Question about Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum
Spin Scrub Brushes won't turn
I hae a hooer spin scrub and the brushes stopped spinning. I can't find a way to open the bottom. I saw a prior problem but no satisfactory answer.
    President:
  • 1,673 Answers
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Posted on Jan 14, 2008
How do you get the broken piece of the brush block out of the turbine on a Hoover Spin Scrub Model #F7429-900
Posted on Feb 01, 2012
  • pamsiebert
    pamsiebert Feb 01, 2012
    how do you get the broken piece of the brush block out of the turbine on a Hoover Spin Scrub Model #F7429-900
Hoover F7410-900 Steam Vac Dual V scrub brushes not working
If the brushes will to spin when you try to turn them by hand remove them from the machine. If the brushes spin ok after removing them the the turbine assembly is seized up and will likely need replaced. If the brushes won't spin when they are removed from machine take the plastic cover off the brushes and clean out the gears.
Nov 03, 2013 | Hoover F7425-900 SteamVac V2 Widepath...
Does the Hoover F5835-900 have spin scrub brushes?
No. The F5893-900 has a brush but it is just a straight brush and does not spin.
Jul 18, 2010 | Hoover F5835900 Upright Steam Vacuum
Help. The brushes on my Steam Vac Spin Scrub
If you don't have the user's manual for the machine, here it is:
www.thinkvacuums.com/pdf/uprights/Hoover_F5914900.pdf
Check your system for any obstructions that could possibly causing the problem. Also, remove the brushes and see if there's a problem between the brushes and the motor.
Aug 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My spin scrub brushes don't spin at all.
Check that the belt that spins the brushes is not broken, also that the
gear that drives the belt is turning.
Tom
Aug 10, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
Spin-scrub brushes do not spin
hello. there is a little window by the brush control. if you open it up, you can see that there is maybe some lint covering it. scrape that off, and try again. make sure your lever is set to brushes and realease the handle release. if this doesn't work, then you probably have a problem with your gear box. this can only be serviced at a repair shop. I hope this helps. Let me know! Thanks, Renevacdoc
Jul 23, 2009 | Hoover F7431-900 SteamVac Vacuum
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Brushes won't spin
The brushes are turned by belt and/or motor.
Mar 09, 2009 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
Hoover H3030 FloorMate SpinScrub 500 Upright Wet/Dry Vacuum Logo
1,088 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
