Question about Ovens
Baumatic oven not heating up
I have a Baumatic oven, it is Model BT180SS and mentions B600 - not sure which is correct...
When connected to power all of the clock display lights up.
When turned to grill or oven setting the oven makes a noise, but there is no heat and the fan does not turn.
The light does not work either.
If anyone could offer advice it would be much appreciated!!
Thanks!!
Chris
  • Anonymous Mar 24, 2014
    thermostat light stay on on my baumatic b600
Hi Damien,
Many thanks for your help - unfortunalty have tried this and it dosent work... BOO
Thanks,
Chris
Posted on Mar 29, 2008
I have the same model steel finish was looking for parts mysel and came across yr dilema... I had that problem before . I always turn left knob to fan.. turn heat to whatever say 200 then click the button with the hand signal and i never touch any other button it alays does the job for me.. i cant cook so never need to touch ant other button ,,,, its a timer issue that stops it heating up swtch it all off at spur or mains start it up again
DamienPJennings@aol.com hope this helps
Posted on Jan 21, 2008
After a power cut my Baumatic oven won't now work. Power is going to it, time is correctly set but oven won't turn on. Any help appreciated.
If this unit is still under warranty, Baumatic will repair it for free. Their service number is 0118 933 6911. I recommend trying them first before making any repair attempts. You could try unplugging it for a couple minutes to reset the computer.
Jun 13, 2016 | Baumatic Ovens
Hello, I have a Baumatic B180SS (B600) oven which no longer heats up when i choose the fan oven option. The fan still works and if i change it to Grill it heats up still. Can you please advise me of...
we can not guess at any cost to repair . that is many times a local thing by your location in the world .could be a bad controller but only a repair tech can really tell for sure
Jan 14, 2018 | Baumatic B180 Electric Single Oven
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
My Baumatic oven now displays F4E0 after a power surge, the fan still works but there is no heat.
more than likely the heating element blow but check to see if theres a fuse in line with that element
Jan 23, 2010 | Baumatic B187 Electric Single Oven
Oven does not heat up.
You will probably find that it is the oven element that has failed.
This is to be found at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 01, 2010 | Baumatic B187 Stainless Steel Electric...
Baumatic built in oven (B600) product manual
I have a Baumatic P650SS oven. To adjust the timer volume, wait until it is beeping and then press the minus button and it will adjust through 3 sound levels. Release the minus button and the sound level of the audio signal will be set.
Dec 07, 2008 | Baumatic Ovens
Noisy Oven when heating up & fan spinning
Neth, Im not familiar with this oven but I thing someone is handing you a line. I've been doing this for 30 years now and never saw a oven cavity arch when heating. The fact is that there is something wrong with the fan motor or fan blades itself. Call this cat back and have them honor your warranty...Catriver..post back.
Sep 12, 2006 | Baumatic B180 Electric Single Oven
Ovens Logo
592 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
