Question about Hitachi 43F300 43" Rear Projection Television
Can't find the "service only switch"
Hitachi model 43FDX01B
I had the back cover off and looked all over the deflection and power PCB, but I cannot find the "service only switch." I need to push and hold it while applying power to reset convergence RAM. Where the heck is it?
    Sergeant:
    Champion:
  • 301 Answers
Take the front panel off behind the speaker grill and it will be a small button manybe blue or white and that is the button your looking for. it is at the front of the board and you can only press it when the tv is on to go into service mode.
Posted on Feb 22, 2008
Color has changed to green tint
    According to the system the problem in your projection is convergence and the solution is to replace the IC STK's.The part Number is CZ01341. Change the IC STK both and your TV work fine again.And for parts please see the link below.
http://jr.partsearch.com/Model/Hitachi+Ltd/Hitachi/43FDX01B.aspx?SearchTerm=True
   Thanks.
Jan 09, 2010 | Hitachi 43FDX01B TV
Dead set
Check for blown fuse EP91. If the fuse is blown, check for a shorted IP01 regulator transistor in the deflection power supply. If that is shorted, change the IP04 photo coupler and leaky D05 a 12 volt zener in the OCP circuit of IP01. If this all looks good, look for an oily fluid on the printed circuit boards under the picture tubes. Good Luck
Jun 21, 2007 | Hitachi 43FDX01B TV
Hi,I have a problem with my Hitachi TV, The problem is deflection PCB, part # JT23274, model #43fdx20b, How much is cost to repair?
Hi, i'm a technician in florida.
The cost for me to referb a deflection assy is
289.50 plus tax.
i'll give you a nice tip...sometimes the convergence circuit temps to load the power supply...try to fix the convergence circuit first...then see if that fixed it.
convergence ic# stk392-110...try the stk392-120, they are more reliable...my e-mail bhzrdg@yahoo.com
Oct 08, 2009 | Hitachi 61SWX10B 61" Rear Projection...
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms
This might not be your model but you should contact them to see if the have the parts I know they list the manual
Feb 18, 2018 | Hitachi 43FDX01B TV
TV Want Power up
This tv have different causes for no power.
Can you tell me if any light on the chassis is off?, if so, let me know the location part number.
Common problem is IC output ( short) or convergence STKs ICs.
Thank you
Jul 26, 2009 | Hitachi 43FDX01B TV
Hitachi 43FDX01B (convergence) problem
Convergence IC's must be changed to start repair..original...
STK392-110 sub to Hitachi upgrade STK394-160E.....PART #
CZ 01341...you need two....
Next, take a critical look at the B+ feed resistors near the IC's..
check for over-heat / damage......usually 2.2 ohm 2 watt......
Let me know....................T.
Jan 03, 2008 | Hitachi 43FDX01B TV
as the problem cannot be the rectified by the user. as it may require authorised service personnel. the problem might be with Tuner,video processing circuits. also mainly with the deflection circuits
Dec 20, 2007 | Hitachi 43FDX01B TV
Blue wave shadowing
The convergence Ics need replaced. In Hitachi, resistors and sometimes a coil needs replaced as well. The convergence/deflection PCB is available, but, the cost of that board is higher than having a servicer come to your home and repair the unit to component level. If you are not familar with this circuit, then call a servicer. Have them replace both ICs not just one. Make sure they are repairing to component level and not replacing the board. Hope this helps.
Feb 08, 2007 | Hitachi 43FDX01B TV
43fdx01 hitachi
possible convergence overdrive from the IC's. This will cause the symptom you describe. ....accordianman
Jul 17, 2006 | Hitachi 43FDX01B TV
Hitachi 43F300 43" Rear Projection Television Logo
95 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
