Question about Gigabyte GA-M61P-S3 Motherboard
Motherboard everything is connected correctly and turns on but no video and i have onboard video
I had the same problem,
i checked and rechecked everything,
but my solution was to put all my 2 sticks of ram in slots 3 and 4, see if that works.
Posted on Jan 23, 2008
    Genius:
  • 1,601 Answers
Make sure that it is enabled in the BIOS. Check VGA cord for bent pins.
Posted on Jan 14, 2008
Onboard sound lost after video card installation
If your PC had an onboard video card before this, you may want to go in and make sure you have disabled it in the BIOS. This has happened to me before.
Nov 21, 2013 | Biostar P4M900-M7 Fe VIA P4M900 Socket 775...
No video on monitor. Powers up, looks like everything should work but nothing on the screen. The Geeks at Geek Squad say it's a bad motherboard.
Remember before you attempt this there must be no power going to the computer.Do you have a onboard video or a video card installed.If you do,where is the monitor pluged in?on the onboard or the installed card.If you have onboard remove the other card.See if you get video.If not check the memory.
Mar 22, 2010 | ASUS Striker Extreme Motherboard
Got a flickering in my video, installed brand new Video card. No change. Unplugged everything, except monitor (I meam mouse & all). Still flickers Monitor Acer AL2017
I had this problem once. Turned out to be the VGA plug connecting to the computer. Make sure this is inserted at the computer properly. Wiggle the plug and see if that effects the monitor display. If it does, then replace the VGA lead. Also check that your video card is inserted properly and go into the BIOS on your computer and make sure that the onboard Video chip is disabled (if your motherboard has one). If all this doesnt correct the fault, try uninstalling and installing the video driver again. If you are still having problems you may have a faulty video card.
Mar 17, 2010 | Acer AL2017 20" LCD Monitor
Don't have any video everything is never been used have three different vid cards and nothing comes on but the tower i don't get any video no matter what card i put in it.
Turn the computer off, and disconnect the AC power.
If the motherboard has an "integrated" video-adapter, connect one monitor to its VGA port, and connect another monitor to the VGA port on the add-in video-card, and turn the computer on, and watch both monitors, to see which one becomes "primary" and which one becomes the "secondary" monitor.
Reboot, and enter BIOS SETUP, and "disable" the "onboard" video-adapter, then "save and exit" and reboot. Now, which monitor stays "dark" and which monitor is "primary" ???
Mar 03, 2010 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
I have a L7vmm3 motherboard - everything is
If you have onboard video disabled in BIOS, then the driver can't find the video chip.
Enable onboard video in Bios and you should then be able to install driver.
Hank
Jun 09, 2009 | EliteGroup (L7VMM) Motherboard
I took my pc apart last night to do some kabinett mods to my antec 900. and put everything back togheter and startet up, everything seems to work but i dont get no picture on my screen, it says no signal...
"No signal input" means that the signal is not making it from your video card to the monitor. Things to try: 1) check your monitor cable to make sure you didn't accidentally bend any pins when you reconnected it. 2) Unplug the monitor for about 5 minutes and then try again. 3) If you are positive that everything is connected correctly and that things are working (you can hear the hard drive and fans spinning up but no video) then you may have somehow killed a component. disconnect everything except the power-supply, video card, 1 stick of ram, the CPU and the CUP fan and see if it you get video there. If you don't, then the next step would be to swap out each of those components left to see what died.
Jun 03, 2009 | ASUS Motherboard Striker II Formula
Start Uo
go into bios and disable the onboard video this should fix u problem
rate and vote
Dec 17, 2008 | AOpen XC Cube EZ915 (95EZ1592Z1) Barebone
Is visiontek a radeon hd 2400 pro agp 8 compatible w/ p4s800- mx?
ATI has recently written some better drivers for the 2400 Pro AGP cards,... Make sure the setting in the BIOS for the motherboard is set to the AGP or PCI for primary video. For AGP, make sure that you have the power from the power supply connected to the video card. Make sure that your motherboard does support 8X AGP video cards. If you are not sure, please check with motherboard manufacturer for compatibility.
Dec 13, 2008 | VisionTek ATI RADEON HD2400 Pro Edition...
No display from motherboard how will be resolve
Everything is connected firmly but the motherboard does not display
Dec 12, 2008 | Computers & Internet
Gigabyte GA-M61P-S3 Motherboard Logo
89 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
