Question about RCA D52W19 52" Rear Projection Television
Everything comes on, but the projectors won't
This tv was given to me, and I have resoddered everything, and replaced a fuse. everything comes on all 4 green lights, but the projecters won't come on. What do I need to do?
  • Lizard701 Jan 14, 2008
    RCA PR1908B102 model
    RCA twin tuner pip
    is there diagram or something that I can look at to see what is what, so I know what I am lookig at.
  • RCA Master
  • 8,617 Answers
What model TV do you have?
Posted on Jan 13, 2008
  • Sonny Berry
    Sonny Berry Jan 14, 2008
    If the fuse was blown origionally. Check the horizontal output and low voltage regulators for being shorted.
  • Sonny Berry
    I dont have the service manual for that model. However the Horizontal output transistor is always located near the flyback and is mounted onto a large heatsink. The low voltage regulators are slightly smaller than the H output, also mounted to small heatsinks.You may be able to get a manual online at one of the manual sites. You have Chassis number ITC222 its pretty hard to find.
I replaced an apparent blown fuse, TV still won't power on.
Most likely your power supply is damaged and will need to be replaced. Sometimes, power supply manufacturers add additional "fusible resistors" to provide additional protection.
Jan 05, 2013 | Magnavox 19MF330BF7 19 in LCD TV
My viewsonic 3d projector won't turn...but it has
You should replace the lamp it is already damage, when you replace the lamp do not forget to reset the lamp hour meter.
Aug 22, 2011 | ViewSonic Televison & Video
We have a Notevision Sharp LCD projector, PG-C30XU and can't figure out how to open up the insides of the projector to replace the fuse. Or even where to get the replacement fuse.
http://elektrotanya.com/sharp_pg-c30xu.pdf/download.html
Above is a download for your service and repair manual, this will show you everything you need to know to do with this printer.
Replacement fuses, and parts, are easy to obtain, simply Google the parts number, obtained from the manual, and you will find a number of suppliers, simply choose one you like, and get it shipped to you.
Nov 15, 2010 | Sharp Notevision PG-C30XU Multimedia...
I have a Canon LV-7350 that comes on for 15 secs then turns off.. everything is hooked up correctly. and I have swiched out the bulb to rule that out.. anyone ever seen this?
Hello :
It must be overheating problem . Check the fans . If the fans run properly , then you need to check the fuse or the power PCB [printed circuit board ] . If everything is okay with all of those , then I recommend you to replace the bulb .
Here I'll tell you how to replace it :
  1. Make sure that your power switch is off and that the power cord is unplugged from the electrical socket.
    It is also wise to unplug any other cables and label them in order to restore them in the right way once the lamp is replaced.
  2. In order to see the lamp, remove the access handle on the outside cover. You may need to use a screwdriver.
  3. Pull out the used lamp and clean the relevant parts using micro fiber products and not paper.
    Please note that in some projectors a small inside filter should also be replaced.
  4. Insert the new lamp into the projector carefully avoiding touching the glass of the lamp itself.
    Touching the lamp will deposit skin oil that will likely damage any new lamp during use.
  5. Reassemble the access panel, repluge the cables and power up the projector.
Things You'll Need:
Warning:
  • avoid touching the bare projector lamp
please rate !.
Apr 12, 2010 | Canon LV 7350 Multimedia Projector
When I move the projector, it lamp will not come on.
there is a short in the projector somewhere. but that model has an issue with the power supply and there is no replacement parts available.
Nov 02, 2009 | InFocus LP 250 Multimedia Projector
Replaced the projector lamp 3 weeks ago. Reset
If the lamp is working it should be fairly obvious but stand to one side of the lens and see whether there is any light coming from the projector. If there is you know that it's an input problem. If there isn't either a fuse has gone, the bulb has blown or the filters might need cleaning. If the bulb has blown it's probably because you handled the bulb. It's vital not to touch these bulbs with your fingers. If you do wipe it with methylated spirits.
Aug 21, 2009 | Sharp Office Equipment & Supplies
Power does not work
ok " always check power first, sounds like internal fuse
has blown , just has to be replaced.
Jan 20, 2008 | Optoma MovieTime DV10 Multimedia Projector
How do we know the Elmo is on?
use another power cabel-dissconect from outlet and check for broken fuse-if everything is ok.change exposure lamp.
Oct 09, 2007 | Elmo Projectors EV-200 Slide Projector
RCA D52W19 52" Rear Projection Television Logo
48 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
