Question about Craftsman 17765 Canister Wet/Dry Vacuum
3.0 h.p. wet/dry vac
I think I overloaded the dry filter and the motor quit. Is there a reset? I took it apart hoping for something obvious, no go. Tested switch it was o.k. Any thoughts. Probably 15 years old and abused. Steve
  • Anonymous Mar 20, 2014
    i used it for about 1/2 hour & suddenly it started making a high pitched noise?
    President:
  • 1,673 Answers
Check the motor brushes, either worn down or dust is keeping one of them from laying on the armature. The other would be a bad motor.
Posted on Jan 14, 2008
Mini shop vac
There is a hidden thermo fuse in the tape on one of the field windings. If it overheats that fuse will blow and the motor won't run until replaced.
May 22, 2013 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I can't find the owner's manual to our shop vac. What's involved in converting it from a dry vac to a wet vac? I think it does both, but I've only ever used it to clean the car.
generally you remove the filter and just use the foam sleeve (if it has one) it should have a float ball in a cage under the filter. this is to keep the water from going into the motor if it gets too full. That is pretty much it. You should have it plugged into a GFCI outlet when using it for wet pick up, also do not pick up flammable or hazardous liquids.
Jul 23, 2011 | Shop Vac 5841627 Wet/Dry Vacuum
I bought my first craftsman 9 gallong wet/dry vac - i do not know how to operate it and I don't want to break anything. I have a pamphlet but it is still confusing. can I pour a few gallons of water into...
Hello again.
When it says wet vacuuming, it means that the vacuum will pick up water, not dispense it. When you are using the vacuum to pick up water, you'll need to remove the paper filter element under the motor, inside the canister, to avoid ruining it. When the filter is removed, you will see a plactic ball inside a cage under the motor. It's purpose is to float up on the surface of the water being vacuumed up, and prevent the motor from getting water into it. You'll be able to tell when the canister is full; the noise the vacuum makes will change and sound higher. Also, the suction at the hose will quit. At that point, shut off the vacuum and drain the water.
Be sure to replace the paper filter when you swap back from liquids to solids.
Best regards, --W/D--
Apr 02, 2011 | Craftsman 17026 Wet/Dry Vacuum
Power cuts maybe after 10 mins use, then after switching off for an hour or so, it works again! repeat.
I would think that it is probably a motor going bad and tripping the overload switch. After the overload resets, it will run again. Is there a chance that the motor is still under warranty? Some vacuum maker warranty the motor for longer than the rest of the vacuum (Dirt Devil is 6 years on the motor) so hopefully they will fix it for free. One other thing, should be obvious, but I'll ask anyway -- the brush is turning properly and the vacuum has suction when it is working, right? if something is jammed that could overload the motor as well.
Nov 19, 2009 | Vacuums
Using shop vac 52722-90 for wet applications
yes, the foam filter is what you should use, also make sure you remove any bag, or paper filter, the water would make it fall apart.
Sep 16, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
Craftsman 17765 Canister Wet/Dry Vacuum Logo
204 people viewed this question
Top Craftsman Vacuums Experts
Andrew Taylor
Andrew Taylor
Vernon Taylor
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
