Question about Whirlpool 24 in. ADP6940 Dishwasher
Long Cycle times on ADP6940/5 6th Sense Dishwasher
I have a problem with my dishwasher, where when it is first turned on it shows something like 3hr 20 mins on the display for a wash cycle. This is when there is only a standard load. During the wash cycle it can sometimes add on extra time and on a bad day takes up 4 hours for a complete cycle. The dishes come out clean, but why is it taking so long to complete When the door is open after the cycle, there is plenty of steam, so I imagine it is getting to correct washing temperature. I have checked things like the filter and the sensor area in the filter base, they are spotlessly clean. I suspect it may be the micro controller board!. Are there any other sensors to check. Any help would be great as this is a real puzzle.
Many Thanks
Trevor
  • trevvy Jan 17, 2008
    I have had the dishwasher for a couple of years. It has only been a problem for about a month. As suggested I have powered it off several times. It seems every time I switch it on, the display show 3hrs + cycle time. I have removed the control board and connectors and examined the board for bad soldered joints. All appears to be O.K!. I have checked the water input and it is filling O.K. When the machine is on during a cycle at times rather than counting down, the program adds more time. The program used for most washes is the 40-70 degree wash.
    So unfortunately I am still no further forward!
  • trevvy Jan 20, 2008
    I have some further information as shown below:-
    Genius:
  • 1,067 Answers
It is that micro controller bord i had one did same thing to i changed that well close buddie has that same model he did it so getthat bord done
Posted on Jan 20, 2008
  • Anonymous Jan 20, 2008
    reaosn why steam in ther mesed bord up leaking in sumware heat issue ok
    Sergeant:
    Champion:
  • 209 Answers
It might not be getting enough water.
Try fully taking power off of the dishwasher and turn it on/off a couple times.
If its your board, it will take a while to fix it,first check the main settings on your front display then try locating the board and check for any switches or knobs.
Did you just get this dishwasher ?
If you've tried this things with no luck, respond with more details.
Posted on Jan 13, 2008
6ya staff
SOURCE:
Dishwasher continues to wash.
the timer motor run contacts are stuck together
Oct 15, 2015 | GE 24 in. GSD5500G - Multiple Color...
Water doesn't heat up and cycle seems to be stuck, candy DFI 45
What is a Candy brand dishwasher? Made in the UK? That is not a manufacturer I have ever heard of here in the US.
What do you mean, 'doesn't seem to heat up any sense?'
If the dishwasher is older than 5 years, write it off to age a buy a new, high quality machine. Or do the dishes by hand.
Machines get old and die. If you are UK native, don't buy anothre Candy.
Aug 19, 2014 | Candy DFI Plan Built-In Dishwasher
Need reset sequence for dishwasher
see this causes, use the common sense.God bless you
Dishwasher Stuck in a Cycle If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 19, 2012 | Whirlpool DU1055XTS Built-in Dishwasher
Controls on front
reset the whole thing press heatdry normal heatdry normal try that
Jul 10, 2010 | Whirlpool 24 in. GU3200XTP Built-in...
My bosch dishwasher beeps everytime we close the door.
Better switch of till you are ready with full load. Otherwise you have to trace the beeper and disconnect it.
Apr 12, 2010 | Bosch 24 in. SHY66C05 Stainless Steel...
Dishwasher turns on, begins to sense, proceeds but no water
replace inlet valve after you check and make sure nothind is under basket example fork hung under float
Jan 29, 2010 | GE Dishwashers
I have a hotpoint aquarius sdw60 with the eco 45 light flashing fast and will not reset I have tried turning off the power I have stripped the pump this was clear. then reinstalled it but it is still same
I have a Hotpoint Aquarius SDW 60 The delay 3hr &12hr lights are flashing at the same time. Machine won't start. If the door is slamed shut. It get stuck on the Fast & Prewash 40 degree cycle. and stays there.
Jul 13, 2009 | Hotpoint 24 in. FDW60 Free-standing...
My dishwasher does not completely drain. It leaves about 3 inches of standing water. What could be causing this?
Without knowing the model of this GE ? dishwasher, it is very hard to be specific. Most DWs have a float/switch that sense when the dishwasher is filled and empty of water. They can fail.
If you can run a cycle without the dishwasher over flowing but it simply does not fully drain, I would pull the lower spray arm and the filter beneath that arm. Look closely for debris that could be blocking the pump. SOme dishwashers simply have a timer that controls each phase of the wash, including the drain cycle. If something is blocking the drain pump, an obstruction could cause this problem.
Good Luck, Please report back with what you find.
Apr 05, 2009 | GE Dishwashers
Dishwasher problem
Hello ramsey06,
Welcome,
You said , dishwasher starts everything is going OK. the water is going but then it stops and does not finish.
First: this is what Whirlpool says!!
And after this Is what the repair manual says when I looked it up for you!
Dishwasher is not operating properly
1.Dishwasher does not run or stops during a cycle
Is the Start/Resume indicator flashing? Opening the door or
interrupting the power stopped the cycle. Close the door and
press START/RESUME.
2.Does the Start/Resume indicator flash 3 times when you
press START/RESUME? The dishwasher is waiting for you to
open the door after the last cycle. Open and close the door,
then press START/RESUME.
3.Is the door closed tightly and latched?
(NOTE: On models with a dual-digit display, the control
displays “- -” during a cycle if it believes the door is not
latched.)
4.Is the right cycle selected? Refer to the “Cycle Selection
Charts.”
5.Is there power to the dishwasher? Has a household fuse
blown, or has a circuit breaker tripped?
6.Has the motor stopped due to an overload? The motor
automatically resets itself within a few minutes. If it does not
restart, call for service.
7.Is the water shutoff valve (if installed) turned on?
It is normal for certain cycles to repeatedly pause for several
seconds during the main wash.
___________________________________________________________
BUT, the repair manual says this
Faulty Pump and Motor Assembly Some models that will not wash or drain often have a faulty Pump and Motor Assembly. If the motor is receiving power from the timer and it is not operating that is the case.
Temporary Work-around:
With the power turned off to the unit, sometimes it is possible to manually rotate the cooling fan on the motor assembly. In certain situations where the dishwasher has set idle for a period of time, this may free the bearings enough that the unit will begin to operate. Where this works as a short term solution in some cases, it is often a sign of things to come. The frequency of the motor seizing will increase until it will simply no longer work.
I think this is a hands job that needs service and hands on attention!
I hope it's not the motor or pump!
How old is the machine?
If they tell you it is an expensive motor then you need to know this!!!!
Here is an article I just read!
If the dishwasher is old it will not pay you to repair the
Here is an interesting report I just read!!!!!!!!!!
Repair or replace?
When to pull the plug on your old dishwasher
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your dishwasher,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your dishwasher is under warranty or less than four years old ,
paying for a repair makes sense.
Note that dishwashers under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your dishwasher is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new dishwasher.
Data also shows that it doesn't pay to fix a less-expensive dishwasher
eight or more years old.
Thanks to better recycling programs, less than 10 percent
of dishwashers you replace are likely to end up in a landfill.
Let me know how it goes!
Thanks for giving me the opportunity to help!
Huuum
Please do not forget to give a rating before you sign off!
Oct 20, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Zanussi DE6755
This is for the right model, but is the UK version, all should be the same but power supply details might differ if you are in US etc. http://www.serviceforce.co.uk/pdfs/U23297.pdf Hope this helps :)
Mar 05, 2007 | Zanussi 32 in. DE6755 Dishwasher
Whirlpool 24 in. ADP6940 Dishwasher Logo
188 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Bruce Denton
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
