Question about Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L
10in sliding compound mitre saw
I can't seem to release the bevel lock on the back of the saw
    Problem Solver:
  • 5 Answers
Turn the bevel lock to counter clockwise
Posted on May 29, 2008
New Hitachi miter saw C10FCG can't get clamp lever to loosen to set bevel angel. Help?
I have a Bosch, and I am not really familiar with your model Hitachi. However, I do know that most compound miter saws have a locking pin that clicks in at frequently used settings like 90 and 45. This pin must be released (pulled out) before the bevel can be changed.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_f6ca18ca1db028ed
Nov 15, 2017 | Hitachi Saws
Bosch 10 duel compound saw won't bevel.
Be sure to release (pull out) the bevel locking pin.
Apr 29, 2017 | Bosch Saws
I did a 45 degree bevel cut with my Dewalt portable table saw and now I can not get the blade back to a 90 degree position, any thoughts?
Did you check to see if the saw has a locking nut on the front of the bevel gauge handle? Its possible you just locked it into position and forgot to unlock.
Oct 05, 2014 | Dewalt Saws
How do i unlock dewalt dws780?
Curious if you got an answer? My Model 36-230 miter saw is locked in doen position and I can't get it unlocked and upright.
Jun 07, 2014 | Dewalt Miter Saws 12" Double Bevel...
Dewalt 12 inch compound sliding miter saw
This saw has locking indexing to set bevels for 52 degree crown molding the other common crown angle is 45 degrees, the bevel setting needs to be other than where the locking indexs are for the 52 degree crown. Problem is that the bevel lock does not securely hold at the bevel angle required. Is their an adjustment to get this lock to hold tighter.
Jan 04, 2012 | Dewalt 12" Beveling Sliding Compound Miter...
The bevel on my my ryobi 10" table saw model BTS12S does not change from the knob reguardless of the position of the bevel lock ar regaurdless if i adjust the bevel lock. i just got this saw so i do...
Suspect that a part was left out of the bevel adjust mechanism. Best to take the saw back and get a warranty replacement--let warranty fix the defect. Can you change the bevel of the blade by pushing/pulling the blade? I would suspect a missing worm gear on the bevel control shaft if you can. Otherwise, look for loose/missing set screws on the shaft or possibly a missing key. Good luck!
Oct 30, 2010 | Garden
I have purchased a dewalt 718, 12 inch sliding double bevel saw , private sale, saw was only used a couple of times and is in new condition .Checked cutting bevels and found that the left 45 degree does...
The fence may be getting in the way of the arm when you adjust the trunion assembly fully to one side or the other for bevel cutting. Adjusting the fence all the way out away from the trunion assy. should allow full 45deg adjustment. If this is not the case, it could be--even though its only slightly used--that there is sawdust built up enough in the housing to keep the arm from fully adjusting.
While the latch COULD indeed be faulty, it generally should always be tightened/locked so that the trunion assy. is fimly "locked" before cutting as this is designed to keep the saw from shifting mid cut, causing binding, uneven cuts, broken blades, seized bearings, etc.
Dec 02, 2009 | Dewalt Heavy - Duty 12" Double - Bevel...
I have a 10" ryobi table saw and my bevel will not return to the 0 degree position. I can change the angle, but I can not get the blade to sit straight up and down. I can push it almost to zero with much...
I have a Ryobi folding table saw and I learned how to adjust the bevel through trial and error. There are two allen key machine set screws in the top of the table. One for 90 and the other for 45. I backed the 90 screw off past 90 and than set the blade exactly at 90. Now I screwed the allen screw in to touch the blade. It seemed to work for me. Mind you it will have to be checked often to insure a perfect cut. Good luck.
May 03, 2009 | Saws
Finding the lock button..changing a circular saw blade? "skill saw brand,usa" cannot seem to find it anywhere
older model of circular saw dont have a spindle lock.wedge the blade on a bench vise & make sure ur not clamping the teeth of the blade & then turn the blade screw clock wise.
Jul 03, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Jan 13, 2008 | Bosch 12" Dual - Bevel Compound Miter Saw...
Bosch 12" Dual - Bevel Compound Miter Saw with Upfront Controls and Laser Tracking 4212L Logo
757 people viewed this question
Top Bosch Saws Experts
Craig Butler
Craig Butler
Tim Venetis
Gary Nitowski
Are you a Bosch Saw Expert? Answer questions, earn points and help others
