Question about Car Audio & Video
2004 dodge intrepid
Yea, call me a girly-girl, but I am not sure where the camshaft sensor is on my 2004 dodge intrepid. I know it is on the drivers side at the front but I am not sure what it is I am looking at, I have a new one already to put! I couldn't find a correct product category, either. So, I am hoping this works
  • 102 Answers
I found this bit of information on
just changed my 04 intrepid cam sensor , it is not that hard as I thought. just lose 6(or seven 7 can remember clearly) bolts(10mm) on top of the plenum, in front of the plenum there are two clips on each corner, loose it with 15 mm( probably) socket wrench, you even don't need to take it out of the engine, it can be removed to the other side of engine, which will allow the plenum to go up a little bit, that space is good enough to take the cam sensor out. there is a 10 mm bolt to hold the sensor you also need to take it out.
remember: for the bolts on top, when you tie it after you need 105 in.lbs torque.
Some more Intrepid info can be found here
Posted on Jan 13, 2008
Where is the camshaft position sensor located on a 2003 dodge intrepid?
Depends on which motor you have, but the 2.7 sensor is in the front of the timing belt cover, on the drivers side. it has a 13mm bolt holding it in place. the bolt has an extension which a wire loom is attached. Slightly ornery to reach with the radiator cover in place, but you can do it if you don't have really big hands. The 3.2 and 3.5 motor has the sensor in roughly the same area, but is inserted on top of the rear timing cover, drivers side. Much more easily serviced.
Aug 21, 2011 | 2000 Dodge Intrepid
Where is the camshaft position sensor on a dodge 04 intrepid
The camshaft position sensor is mounted in the front of the head on 2.7L or belt cover on the 3.5L .
Apr 18, 2011 | 2004 Dodge Intrepid
Down on front bottom of engine block. Follow the spark plug wires to coil packs and ignition module. Then there will be two or three more wires that run from there down to the crankshaft position sensor.
Jan 16, 2011 | 2004 Dodge Intrepid
Locate cam position sensor on 2004 dodge intrepid
The camshaft position sensor is mounted to the top of the timing case cover.
Oct 25, 2009 | 2004 Dodge Intrepid
Where is the camshaft position sensor located on a 2000 Dodge Intrepid?
If it is a 3.5 it is located on the front of the engine on the drivers side under the plenum.
Oct 23, 2009 | 2000 Dodge Intrepid
Transmission for a 2004 dodge intrepid
you should have a input sensor and a output sensor on the driver's side of the trans!!
they are common to go out on these intrepids!!!
Jun 25, 2009 | 2004 Dodge Intrepid
Location of the camshaft and crankshaft sensors
cam sensor is on the driver side, front of the motor, just below the valve covers in easy veiw, just outboard of the water temp sensor and they both share the same wiring harness.  The cam sensor is on the passenger side, actually on the transmission bell housing.  It takes the signal from the flywheel next to the ring gear, about an inch from the engine on the transmission bellhousing.  Accesible from the top and easier if you remove the air filter duct.  Or jack up the front passenger side and easier if you come in from the front and its behind the axel, behind the motor, go up the bell housing, just below crank shaft level.  Go with this first , it tells the comp when to send fuel.  If you're getting spark with a 1381 code and you're choosing between CAM & CRANK, start with this, this is the culprit.  Consider getting it from the dealer.  Good luck.  This is Waverunner70, Hope I could help.
Feb 28, 2009 | 1999 Dodge Intrepid
Camshaft position sensor loacation on a 2004 dodge intrepid
cam sensor is located on the timing cover drivers side top
Jun 24, 2008 | 2004 Dodge Intrepid
2004 Dodge Intrepid cuting off
try to replace your crank sensor but before that top on computer with car runing and see if stalls if it does your computer is not good most of times the computer is located by the drivers front fender at front side in engine compartment
Jun 01, 2008 | 2004 Dodge Intrepid
Car Audio & Video Logo
222 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
