My cenrtios mp3 says key locked when i push buttons but songs still play dont know what 2 do
  • Anonymous Feb 09, 2008
    I had this problem too. Eventually, I moved the hold switch
    on the left side to the off (up) position, and it now works.
Posted on Feb 09, 2008
It will not let me delete all my songs at once....I really dont want to go one at a time! Any help?
1. Go to the MSC menu
2. Press MENU button
3. When you see a song displayed in the LCD, press the Play key to pause the song
4. Once song is paused, press the MENU button
5. Select “Delete All”
6. Use the Menu left/right keys to toggle between “Yes” delete and “No” don’t delete
-Tha Mp3 Doctor
Jan 27, 2009 | Nextar MA933A MP3 Player
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Nov 03, 2008 | Nextar MA933A MP3 Player
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
Only plays ten seconds of songs
I HAD A VISUAL LAND MP3 PLAYER. ONLY PLAYED FIRST 10 SECONDS OF SONG. IT IS SET TO INTRO. WHILE THE SONG IS PLAYING PUSH THE BUTTONS AND YOU WILL SEE THE OPTIONS COME UP. SONG HAS TO BE PLAYING. CHANGE FROM INTRO.
May 31, 2008 | Centon Electronics MP4-001 MP3 Player
Messed Up.
hi what you need to do is put the mp3 into recovery mode to do this follow these instructions
1 with mp3 player off push hold/lock button to lock position(this is what you press to stop you pressing buttons when its playing it locks the buttons out) switch this to lock
2 press and hold rec button on left hand side keep holding down
3 whilst holding rec switch mp3 player on keep holding rec button untill it comes on it should now say recovery mode.
Dont do this whilst plugged into computer and dont plug into computer after its in recovery mode untill told to
once its in recovery mode got sandisk website and download the latest firmware once you have downloaded it onto your computer then open the file on your computer it will then talk you through the rest of the procedure this will solve your problem.
Let me know how you get on or if you need further assistance ok
Apr 09, 2008 | SanDisk Sansa e250 MP3 Player
MP3 player problem
heh, I got exactly the same thing. Mine is saying the player is "almost full" - it has the two songs it came with - and they work - but it wont let me copy anything from the computer. The computer knows the mp3 player is there, i used the disc that comes with it, and it still wont do anything
Mar 13, 2008 | Audio Players & Recorders
My sansa e250R not working
Hi try this for me and let me know if you can put it in recovery mode if it does go into recovery mode dont do anything just let me know then ill tell you what you need to do next ok
1. with it switched off put key lock on
2. hold down rec button on left hand side
3. whilst still holding rec switch it on still holding down rec
4 it should now say recovery mode
let me know when you get this far ok
Mar 11, 2008 | SanDisk Sansa e250 MP3 Player
Graig MP3 problem
will not connect to PC
Feb 08, 2008 | Audio Players & Recorders
Won't stop skipping songs after 10 seconds!!
WAHA i've fixed it it was on repeat intro which means it plays the first quarter of he song so pretty much try to look at the repeat button and see if it is on that.....
Jan 07, 2008 | Audio Players & Recorders
Problem
check to make sure the top slide button on the top left is not set to the locked position
Jun 14, 2007 | Apple iPod MA446LL/A MP3 Player
67 people viewed this question
 Grubhead
Grubhead
