Question about Kitchen Ranges
Broken Oven Light
Amana ACF3325AS Gas range. Everything works except oven light. Bulb is fine...bought several new ones...assume it must be the fuse but don't have the manual anymore and have no idea how to undertake this safely. Any suggestions...or am I more likely to mess something else up...and really how big of a deal is a light!
  • hjletendre Jan 14, 2008
    No difference in the light working or not if the door part is clicked on/off, and no change when "oven light" is switched on on digital display on oven itself...would be surprised if both switches are burned out unless inside they are one and the same...I have no idea how to go about looking at this....any suggestions? or am I back to the maybe fuse issue...or so what it's just an oven light...leave it alone lady! :)
    Very helpful thank you. Not the switch though...lucky for me as I had no idea how to fix. Unfortunatley once bent tab and put in new bulb it lit...but threw sparks and blew instantly...SCARY...thought the whole stove was toast for a minute but thankfully only tripped the breaker downstairs. Probably a wiring issue...had a mouse the drawer around the time the light first blew...probably connected. Since everything else perfect with the stove I think I should leave this alone...Beyond my skills! Hate to mess up a great stove!
    Thanks so much for your help!!!
    Sergeant:
  • 288 Answers
I would look at the switch as the problem for this. Either the one on the door, or the one you turn on yourself.
Posted on Jan 13, 2008
  • Rob Luna
    Rob Luna Jan 14, 2008
    First turn off the power. Next make sure the little tab at the bottom inside the socket is making contact with the end of the bulb. I have had this problem before and all it needed was to bend the little tab out a bit. That is the easy thing to check. Next is the switch. If I am correct the light is turned on by opening the door and by flipping an on/off switch, right? This is wired in a 3 way manner. If the common has burnt out on one, then it will effect the other. I haven't ever seen an oven light that had an individual fuse for just the light. Are there any other functions that do not work?
I have an Amana oven with Model # ACF3325AS. A month ago I had a code F3, which a repair man resolved. Now I've got a F2 code stating that the oven is overheating. Can you help with what part I'm...
Hi
F2/F3 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 25, 2011 | Amana ACF3325AS Dual Fuel (Electric and...
Oven will not light
Most likely your oven igniter is faulty. When they get worn they will heat up but not get hot enough for the gas to turn on.
Part number is 7432P062-60
May 18, 2009 | Amana RanARG7302 Gas Kitchen Range
Oven not lighting
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
May 06, 2009 | Amana ACF3325AS Dual Fuel (Electric and...
Hello, I have a Frigidaire freestanding crown series gas range that has two problems. The most important being that the oven does not light. The stovetop lights, except one burner that you hav to light...
I figured it was the ignitor given the burners work fine and I could smell gas from the oven when I would try to turn it on. So I found a local parts store and bought the replacement ignitor. I cut the wires of the old ignitor close to the ceramic and spliced the new one on with porcelain nuts and voila my oven now works again!
Nov 18, 2008 | Frigidaire Kitchen Ranges
Control panel stuck om 5 Ab and does not work
youve somehow had the oven enter a Sabbath mode SAB if the code
Sabbath mode can also be cancelled
by pressing and holding the 8 key for 3
seconds
http://www.servicematters.com/maytag_library/docs/S231_5R0.pdf
hers a link to a manual check page 14 for your problem explained
Nov 02, 2008 | Amana ACF3325AS Dual Fuel (Electric and...
Oven will not light
ck your light bulb . and ck with meter see if you geting any voltidge
Feb 05, 2008 | Amana AGR5735QDS Gas Kitchen Range
Amana Range ARG7300W
yep open the oven door unplug the range remove the racks on the bottom liner should be some screws remove them then take the liner up and out if there is a flame spreadder on the burner tube remove it at the back of the burner bar should be the ignighter most new ones are generic you just cut the wires on the old one and splice the new one on with cerramic wire nuts make sure the wires are away from the burner bar reverse dissambily turn oven on should light within 30 secs if ya pluggedit back in
Dec 29, 2007 | Amana RanARG7302 Gas Kitchen Range
Kitchen Ranges Logo
423 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
