Question about Polaroid izone 550W Digital Camera
Battery lasts 1 minute on full charge, wont work on computer
After fully charged battery power lasted about 20 minutes.
Since it's brand new, return it. You didn't say what type of tablet it is, but they should last for many hours on a charge.
Oct 02, 2015 | Tablets & eReaders
FULL CHARGE LAST 5MIN. MAX
My guess is the batteries are probably no good. All batteries will only last so long and it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
Jan 23, 2013 | SPOT SL5W09 Spot Light
My mp3 wont charge it says it has a full battery but when i unplug it,it lasts 5 minutes
battery needs replacement, usually the life span of battery it takes only for 2 years then depends how often it was used.
Sep 07, 2012 | Audio Players & Recorders
I perchased my rca mp3 player last month and loaded my music onto the device and now it wont turn on ,I just took it out of the package and charged it per the instructions and loaded my songs onto it but...
remove the battery from the unit then press and hold the power on button for atleast 1 minute this should reset the system then return the battery then charge the battery for atleast 2 hours just to ensure your battery is full charge..the turn the power again.The player should be ok now..
Aug 29, 2011 | Car Audio & Video
When i boot up, my Compaq CQ20 displays the message that the battery has low storage capacity. Battery time is now down to 15 to 20 minutes at full charge.
If you laptop is more than two years old then it is possible that the battery is faulty as many of the compaq laptops have poor back up battery orr quality retained.
Check the adapter on the PC , check if the adapter charges the battery to full capcity , now if this charge wont lat more than 20 minutes , you might need a new one.
Discharge the battery fully and charge few times as the last resort.
Feb 23, 2011 | Compaq Computers & Internet
Unit shuts down after about one minute.
When you leave a Nuvi on a charger for several hours and don't see full green bars, this is an indication that the battery is defective. Most Nuvi batteries last about 2 years. Most of the batteries have a date code of 2007. I would have the battery replaced as soon as possible as it can bloat and crack the case open. More info can be found here:
http://www.sharc.net/gps_battery_repair.htm
- Jim
Jun 01, 2010 | Garmin Nuvi 660 GPS Receiver
Battery Lifeline
Have you adjusted your power settings in your control panel? This is the only way to allocate how your laptop is using the battery power. Also, watching a DVD is going to take up a lot more energy then say surfing the internet.
Mar 03, 2010 | Acer Extensa 5620-4020 Notebook
1993 cutlass supreme
Are you Sure the Alternator is Fine???? Sounds an Awful Lot like it is not Charging the Battery to Full Capacity.
Jan 22, 2009 | 1993 Oldsmobile Cutlass Supreme
Minn kota turbo35 electric motor only stays on full spped for 10 minutes.
I dont know how old your battery is but they will sometimes show full charge but not last long cause of age. Try a differant battery.
Jul 26, 2008 | Boating
Polaroid izone 550W Digital Camera Logo
27 people viewed this question
Top Polaroid Cameras Experts
Damen Wong
Damen Wong
Steven Wander
Steven Wander
Marvin
Marvin
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
