Question about LG WD-12126RD Front Load Washer / Dryer
Need to change the whozit for propane gas on our new dryer.
The manual doesn't show how to remove the front of dryer to get at the place to change it.
  • 196 Answers
Before going any further, tilt the machine back and see if there is an open bottom or cover plate. The front should not be removed unless absolutely necessary.
Posted on Jan 14, 2008
Need to convert from natural gas to propane
Take 3 screws out of bottom side of Z shaped metal part on the back of the dryer's top. Stand in front of dryer and use the palms of your hands to sharply push dryer top back about 2 inches and lift top off. Open door and remove screw at 4 and 8 O'Clock position. Remove control panel (ususally 2 screws and a bunch on retaining plastic parts along the top side) and set on top of dryer or unplug electrical plugs and set aside. Remove screws at top of front panel. Unplug light bulb and door switch. Tilt front panel forward and lift off bottom tabs, then unplug moisure sensor wire at bottom, allowing front panel to be set aside. Remove 4 screws at sides of drum support assembly, lift up and off. Release belt, and remove drum. (easier to do if flat metal part originally right behind control panel is removed first) Use belt as a handle and lift drum out of dryer, allowing access to burner assembly. Change burner orfice and regulator blocker. Re-assemble and test.
Nov 18, 2011 | LG Dryers
How do I get to the gas fittings to change from natural to propane
Try searching for the DLG5932W Gas Dryer manual there is a page that shows part numbers and how to info.
Feb 18, 2011 | LG DLG5932W Gas Dryer
Need to change from LP to propane. How do I get access
Gas to Propane requires a Propane Certified technician. These technicians are provided by the company that provides Propane that they will be using.
You may need to get a Propane conversion kit, for technician from the Propane company to install.
You can certainly double check on this...Hope this helps.
May 01, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Do I need a part to convert my Maytag gas dryer/washer combo back from propane to Natural Gas?
Yes you can, but whether you should is another matter. I purchased a new dryer and needed it to be propane need to get the proper orifice (which lets the gas in to the burners) changed out. Natural gas orifice has a larger hole than a propane orifice. In addition, the regulator must be modified. It may involve flipping an insert under the cap (typical of stoves) or it may require conversion parts packed in the conversion kit (order one specific to your drier). This regulator is part of the piping within the back of the drier.
Incidentally, conversion orifice(s) should be included with the drier and screwed to the body in a clip. When you change it over and label the equipment as converted to propane, put the old natural gas orifice in the clip and screw it back onto the body. Put the instructions in a paper envelope and tape to the outside of the body of the drier.
Apr 27, 2010 | LG WD-3243RHD Front Load Washer / Dryer
I need to change the jet from natural gas to propane which I know how to do, but how do I get into the box. Clearly the front panel comes off but how?
two screws on the bottom front and then the panel tilts up, remove door first and also the screws from the inside of the panel
Aug 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
How do you convert back from propane to natural gas, I already have the orifice but don't know how to put it on?
If you have the rear control dryer you posted under:
1. Unplug power to dryer.
2. remove two phillips head screws behind door, just in front of lint filter.
3. Use putty knife to push in dryer top release clips at seam with dryer front, about a inch in from each side.
4. Swing top up and remove two phillips screws holding front onto frame at very top of front panel.
5. pull front panel forward a bit and remove plug to drum light and door switch.
6. lift front panel off dryer.
7. Turn off gas shut off and remove burner / valve assembly.
8. Replace orifice and change out brass pressure regulator screw.
9. reassemble and test.
Aug 06, 2009 | LG DLG5988 Gas Dryer
Whirlpool gas (Propane) dryer
Hi, Remove the small plastic cover on the front lower right hand corner. Start the dryer and see id=f the ignitor glows. If the ignitor glows and shuts down before igniting the flame, follow these instructions. UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto.
If I can assist you further, please let me know.
Jun 19, 2009 | Whirlpool LER4634J Electric Dryer
How to remove the front cover of my samsung front load gas dryer
take the top off first by removing the two screws in the back, then the five screws which hold down the door section. the door will lift off and then follow the instructions
Jun 08, 2009 | Samsung DV448AGE Gas Dryer
LG gas dryer to convert in propane
If you replaced the orifice on the gas valve, then you must screw down on the adjustment screw on top of the valve.  Use a flat screwdriver and screw down the pressure adjustment screw till it stops in the down position.  Then the valve is set for propane use.
May 05, 2008 | LG WD-3243RHD Front Load Washer / Dryer
LG WD-12126RD Front Load Washer / Dryer Logo
64 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
