Question about Whirlpool LSB6300PW Top Load Washer
WASHING MACHINE MODEL#LSB6300PW WITH MOTOR RUNNING TUB IS NOT SPINNING ON SPIN CYCLE
  • Anonymous Apr 14, 2008
    Washer will agitate, but it will not spin.
Yes it agitates, but not spin
Posted on Apr 17, 2008
    President:
  • 1,314 Answers
Try it on wash and let me know if it agitates hold my rating till were through please
Posted on Jan 13, 2008
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Dec 24, 2012 | Maytag Neptune MAH5500B Front Load Washer
My washer will spin but very slowly. Motor and shaft spins out of washer.
Your problem sounds like the drum/tub drive clutch is worn. Especially if the motor operates fine and attempts to spin the tub. This model is a direct drive unit, no belts, so if the motor operates during the spin and drain cycles but the tub is barely moving, only two problems can cause this, bad clutch (which is engaged only during the spin cycles) or worn drive coupling on the motor. If the coupling were a problem, though, you would also notice sluggish or erratic agitation during the wash cycle.
Hope this helps
kcomp1863
Jan 04, 2011 | Roper RAS6233KQ Top Load Washer
Making constant buzz, tub not moving, will not finish spin
you need to replace a component called the"capacitor".this should solve the problem.
Nov 01, 2009 | Whirlpool LSB6300PW Top Load Washer
Washing machine will not spin
Hi, If this model has a belt, you might need to replace it. Once the belt gets wet, they are ruined. If the motor runs during the spin cycle and the tub does not turn, it is most likely the belt. If the motor is not running in the spin cycle, we need to look at other causes. If I can assist you further, please get me a model # so I can see exactly what washer you have.
Thanks
Vic
Jul 17, 2009 | Washing Machines
My washing machine will work on the wash cycle but will not spin.
if no sound in spin cycle, lid switch. if motor is running but no spin, motor coupler is likely. or foreign object is physically holding tub ie nail on tub hole etc.
Jun 12, 2009 | Kenmore 25852 Top Load Washer
Tub will not spin.
Replace the direct drive doupling on the motor.
This video explains how.
Mar 31, 2009 | Whirlpool WET3300S Top Load Stacked Washer...
The tub will not spin in the rinse cycle
This sounds like a timer problem if it will spin in other cycles. If you hear a motor running but no spin it is the motor couple.
Mar 12, 2009 | Whirlpool Washing Machines
Lsb6300pw whirlpool topload
does it wash have you tried on wash since youve had the spin promblem
Jan 13, 2008 | Whirlpool LSB6300PW Top Load Washer
Tub full
your pump maybe the problem if you need help on accessing it plz let me know
Oct 16, 2007 | Whirlpool LSB6300PW Top Load Washer
Washing Machines Logo
152 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
