and left click on Properties
Now in this window towards the bottom right you will see a tab which says print test pageClick on it to see if it prints a test page then try printing any document or Email.
Let me know if any problem
Good Luck
Nov 04, 2008 | HP Office Equipment & Supplies
Datamax I-4208 Cutter Fault
if the cutter cycles on start up up?
if not, check connector(RJ45) underneath platen assy.
I connected the I class should immediately recognize the cutter.
If it does not cut ever, check you format to see if the cutter is turned on in the driver.
I have seen some failures from wear on the bell crank that cycles the cutter.
Oct 02, 2008 | Datamax M-4208 Thermal Label Printer
Car door bell won't stop ringing.
is there any type of check engine light on or any type of warning light is the sound of the bell the same bell sound when you open your door or seatbelt warning
Aug 28, 2008 | 1997 Plymouth Neon
Bell on ignition switch does not stop ringing on 1999 Dodge Caravan.
Locate it by sound & pull it out, and replace it. probably stuck relay inside it.
Aug 03, 2008 | 1999 Dodge Caravan
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
