Only way to remove a BIOS password on any
computer is to remove all power sources from the
motherboard so its memory can be cleared.
First, remove the main
battery from the
laptop. Then you must locate and find the little coin cell battery (It looks like a watch battery) on the laptop and remove it for about a minute or so. Then you can replace them in the opposite order.
Your coin cell battery is in a bay on the bottom of your computer. Enjoy!
1.
Before removing the coin battery:
2.
Locate the memory module cover on the bottom of the system.
3.
Use a Phillips screwdriver to remove the two screws securing the cover.
4.
Lift and remove the cover from the system.
5.
Locate the coin battery.
6.
Use a fingernail (or small flathead screwdriver, if necessary) to release the battery ZIF connector.
7.
Remove the battery from the chassis.
8.
Reverse the previous steps to replace the coin battery.
