Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Overfilling Whirlpool cabrio washer
About every third load the washer keeps filling so it overflows, and is showing the "LF" code.
  • 7 Answers
Great! It may be the water level control switch. So, where is it and how do you check it or fix it or replace it?
Posted on Aug 22, 2009
    Scholar:
  • 196 Answers
The "LF" is the code for long fill time. Best bet would be to check the water level control switch.
Posted on Jan 14, 2008
Whirlpool LF code reset
The Long Fill code occurs when the washer takes more than ten minutes to fill. Although the replacement level sensor could be defective, it is more likely a control board defect because of the timed fill.
Feb 03, 2017 | Whirlpool Washing Machines
What is the LF Code my washer puts out
Hi Sherry,
The code definition for LF is a LONG Fill (F30). What does that mean is the next question? Here goes.
a. The fill hose may have a pinch or fold between the connections on the pressure in .
b. Are the hose screens plugged at the connections.
c. Is the water siphoning out of the drain hose ?
d. Is the water pressure at peak, check valve, filters before washer.
Now if your savvy hungry. Here is a learning curve link
Washing Machine Diagnostic Test Error Codes Cabrio Bravo Kenmore Oasis .
Okay. The next link is for the manual for your favorite machine. Manuals and Troubleshooting Whirlpool Whirlpool Cabrio Washer Fault Codes . I tried this and you need registration.
I decided to go one step further and track down a printable and savable resource for you. Yes, all, the fault codes and what they mean.
I did pretty good from memory but that link leads you to a printout you can keep right by your washer. Most of the occurrences are easy to fix without a technician. Hope this makes your day. Better. Fare. Well.
Jun 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
What does whirlpool duet error code lf?
Lf or long fill could be a multitude of many. Is the water turned on, is the hoses kinked , the water inlet screen clogged, water lines crossed, bad or faulty water inlet valve, or faulty pressure switch.
May 01, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Code lf keeps popping up
lf code means long fill. If the water fill time exceeds 10 minutes, the water valves are turned off and lf is flashed. Press STOP/CANCEL to clear the display.
Mar 24, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is the lf code on the cabrio washer?
FL Flood Condition FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Mar 06, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What does the code Lf mean?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Feb 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What do I need to do to fix the Lf code problem on my oasis washer?
Following is the LF troubleshooting response from the Whirlpool Cabrio
Service Manual. The Cabrio is the same as the Kenmore Oasis.
“LF” (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Are both water faucets turned on?
Is the drain hose sticking too far into the
standpipe (siphoning)?
Is the pressure transducer hose kinked or
dislodged?
Press PAUSE/CANCEL to clear display.
It takes a while to load but following is the manual in PDF format.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Dec 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
The washer is showing a code of LF what does this mean
LF Long Fill
Oct 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer has LF error?
Lf means Long Fill This error code is displayed if the control failed to save cycle information during a power failure. This does not generate an error code beep.
Press STOP/CANCEL to clear the display. Good luck
Oct 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio washer is leaking water
The problem happens when your installer throws away the drain hose u-bend, and stuffs the hose as far as it will go down the drain pipe. When this happens the end of the hose can get pushed under water, which causes the washer to siphon out the wash water when it fills. This results in an LF "Long Fill" error.
The solution is to get your installer to come back and install the washer properly.
Jun 23, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
1,474 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
