Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
H and F flashing no numbers
I have an HE 3 Kenmore front loader washer. I have just started having problems with my washer. (my 5 year warranty expirded two months ago)
After the washer runs for a couple of miniute I will hear a beeping sound and F and H will start flashing until I press the start button again and the washer will start working as normal.
  • JaneDoe6835 Jan 30, 2008
    I have owned my HE3 washer for 7 weeks and it is doing the same thing, running for a few minutes and then flashing F and H, however, when I press start again any water in the machine drains out and then the machine turns itself off - not too sure what is happening or why. I was delighted to find this issue online but the solutions are not the same.
  • CFARI Mar 09, 2008
    I have the same issue. When I start the washer it's ok, but after a couple of minutes it beeps F & H. I click pause and then start and sometimes it starts and sometimes it beeps about 3 or 4 times before it works again.
  • 125 Answers
Check for kinked hoses and blocked screens on the inlet. It could also be a problem with the pressure hose, if its out of its clip on the back of the machine it could have gotten rubbed on the tub and has a pin hole in it. it should be in a clip that also holds the drain hose. could also be a drain issue, or a flow meter problem or a CCU problem. Hope this helps, email me back if you need to.
Posted on Jan 14, 2008
My Kenmore front loader washer is 5 years old. It
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 16, 2009 | Kenmore Elite 45986 Front Load Washer
Crack in the bottom of my Kenmore washing machine tub
What is the model number? Is this a front loader or a top loader? To answer your question, yes, the tub can be replaced. You need to take a look at your warranty information to see if this can be replaced at no cost to you. Most manufacturer's warranties cover the first year against any major defects. However, some warranties are extended on certain parts. Something you may consider.
If you post back with your complete model number, I can give you an idea on how much a replacement tub may cost you, and if you have to pursue this on your own...I can give you the steps required to replace the tub.
NOTE: Marine epoxy or plumbers goop may work as a temporary fix in the mean time.
Aug 18, 2009 | Frigidaire ATF6000ES Front Load Washer
F35 and Suds error on Kenmore Elite HE5t
I also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
Jul 20, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite top loader
Call or email the consumer feedback or make a complaint to Sears. I had a similar prob. Sears ending up replacing rhe washer and paying for rental. Took up to 3-6 months, calling and writing complaint letters.
Jun 03, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Stops - lights flashing
Other posts on this site address the issue of the flashing lights on the Kenmore HE, saying that your first step is to check the filter behind the front foot panel. (The manual nowhere mentions this hard-to-find but easy-to-empty device.) Our filter certainly needed to be emptied...we found over $7 in change packed in there.
But in our case, emptying the filter did not stop the lights from flashing. We called the Sears technician and paid $129 for him to tell us that we needed a new motherboard computer. Those cost $255, which puts us in the market for a new machine. How to avoid buying another machine that only lasts 3 years?
Instead of Sears or a big box store, we then went to a local appliance store, shabby in appearance but a place where the salesmen are also repairmen. We learned that if you want a durable machine that lasts 10 years or more, don't consider a front loader or a machine with computers (the Kenmore HE has 3 different computers, each of which can fail). Sure, there are no guarantees that any machine will last 10 years, but at least the local appliance stores have people who are allowed to give you advice over the phone after your warranty runs out. Our salesman claimed to save four problems a day over the phone, and said he laughed at people who insist on front loaders. "The more parts you have, the more parts can break," as he said. By the way, top loaders don't need a filter like the front loaders do.
How do you get a washer to last 10 years if you can't spend more than $600? Buy a loud-*** machine with a stainless steel tub, be careful not to overload it, and empty pockets before you load, especially of nails or things small enough to fit through the holes in the sides of the tub.
What is that loud, clunky sound you hear coming from the laundry room? That could be the sweet sound of affordability and durability. (We looked at Maytag and Speed Queen top loaders.)
Apr 13, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore HE3 Front Loader Washer Cold Water Intake problem
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore front loader Model 48102 will not start
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Mar 14, 2009 | Kenmore Washing Machines
Whirlpool Duet Washer (GWH9100LW1) Bangs Loudly during spin
how old iss your washer? do you have an owners manual. because usually there is an extended factory warrenty on the tub and basket. the only thing you would have to pay for would be the labor. Call whirlpool if you do not have a owners manual to find out. the bearing is compressed in the tub. does it sound like an airplain taking off in your house that's usually it.
Jan 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
42 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
