Question about NetGear WGR614 Wireless Router
I cant log into my router even though I am using the 192.168.1.1 subnet mask
  • 1 more comment
  • MissAngel Mar 19, 2008
    Can anyone tell me how I can log into my NetGear WGR614 Wireless Router and access my web log?
    Any help would be greatly appreciated.
    Melissa
  • mcrulez4life Aug 24, 2008
    i type my router ip and it just says "no search results match your document" please help me im trying to make a server
  • networkmagic May 11, 2010
    Are you using an ethernet cable from the network connection on your computer to one of the numbered network ports on the router? Verify that the link light on the router is on. For example, if you plug the cable into port #1 on the router, make sure the #1 link light is on.
    Type this in your browser address bar:
    http://www.routerlogin.net
    -or-
    http://192.168.1.1
    What is the response? Do you get an error message?
    Novelist:
    Scholar:
  • 136 Answers
Go to run type in cmd a dos prompt will appear.
type in ipconfig /all and check your ip address. Chances are your ip address is 169.x.x.x which is an internal ipaddress. You will need to manually assign an ip address To do this go to my network click on view connections right mouse click the lan icon then go to the tcp/ip config and manually assign your ip address.
It needs to be the same subnet as your router so use 192.168.1.xx anything but 1 then you should be fine.
good luck
Posted on Jan 14, 2008
How do i establish a subnet with a A address
The subnet is determined by the subnet mask. Class A addresses are contained in the following range: 0.0.0.0 - 127.255.255.255. The most common use of a class A address is 10.0.0.0
In class A networking you may use a subnet mask from 255.0.0.0 all the way to 255.255.255.255
The subnet would work as the following example:
Network Address: 10.x.x.x
Subnet mask: 255.0.0.0
The first number in the above example would determine our subnet. So if you have 2 devices and you would want to put them in a different subnets you would want the first octet (octet is each number seperated by periods) to be a different number.
Network 1: 10.x.x.x
Network 2: 11.x.x.x
Unless these devices use a router to communicate they would not "talk" properly. Thus giving you 2 different subnets.
Oct 24, 2013 | Computers & Internet
How do i find my MAC ADDRESS,SUBNET MASK GATEWAY&PRIMARY DNS NO,S ON MY D-LINK (DSL-2640R ROUTER
Click start and in the search box type cmd then press enter. You should a black window with some text, this is the command prompt. Now type this "ipconfig /all" exactly as if type with the quotes, then press enter you should now have alot of text, these are all the settings recieved from the router. You will find exactly what you are looking for here.
May 28, 2011 | Computers & Internet
I have a WNDR3400 and it serves DHCP IP addresses in the range of 192.168.2.x subnet. The routers is connected to the another local subnet 192.16.1.x I want the computers on the 192.168.2.x to be...
You need to set the subnet mask correctly on the machines so the machines can see traffic on both subnets. If DCHP is issuing the IP address of each subnet, it's also issuing the subnet mask. You should be able to configure both routers to issue a subnet mask of 255.255.0.0 and that would give your computers on either subnet visibility to both networks. Make sure to configure only one of these routers as the gateway and make sure both routers agree which one is the gateway to the Internet otherwise some of the computers won't have Internet access.
I’m happy to help further over the phone at https://www.6ya.com/expert/matt_7e951e081251ffbc
Jun 30, 2017 | NetGear WNDR3400 N600 Wireless Dual Band...
Seemlessly joining two networks
try changing the subnet on N1 to 255.255.254.0 or 255.255.248.0
Apr 24, 2010 | Computers & Internet
I can connect to the internet when I use a cable but don't get a connection when I am connected wirelessly even though it says it is connected properly
check the signal strength and check the ip address change it to the same class, check subnet mask, int gateway etc and try.
Oct 18, 2009 | Edimax BR-6104K Router (br6104k)
Cant connect to xbox live via my voyager 210 router from Bt
2 things you can try:-
1. make sure you enter the subnet mask and the gateway on the xbox
You can get these values on a connected computer
2. Try connecting to the Netgear and changing the channel if in UK try channel 4 or 7
Jan 05, 2009 | Computers & Internet
Un secured linksys router
first need to reset your router push the reset button at the back of the router for for 10 sec. then open internet explorer type 192.1681.1. enter type password admin enter ,..configure again your router enter the IP address. , Subnet mask , and DNS put the setting Static IP ,next click mac address clone and click "clone your pc mac" then click wireless at wireless network mode put it mix, at wireless channel put to the highest ghz. then after that check your line by trying to conect to the other pc using your UTP cable if it is working connect it again to your laptop
Jun 23, 2008 | Linksys Wireless-G WRT54G Router
The subnet mask
To change you subnet mask, go to control panel. look for network settings. select your internet. Right-click and properties. Look for subnet mask options (Try TCP/IP) If your subnet mask settings arent on automatic, put it to auto, if they are on auto, manually type in 255.255.255.0 (That is what is supposed to be)
Mar 23, 2008 | SMC Barricade g SMCWBR14T-G Wireless...
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
NetGear WGR614 Wireless Router Logo
359 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
