Question about Cobra DC5600 Digital Camera
I have a Cobra DC550
Ok my husband got it for me in dec. of 2006. Ok I hadnt never used the flash on it until dec.2007 at parents house for christmas. Anyways when I used the flash it went hay wire. I had brand new batteries in it before I use it. And when I tried to use it wouldnt do nothing. The green light was on but the flash wouldnt work on it. And when I contacted the manufacturing company they couldnt do nothing about it cause it didnt have no warranty. The warranty had ran out. But what I was wondering if it needs a new bulb or something.
    Top Expert:
  • Cobra Master
  • 2,931 Answers
Holy cow! It is a 10 year old camera that cost no more than $50 new! Throw it away and buy another.
Posted on Feb 01, 2018
6ya staff
SOURCE:
Anonymous
  • 36 Answers
SOURCE: Was wondering if anyone knows where to find a
Should be able to find it here, if I remember correctly it is a relay circuit http://www.cbtricks.com/radios/browning/golden_eagle_mark_4/index.htm
Posted on Jun 09, 2009
ToecutterPA
Mike
  • 13 Answers
SOURCE: Hi, I have a Cobra 29 NW ST CB Radio and I was
LED's do matter how they're installed.
Test your LED leads w/ a batt. first before soldering in you 29 board.
Look at you existing leads from you burnt out bulb. One red?
Then its your Pos terminal. when your LED lights up on your Batt. test you'll know which one is the POS/NEG legs. then resolder it into your board.
Mike
Posted on Dec 31, 2010
steve132003
Steve Tompkins
  • 98 Answers
SOURCE: i have a headphone/microphone that isnt cobra
Its probably wired different than Cobra like Microphones are. If you tamper with wires you may try combinations and it may work. Otherwise, best to buy Cobra replacement.
Posted on Apr 01, 2011
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: Whats wrong? I cannot use a coffe machine 1600
That should work....
Are you connected directly to the battery???
Are they good solid connections??
Do the connections heat up and spark/smoke....or does the inverter kick out??
You are about maxed out on what you can run on that setup, but it should be running for you...sometimes a heating element load can be problematic though... they pull more they you think or they say they will...
heatman101
Posted on Jun 20, 2011
Robert
  • 54 Answers
SOURCE: I bought 3o brand new standard cobra mics from an individual. The wire is not the standard color code. these mics do not work on cobra 4 pin radios. Whats up?
THE YELLOW I BELIEVE IS THE AUDIO LEAD WITCH GOES TO PIN 2 AND SHIELD IS PIN 1 PIN 3 IS TRANSMIT AND 4 IS RECEIVE
Posted on Feb 27, 2013
How is it repaired error E-29?
Search Results
    Motorola Spectra FAIL and ERROR Codes
    www.repeater-builder.com/motorola/spectra/spectra-error-codes.html
    Dec 27, 2007 - Motorola Spectra FAIL and ERROR Codes. ... For example, a radioFAIL code may look like this: "FAIL 01/90", where the first two digits ("xx" in the ....FAIL 10/84, Trunking EEPROM blank, Troubleshoot Trunking Option, CB.
    [PDF]How to Use Your Cobra 29 LTD Classic - Cobra Electronics
    https://www.cobra.com/sites/.../manuals/29LTDCLA.pd...
    Cobra ElectronicsBefore installing the CB radio, .... Even though the Cobra 29 LTD Classic has an automatic noise ...... referring to the manual, you still need help, call Cobra ...
Jan 13, 2016 | Radio Communications
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
https://answers.yahoo.com/question/index?qid...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from answers.yahoo.com
Dimming Microwave Light - Breville Support
brevilleusasupport.com/bmo734xl/dimming-microwave-light/
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
Dec 21, 2015 | Microwave Ovens
I have a 2006 Ford Ranger sport that has a missfire and the plugs, wires, and fuel filter has been changed. Still has a misfire, what else could it be?
2006 Ranger 3.0 misfires at idle and has problems accelerating ...
www.topix.com > Ford Ranger
Dec 27, 2010 - 2006 Ranger 3.0 misfires at idle and has problems accelerating. Posted in the Ford Ranger Forum. Leave a Comment Track Replies. 2000 ranger misfire/stumble at idle no codes
Nov 4, 2009
Check Engine light flashing- Loss of power
Jan 26, 2009
2002 ranger misfire rough idle
Jul 27, 2007
1997 Ranger Misfires
May 31, 2007
More results from www.topix.com
Part 1 -How to Test a Misfire Problem (Ford 4.0L V6)
troubleshootmyvehicle.com > Ford > 4.0L
Dec 19, 2013 - How to Test Misfire Codes (4.0L Ford Explorer, Ranger, Aerostar, Mercury ... Ignition System: The majority of misfire codes have their root cause ...
Nov 13, 2015 | 2006 Ford Ranger - Sport, SuperCab, short...
I used equity on my parents home to buy my new house. I have already paid off the equity amount borrowed with westpac but they will not release my parents home.
It sounds like it is time to refinance your house through another lender. If you originally bought in 2006 you can probably get a lower rate anyway. Once you refinance the home and pay off the original loan the original lender has to release any lien on your parents home.
Mar 07, 2014 | Computers & Internet
How do you replace the thermostat on a 2007 Buick Terraza?
Hi!!
Engine Coolant Thermostat and Housing Replacement, Tools Required: Hose Clamp Pliers.
Removal Procedure IMPORTANT:Use the hose clamp pliers to gently release tension on the hose clamp until the hose clamp lock feature engages allowing removal of the hose.
Fig. 1: View Of Radiator Inlet & Outlet Hoses
  • Drain the cooling system.
  • Using the hose clamp pliers, release the tension on the hose clamp at the thermostat housing and reposition the clamp.
  • Remove the radiator outlet hose from the thermostat housing.
Fig. 2: Identifying Thermostat Housing & Bolt/Stud
  • Remove the thermostat housing bolt/stud.
  • Remove the thermostat housing.
INSTALLATION
  • Position the thermostat housing.
  • Install the thermostat housing bolt/stud.
  • Tighten: Tighten the bolts to 25 N.m (18 lb ft).
  • Install the radiator outlet hose to the thermostat housing.
  • Using a small flat-bladed screwdriver, release the hose clamp retention lock at the thermostat housing.
  • Fill the cooling system.
Good Luck and Merry Christmas!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Dec 17, 2010 | 2007 Buick Terraza CXL Wagon
Battery won't keep charge
At that price point, these are completely disposable if giving problems. Otherwise, Contact your local retailer directly or online here: Support Cobra Electronics Corporation
Aug 02, 2017 | Cobra MicroTalk FRS 110-2 (14 Channels)...
CANNOT READ DISK
the ps2 console have all been acting up. my solution is to go out and get an upgrade (ps3)
Jul 18, 2008 | Sony PlayStation 2 (PS2) Console
COBRA DC6550
Hi ill have a look now for you and let you know what you need to do ok bare with me for few minutes ok
Feb 12, 2008 | Cobra Digital DC6550 Digital Camera
Dec 2001 Blue reflection and arch on bottom 1/4 of picture
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 23, 2008 | Toshiba 43H71 43" Rear Projection...
Cobra DC5600 Digital Camera Logo
89 people viewed this question
Top Cobra Cameras Experts
Ekse
ray gallant
ray gallant
Tom Chichester
Are you a Cobra Camera Expert? Answer questions, earn points and help others
