WASHING MACHINE OVERFILLING
I have a Maytag PAV3300AWW and the water level is overfilling and will not shut off. I put clothes in it and set the machine to run. I came back 20 min later and water was running everywhere and the machine had not started. I'm leaning toward the water level switch. Any other ideas?
  • 3 more comments
  • JA0173 Jan 14, 2008
    Hi vest6,
    I spoke to a repair person today and they said to replace the water inlet valve. I would think that if the valve was bad, the water would leak into the tub. If the coil had opened, then the water would not come in at all.
    Do you know the voltage output from the water level switch to the water inlet solenoids? I'm still thinking it's the water level switch, but I am going to check the output from the water level switch before I replace it or the inlet valve. Do you know what output I should look for in terms of voltage AC/DC?
    Follow up..
    I took the machine apart and I think the plastic hose between the tub and the water level switch came off. It was off when i saw it and I was being as easy I could at taking the top off.
    I turned the washer on so it would run water in. I blew into the plastic tub and the water would stop coming in and the wash cycle would start. I reattached the tube after cutting a small piece off as it had gotten swollen and would easily slide on and off. Ran 3 complete cycles and so far no more overfilling.
    Thanks vest6 for the information!!
  • spowers May 24, 2008
    Maytag Model PAV3300AWW washer. Tube from water level sensing switch comes loose from washer tub. Reconnecte loose tube and the washer works fine. This tube has come loose twice, it seems to be made of a silicon rubber and has a tendency to come off of the washer tub nipple. The hardest part was figuring out how to get inside the washer. Just put a flat bladed screwdriver in the crack, between the front of the lid deck and the front face panel. Two friction locks hold the lid down. Pry open the lid, carefully, and then reach inside and reconnect the loose water fill sensor tube. Tube is held in place by a spring clamp. Check the clamp to make sure it is doing its job.
  • Anonymous Jul 16, 2008
    4th Time the Hose has come loose. The Third time I tried clipping about 1/4" off the end of the tube, as it seems to have streached. Then I made sure the spring clip was in the proper place to hold the hose to the tub's nipple. Since this tube is made of Silicon Rubber, I know of no glue that will adhere to it. My next attempt will be to get a longer hose so that there is more slack and less tugging on the hose by the washer tub.
    Scholar:
  • 196 Answers
Suspecting the water level switch is the first step since this device controls starting operations. There is also a possiblity that the water level pressure hose has come off the tub. Make sure this plastic line is attached before replacing the level switch.
Posted on Jan 14, 2008
  • Elmer Vest
    Elmer Vest Jan 15, 2008
    This hose has a bad habit of getting off the tub prong. If it happens again I would sugest placing a small amount of glue on the stem and slide the hose back on. This will stop it from popping off.
    And you are very welcome !
Maytag Neptune MAH6500AWW '03 front load nf code it is OVERFILLING won't shut off, water pouring out door! new drain pump last week & checked hoses in front 2 days ago. now this, help?
nf stands for no fill, so this means the washer's water level sensor is defective or plugged with dirt. That is why it is overfilling.
Nov 09, 2016 | Maytag Washing Machines
Top load kenmore overfilling
Hello there
If your washer is overfilling, check these: Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
Oct 31, 2010 | Kenmore Washing Machines
Water keeps filling up tub
hELLO THERE:
It's overfilling If your washer is overfilling, check these: Water-inlet valve Water-level switch Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve. Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
May 14, 2010 | Washing Machines
Neighbor reports It's overfilling Water on floor.
Could be a faulty water level switch ,or blocked pressure chamber hose leading to switch, or a sticking water inlet valve, question of elmination I'm afraid.
Mar 07, 2010 | Maytag PAV2300 Top Load Washer
Roper washing machine will only run one load every 12 hours!!
Jan 21, 2010 | Washing Machines
Kenmore 70 series , overfill water dose not stop at set fill levels
Jan 16, 2010 | Washing Machines
Water won't stop flowing into tub
Jan 05, 2010 | Estate Washing Machines
My maytag washer model lav3600aww continues to overfill and overflows
Hi There
I have found some stuff for you to read and hope this helps you. Let me know how it goes.
thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Maytag PAV2300 Top Load Washer
Maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 19, 2008 | Maytag Performa PAV2200
Machine over filling even when set on min. simpson enduro 701
When the machine is overfilling , it means that there is a problem with the inlet valve (valve not closing) or with the water level switch, that should turn off the valve when water reaches level.
See the suggestion from It's overfilling at repairclinic:
Water-inlet valve
Water-level switch
Oct 06, 2008 | Washing Machines
Open Questions:
Washing Machines Logo
1,610 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
