Question about Microwave Ovens
Stove lights One of the stove lights dimmed for a day and then when we turned on the lights the circuit breaker tripped of power to the unit. Both bulbs were burned out and were removed. Tripped breaker back in and all functions of the oven work fine but there is not power to the stove lights.
  • oneoldgoat Jan 31, 2009
    The lights just went out. When I tested the bulbs they are fine. Why do they not go on when switched
  • Microwave Ovens Master
  • 9,098 Answers
We see this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 14, 2008
When it is running the lights flicker or go dimmer or trips a breaker.
you have too much wattage on the same circuit. microwaves draw 1000-1100 watts typically, something else in on the same circuit drawing another 700+watts and tripping the circuit breaker. lights, refrigerator, stove, fan, hair dryer, etc, etc. if you turn everything else off and you have the same issue, then you may have an electrical issue with your wiring and it could be a potential shorting/fire issue. be cautious, be smart.
Jul 23, 2015 | Microwave Ovens
Why won't my microwave turn on?
Jennifer, do you have any lights or anything that works on the microwave? In looking up your model, I see that it is an over the stove unit. If you have no power at all for fans or lights or anything on the unit, you might have a tripped circuit breaker or you might have a blown fuse inside your microwave. If you have a blown fuse it would probably be best to have a service company come look at it because it will take two people to safely remove the microwave from the cabinet to be able to work on the unit in most cases. Hope this helps.
Jul 22, 2014 | Microwave Ovens
Freestanding stove (range) keeps tripping breaker when oven is used or two burners are used
Is this a new installation?? It sounds like the circuit breaker is under rated for this unit.
Nov 03, 2013 | Panasonic NN-H965 Microwave Oven
Most of the time while putting stove into the bake setting it will trip the breaker
you need to plug your unit into a power outlet that is fused higher (at least 15 amps) or if the breaker is 15 amps, you may just need to replace the breaker (they do wear out).
Mar 22, 2011 | Microwave Ovens
Went to warm up a food item and after 3 seconds the microwave shut off like the circuit breaker tripped. time face went blank, light inside does not light up and stove top lights do not light. circuit...
You have a fuse behind the screen panel. You have screws inside the microwave holding the panel. you have 1-2 at the bottom. You may also have to remove the vent. It has 2-3 screws which will be inside the vent. These can be removed from the front. Once these are removed the panel will pop off and you will see the fuse The fuse can be bought at a radio shack. BE SURE TO UNPLUG THE MICROWAVE! Good Luck
Dec 04, 2010 | GE JVM1631 Microwave Oven
Loss of power to Whirlpool over the stove AccuWave GH5184XPS-4. Checked circuit breaker and GFI -all OK. No other electrical problems known.
Remove unit and check trip/reset switch on unit. Double check GFCI receptacle with plug tester with GFCI test button.
Jan 12, 2010 | Whirlpool GH5184XPQ Microwave Oven
Turned light on. Several minutes later the light
Your unit may employ a switching power supply and these have a tendency to cease operation without warning and servicing these may require training and a piece of specialized equipment.
With the unit unplugged, after an hour or two, it is safe to open the housing and check for an internal fuse which could have failed.
If typical, these will be in a tubular ceramic housing about 1 1/2" long and 1/4" in diameter and can be purchased at most hardware stores.
Sep 27, 2009 | Whirlpool GH7155XHS Microwave Oven
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
There is no power to the unit at all circuit breaker not tripped
blown fuse-easy fix -find book-it is shown behind service panel
Nov 04, 2008 | GE JVM1651 Microwave Oven
The built-in microwave went dead as I attempted to screw in a new light. It arc'ed, then there was zero power to the unit. Is there an in-line fuse or circuit-breakers?
was cooking on the stove below the microwave and had the fan on. the nicrowave went out all together and will not come back on. it did not blow a fuse in the breaker box. is there a reset button or something to turn back on
Aug 05, 2008 | Microwave Ovens
Microwave Ovens Logo
85 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
