Question about Reddy HEATER RLP100 100,000-BTU PORTABLE PROPANE FORCED AIR HEATER
Ready heater 100,000 btu won't fire up!!!!!!!
I't is a older model. there are no # to call. The fan and everything blows, but it acts like it is not getting any fuel or maybe the spark plug is bad. Someone has done allot of rewiring on this thing. I was hoping for some help or maybe someone can tell me where to find a repair manual, or parts book to fix it.
Thanks BN
  • mickking Jan 16, 2008
    i have the same problem with my 100,000 btu heater. it ran today and then it just quit!!! i have never changed the filters, could that be it?
  • 625 Answers
Go to www dot desatech dot com. you should be able to find what you're looking for here.
Posted on Jan 14, 2008
I have a 100,000 BTU heater has fuel coming out the end,will not fire
SHOULD NOT BE SPRAYING FUEL OUT THE END. TURN THE PRESSURE DOWN BY TURNING THE FLAT HEAD ADJUSTMENT SCREW COUNTER CLOCKWISE IN SMALL INCRIMENTS.
Dec 25, 2012 | Reddy Heater-170,000 BTU Kerosene Deluxe
My ready heater 100,000 will run for app. 5hrs then flame out and blow smoke or unburned fuel the same several times pressure is right
If the heater continuously has a 5 hour run-time check to see if the fuel pickup tube goes to the bottom of the tank. If broken, cracked, or shortened the fuel will stop being picked up when air is sucked rather than fuel.
Feb 08, 2011 | Reddy HEATER R115 115,000-BTU PORTABLE...
Hayward pool heater H100ID keeps blowing GFI
First, I don't see any heaters in my parts wired thru a GFCI. Why did you resolder inputs on board. Usually, those are not repairs that are acceptable. If the pins have shorted, then you need to replace the board. Could be a problem with the ignitor, but this might be one that you will need to call a pro in for. Did you install the heater yourself???
May 19, 2010 | Hayward 100,000 BTU Pool Heater H100ID1 -...
I need 100,000 btu or highest btu output for an enclosed new york masony jobsite
Hi try surefire heaters lpg blows hot air all differant ranges local lp company or hire shop
Feb 12, 2010 | Reddy Heater-30-55,000 BTU Variable
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
100,000 redi heater wont fire just blower fan runs
The igniter is most likely bad.Make sure the igniter is not working,and the pump for the fuel is working,one,or the other is not working,if it is the fuel,order a new pump kit,with impelar,and if it is the igniter,replace it with a new one.
Oct 21, 2009 | Reddy Heater-70,000 BTU Kerosene w/T'stat
I have an older 100,000 btu Reddy unit that was pulsing. Put new diesel in and problem went away for awhile. Now pulsing again.
might have a clogged fuel filter. try to drain and replace. run fresh fuel. the pulse also could come from too much fuel causing a burst in the main heat exchanger. if this heater is older than ten years i would trash it and buy a new one so you dont blow up
Sep 12, 2009 | Reddy Portable Forced Air Propane Heater...
Won't light/stay on
It may be the spark plug (or the ignition module). On my Reddy Heater 50K BTU, there are six metal screws that join the top of torpedo tube to the bottom. Remove these,and the top of the tube casing. The spark plug should be in plain sight.
Turn the unit on and look for spark. If it's not firing, replace the plug. If it still doesn't fire, you may need to replace the ignition module (it's what is "connected to the spark plug via the fat ignition wire.")
Hope this helps,
Jan 06, 2009 | Dayton E50 Heater
Heating & Cooling Logo
334 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
