Question about Denon AVR-1708 Receiver
Sound problem I just installed a clarion vrx935 in my 07 tahoe but after it plays for a little while the sound cuts out. it does it either on low volume or high volume and usually if i turn the unit off and on the sound comes back on but it goes back out again. Any advice???
  • 27 Answers
7 out of 10 the heat sinks are to small for the unit in a tight dash...Sony does the same ...I had one and make shure all speakers are in fase...+on+..- on -
Posted on Oct 30, 2008
    Scholar:
  • 67 Answers
Make sure all speakers that are hooked up sound ok. If any of them sound lower then the others or sound distorted you may have a speaker with a partially shorted voice coil. If speaker or speakers pop when power is first applied you may have a grounded speaker that should not be grounded. Each speaker wire rides on 6vdc and if any speaker sees a ground you will have 6v across voice coil which would explain any popping noise when first turned on and radio may play for awhile then overheat. be sure speakers are 4 ohm min per ch otherwise amp will run to hot. Just a few Guesses
Posted on Jan 14, 2008
I have a clarion vz400 in a 2004 doge truck with an infinity sound system. It plays sound well through the radio and bluetooth but when you try to play a dvd or iphone through usb there is no sound. What...
your unit are not compatible to each other. try other usb that can compatible to the unit Clarion. Option use audio jack like earphone jack and RCA jack if you don't want to replace your DVD and Iphone
Aug 15, 2011 | Car Audio & Video
I have a Clarion XMD2 Marine radio. When I play the radio or a CD, there is a low level "static" sound that plays over the music. I thought the power feeds or ground were bad, but direct wired...
I didn't suspect that the fault came from the speakers but in the unit itself. This kind of symptoms indicated of faulty electrolytic capacitor in the power supply section and/or in the sound output circuitry. To isolate it, you must have a capacitor checker to determine its condition or you may replaced all the electrolytic capacitor in your unit because this is only few in the set and very cheap price per piece. Just remember that you must replaced it with same capacitance and working voltage that is labelled in the body. Also, upon installing, you must check the polarity (positive and negative side) to avoid further damaged.
Also, check for bad solder joints(crack/dried/cold solder) in the board, it will produced the same symptoms.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
May 16, 2011 | Clarion XMD2 CD Player
Sound cut off while playing videos
in that case sound card driver not installed properlly please reinstalled it
May 09, 2010 | Intel D845GVSR Motherboard
Clarion DRB2475 mutes when I turn up the volume
Sound like one of your car speakers is faulty, try using the fader and see if it still happens when all sound is to the front or rear and try left and right.
Nov 16, 2009 | Clarion DRB2475
Starting problem
Do you have a security light flashing? Sound like a theft system problem. Some 1996 Tahoes had passlock.
Jun 01, 2009 | 1996 Chevrolet Tahoe
Vrv785bt- No sound except tuner
sounds like u have a premium sound system. what u need to do is take ur blue/white remotewire to ur blue power antennat that should activate ur factory amp.
Apr 16, 2009 | Clarion VRX785BT Car DVD Player
Trying to install into a 2002 Tahoe. Everything works except I get no sound. I looked up wiring diagrams but nothing shows a factory amp. Stereo works fine I installed it into mustang just to make sure.
Here is the wiring diagram. The factory amplifier is behind the glove compartment on the right. Just open the glove compartment, push in the right side so it swings down (take things out of it first), and the amp is right there.
2000 Suburban Wiring Diagram
(It's for the '00 Suburban/Tahoe, but the wiring did not change from '00-'03.)
Feb 19, 2009 | Clarion VRX745VD Car DVD Player
Sound problem
what model is this? the very first thing i would do is make very sure you dont have a speaker wire shorting out on metal/rubbing/2 wires touchung togther somewhere. this is very bad. If this is a vrx935 id also try wiggling the "din" cord (its a blue cord with about 20 wires inside) between the brain and thwe head unit with the cd playing.. if the audio cuts in/out while wiggling that cord youve found your problem. If you cant figure it out and get sick of it i do buy old clarion dvd players for parts id love it for parts. let me know how it goes! mike bigmikeselectronic@comcast.net
Dec 25, 2006 | Clarion VRX935VD Car DVD Player
Denon AVR-1708 Receiver Logo
291 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
