Question about Sony KP-43HT20 43" Rear Projection HDTV-Ready Television
Sony with blue screen
Well the Sony 43 inch rear projection TV is approximately 8 years old so I guess it doesn't owe me anything. Was watching it, everything was fine, turned it off, moved it two feet, (I was careful) and when I turned it back on, the screen was all blue, no sound or picture. Any ideas?
  • Sony Master
  • 5,138 Answers
Make sure you are on tv slection and not video1 ,aux . pull up menu go to setup look for cable/air make sure you are in tv mode not video aux.if this does not fix it then you may have bad tuner.
Posted on Jan 17, 2008
I have a sony rear projection Tv 43 inch about 13 years old the red light in front blinks continuously when the on button is pushed and nothing else happens\r\ndue to it's age will I be able to get it...
It has been quite sometime, that I have repaired this TV. In one case the audio IC with standby is bad. The symptom you describe, is my first area of trouble shooting. You may resist the temptation to replace this TV. I understand. It would be better to replace this TV. Sony is a unique TV, and parts for this may be substituted with non originals. Even if this set is repaired, it will be a matter of short time that it will go down. I would certainly shop for a new Sony flat screen TV. Your chances of having a long running TV is in your best interest. Thanks for asking and show all hands of support!
Aug 15, 2011 | Sony KP-43T70 43" Rear Projection...
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Picture will freeze occasionally for approximately 30 seconds, then return to normal. Switching channels seems to take care of the freezing right away. It is a 53 inch rear projection about 8 years old,...
Good Day,
Try upgrading the Screen refresh rate.Right click on your desktop,properties,in the tab settings select advanced and then select the monitor tab.Select 85-100Hz in refresh rate.
I hope this helps...
Good Luck!
Jun 22, 2009 | Sony KP-53HS30 53" Rear Projection...
Blue Vertical Lines on the screen
It means the optical block is going bad. Contact Sony support. They will sometimes warranty these even after the 1yr warrany has expired. Have your model and serial numbers handy.
May 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony KDF50 rear projection TV with a Blue tinge (haze) on screen
You have a problem within the light engine. This a hugely expensive. If the set is not too old you could contact Sony and see if they will help you out. Otherwise it is not eceonomical to repair
Mar 30, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Tv shutting off!
replace the high voltage block
the part number is (8-598-955-32)
comen problem for you model number.
Jan 13, 2009 | Sony KP-65WV700 65" Rear Projection HDTV
Sony KP-43HT20 43" Rear Projection HDTV-Ready Television Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
