I was using perfectly the TV watching Dvd's movies. I tried to connect the Usb cable from a laptop to the Hdmi port on the back of the Tv. Automatically when the cable was attached to the Hdmi port, the TV turned off and never went back, I tried to unplug it from the AC conected back, and nothing.
What whas the problem, if there any solution. I dont even have 8 mo. with it.
Thank you.
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
SOURCE: My brand new 40
This is a characteristic of the dynamic backlight used on this set.Turn off the dynamic contrast in the customer menu this should solve your problem.
SOURCE: VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine.I used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
SOURCE: Buzzing noise coming from Vizio HD TV speakers
It ur Vizio tv,The power supply board is the problems.The transformers in the power supply board have gaps in the transformers.The high voltage curents flow that make that buzzing noise.
SOURCE: Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Your Lenovo laptop can be hooked up your TV if you have a model that is
capable of TV output. Newer models with HDMI ports can easily connect to newer
TVs that have HDMI input jacks. For older laptops or TVs, you will need other
adapters or cables. The most common of these is an S-video jack, which has a
small round connector with several pins arranged in a circle. For S-video
connections, you will need to hook up the audio from your laptop to your TV
separately.
Things You'll Need
HDMI cable
USB-to-HDMI
adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your
Lenovo laptop and HDMI-enabled TV.
Connect one end
of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has
these ports. If you have a ThinkPad or other Lenovo model, connect a
USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter
into any USB port.
Press the
"FN" and "F7" keys on your keyboard. This will switch the laptop's
display to the TV. You can then use your TV screen as a monitor or use the
laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your
laptop and TV. Connect your S-video cable to the laptop on one end and the TV
on the other.
Plug audio
cables into your audio out jacks on the laptop. If you do not have stereo audio
output, you can use the headphone/speaker jack. Add a splitter adapter to split
the sound into stereo instead of mono (single speaker). Plug the other ends of
the audio cables into your TV.
Turn on the
laptop and let it boot up. Then turn on the TV. Right-click on your desktop
screen, then select "Properties."
Click the
"Settings" tab, the "Advanced" button, then "ATI
displays" or "Display device" or the similarly worded option,
depending on your system. It is not the "On screen displays" option
in any version.
Click on the
option that suits your system, such as "TV" or "LCD." Click
"Apply," then "Yes" to confirm, if necessary. Click
"OK" to exit. Your display should be visible on the TV screen. If
not, try pressing "FN" and "F7" to toggle the display to
the external screen.
