Question about Kenmore 24032\24036 Top Load Washer
Kenmore 80 series won't spin
Kenmore 80 series washer will fill, agitate and drain but NOT spin
  • 17 more comments
  • tjbon Jan 14, 2008
    Yes it fully washes the clothes and drains. It just doesn't spin. I have put in on the wash cycle with the lid open and the machine is agitating. It worked fine just before I washed an old blanket that completed disintegrated in the washer. I check the drain tube to see if it was blocked and it seemed to be clear.
  • tahkina Mar 09, 2008
    kenmore 80 series won't spin...same problem
  • danileigh Apr 12, 2008
    I have a Kenmore 80 series wash machine that is not spinning. It agitates and drains- however it just stopped spinning. It is also making this annoying noise during the spin cycle. kind of like when you are trying to open a child proof bottle with out pressing down and the top just keeps spinning. I took the load out, redistributed it and the machine still will not spin. I ended up removing the load completely and letting the machine finish its course. Note - the machine was still making that noise with out the load in it.
    I am not mechanically inclined, so I would not even know where to begin to fix this myself. Is this something that a repair man would be able to fix- inexpensively??
  • Anonymous May 14, 2008
    Kenmore 80 series washer does not spinning
    please help me out
  • unhandyman7 Jun 12, 2008
    Mine Does it too.
  • schech77 Aug 07, 2008
    I'm having somewhat of the same problem. My machine will do everything it has to, washes, drains and it gets to the spin cycle and stops. I can set the spin cycle by hand and it will work. However, it won't continue through a full cycle without setting it to the spin cycle by hand. Any Ideas?
  • sgdud Oct 20, 2008
    Kenmore 80 series washer will not spin. It does everything else. Model # 110.23812100
  • Al Cort Apr 07, 2009
    I have the same problem. The washer will not begin a spin cycle unless you initially spin the drum and it will never go fast enough to spin the water out of the clothes. When selecting between fast and slow spin you can hear the motor change speeds. The unit agitates correctly, the drain pies are clear of debris and the drain pump is working correctly.
  • Joe Smith Oct 23, 2012
    I Have a Kenmore 80 series basic washer and its been great for 5 years and now it will agitate and wash, then drain but all teh clothes just sit in the bottom soak in wet. I have to manually turn it to thte next spin cycle. Its not the worst thing but it used to spin to finish then I could throw the clothes inteh dryer. now I always have to urn it to the spin cycle and wait till its done....like 30 seconds ...hey still annoying. I'd like to fix it because I like to learn how to work on things.
  • mpar43
    mpar43 Oct 14, 2013
    Yes, me too. Kenmore Elite 80 series won't spin.
  • mpar43
    mpar43 Oct 14, 2013
    My Kenmore Elite 80 series won't agitate either.
  • Anonymous Mar 13, 2014
    doesn't agitate
    runs, spins, but agitator doesn't move
  • Anonymous Mar 21, 2014
    Kenmore 80
    series heat work but spins slowly
  • Anonymous Mar 25, 2014
    to replace belt
  • Anonymous Mar 26, 2014
    kenmore top loader 80 series will fill up and agitate but will not drain or spin
    how do I remove a stripped screw from a Kenmore 80 series
    how do I remove a stripped screw from a Kenmore 80's series aggitator
  • Anonymous Mar 27, 2014
    machine won't fill with water
If it agitates and drains. leaving your clothes clean but soaking wet. It is most likely the transmission/gearbox. the motor is working otherwise it would not agitate. it is stuck in agitate mode and cannot "shift" into spin mode. new transmission will cost 140-170 and takes 2 or so hours to replace depending on skill level. total repair cost parts+labor $300ish you may want to ante up for a new machine at this point. if you cant to the labor yourself.
part# should be this: tho double check using your own model#
Part # AP3096209
Posted on Dec 09, 2008
  • 447 Answers
Are you sure its agitating??? It sounds like the motor coupling is broken, but it wouldnt wash either. If it really does agitate than the next most common is the spin tub mounting block being stripped, or it could be a clutch or brake not realeasing issue. I do recommend you repair it though all these can be repaired for a reasonable cost.
Posted on Jan 14, 2008
  • 246 Answers
Some models will agitiate for a couple of minutes even with the lid open. Try listening when you close the lid for a "click". If it is missing you may have a bad lid switch.
Posted on Jun 13, 2008
Have the lift switch test also
Posted on Aug 15, 2008
centurionin
  • 20 Answers
SOURCE: kenmore washer 80 series
you need to check the lid switch, does it click. you can unplug and then remove the 2 screws to see it, if it looks like it is coming apart then the lid switch is bad. you can buy one for about $40 or so dollars. i am assuming it doesn't spin either.
Posted on Dec 19, 2008
blueextc3221
  • 15935 Answers
SOURCE: Kenmore 80 series, fills up andn agitates but will not spin or d
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 18, 2010
  • 113 Answers
SOURCE: Kenmore 90 Series Washer
You have a broken lid switch. Its # ll in the diagram. Part # is 3949238. Let me know if you need info on how to replace it, Dave www.washermd.com
Posted on Dec 17, 2008
onthejob5130
  • 640 Answers
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
Posted on Jan 24, 2009
  • 18 Answers
SOURCE: kenmore 80 series washer fills but does not
The agitator dogs may be broken or the transmission could be bad. Try checking the agitator dogs first. They are an easy and inexpensive fix.
Posted on Sep 06, 2009
Kenmore 80 series model # 110.82382110 fills, agitates and drains but won't spin
Based on the information you provided, you need to replace the wig wag on the unit. No joke, that is what the part is called. Here is a link to the part to order.
Nov 05, 2012 | Washing Machines
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer fills but does not wash/agitate. will spin and drain when manually turning dial to spin
Aug 31, 2009 | Kenmore Washing Machines
I have a series 80 top loader. It filled and
Screws holding the lid switch was broken. Had to replace lid switch.
Jun 11, 2009 | Kenmore 24902 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
10,637 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
